Периодически отваливается модем
Использую модем только для отправки алармов по SMS. Заметил, что периодически модем пропадает, перестает мигать лампочка на контроллере, смс-ки не ходят.
Судя по логам, отваливается весь USB:
Спойлер
|22-10-2023 14:58:50.770 [NetworkManager]|<info>  [1697975930.7653] device (ttyUSB1): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')|
|22-10-2023 14:58:50.755|option 3-1:1.5: device disconnected|
|22-10-2023 14:58:50.754|option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2|
|22-10-2023 14:58:50.751 [ModemManager]|<info>  [base-manager] port ttyUSB2 released by device 'wbc'|
|22-10-2023 14:58:50.741|option 3-1:1.4: device disconnected|
|22-10-2023 14:58:50.740|option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1|
|22-10-2023 14:58:50.739|option 3-1:1.2: device disconnected|
|22-10-2023 14:58:50.739|option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0|
|22-10-2023 14:58:50.734 [ModemManager]|<info>  [base-manager] port ttyUSB1 released by device 'wbc'|
|22-10-2023 14:58:50.722 [ModemManager]|<info>  [base-manager] port ttyUSB0 released by device 'wbc'|
|22-10-2023 14:58:50.684 [ModemManager]|<info>  [base-manager] port usb0 released by device 'wbc'|
|22-10-2023 14:58:50.645 [avahi-daemon]|Withdrawing workstation service for usb0.|
|22-10-2023 14:58:50.644|rndis_host 3-1:1.0 usb0: unregister 'rndis_host' usb-1c1c000.usb-1, RNDIS device|
|22-10-2023 14:58:50.638|usb 3-1: USB disconnect, device number 13|
|22-10-2023 14:58:48.494 [ModemManager]|<info>  [modem5] state changed (searching -> registered)|
Как оказалось, проблема существует давно, но так как периодически перегружаю контроллер, я ёе редко замечал:
Спойлер
|22-10-2023 08:39:28.764 [NetworkManager]|<info>  [1697953168.7643] device (ttyUSB1): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')|
|22-10-2023 05:30:22.866 [NetworkManager]|<info>  [1697941822.8520] device (ttyUSB1): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')|
|22-10-2023 04:21:25.984 [NetworkManager]|<info>  [1697937685.9842] device (ttyUSB1): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')|
|17-10-2023 17:01:16.823 [NetworkManager]|<info>  [1697551276.8127] device (ttyUSB1): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')|
|16-10-2023 06:35:53.197 [NetworkManager]|<info>  [1697427353.1817] device (ttyUSB1): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')|
|14-10-2023 09:08:51.265 [NetworkManager]|<info>  [1697263731.2257] device (ttyUSB1): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')|
|11-10-2023 14:26:12.379 [NetworkManager]|<info>  [1697023572.3772] device (ttyUSB1): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')|
|10-10-2023 23:02:38.387 [NetworkManager]|<info>  [1696968158.3857] device (ttyUSB1): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')|
|08-10-2023 17:24:52.234 [NetworkManager]|<info>  [1696775092.2336] device (ttyUSB1): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')|
|08-10-2023 08:39:34.371 [NetworkManager]|<info>  [1696743574.3705] device (ttyUSB1): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')|
|07-10-2023 05:55:13.832 [NetworkManager]|<info>  [1696647313.8158] device (ttyUSB1): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')|
|06-10-2023 13:15:07.574 [NetworkManager]|<info>  [1696587307.5739] device (ttyUSB1): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')|
|05-10-2023 21:10:34.198 [NetworkManager]|<info>  [1696529434.1952] device (ttyUSB1): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')|
|05-10-2023 03:47:13.791 [NetworkManager]|<info>  [1696466833.7865] device (ttyUSB1): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')|
|13-09-2023 00:21:44.091 [NetworkManager]|<info>  [1694553704.0870] device (ttyUSB1): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')|
|31-08-2023 21:58:02.047 [NetworkManager]|<info>  [1693508282.0463] device (ttyUSB1): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')|
|28-08-2023 21:04:20.926 [NetworkManager]|<info>  [1693245860.9254] device (ttyUSB1): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')|
|28-08-2023 20:51:28.996 [NetworkManager]|<info>  [1693245088.9942] device (ttyUSB1): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')|
|16-08-2023 13:57:39.262 [NetworkManager]|<info>  [1692183459.2619] device (ttyUSB1): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')|
|11-08-2023 22:40:06.466 [NetworkManager]|<info>  [1691782806.4564] device (ttyUSB1): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')|
|11-08-2023 12:54:31.377 [NetworkManager]|<info>  [1691747671.3761] device (ttyUSB1): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')|
|10-08-2023 10:51:53.997 [NetworkManager]|<info>  [1691653913.9885] device (ttyUSB1): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')|
|04-08-2023 10:32:46.401 [NetworkManager]|<info>  [1691134366.4007] device (ttyUSB1): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')|
|04-08-2023 01:14:47.868 [NetworkManager]|<info>  [1691100887.8685] device (ttyUSB1): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')|
|03-08-2023 22:40:31.653 [NetworkManager]|<info>  [1691091631.6529] device (ttyUSB1): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')|
|03-08-2023 22:31:45.686 [NetworkManager]|<info>  [1691091105.6850] device (ttyUSB1): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')|
|01-08-2023 20:18:41.394 [NetworkManager]|<info>  [1690910321.3929] device (ttyUSB1): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')|
|01-08-2023 19:29:31.648 [NetworkManager]|<info>  [1690907371.6387] device (ttyUSB1): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')|
|01-08-2023 19:26:23.803 [NetworkManager]|<info>  [1690907183.8035] device (ttyUSB1): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')|
|30-07-2023 23:36:08.879 [NetworkManager]|<info>  [1690749368.8714] device (ttyUSB1): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')|
|30-07-2023 02:09:31.129 [NetworkManager]|<info>  [1690672171.1223] device (ttyUSB1): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')|
|30-07-2023 01:31:49.722 [NetworkManager]|<info>  [1690669909.7089] device (ttyUSB1): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')|
|29-07-2023 21:51:28.428 [NetworkManager]|<info>  [1690656688.4231] device (ttyUSB1): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')|
|27-07-2023 19:19:05.271 [NetworkManager]|<info>  [1690474745.2706] device (ttyUSB1): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')|
|27-07-2023 06:37:09.640 [NetworkManager]|<info>  [1690429029.6376] device (ttyUSB1): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')|
|26-07-2023 22:52:04.751 [NetworkManager]|<info>  [1690401124.7413] device (ttyUSB1): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')|
|26-07-2023 14:21:24.599 [NetworkManager]|<info>  [1690370484.5991] device (ttyUSB1): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')|
|26-07-2023 14:12:01.548 [NetworkManager]|<info>  [1690369921.5481] device (ttyUSB1): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')|
|25-07-2023 21:05:43.992 [NetworkManager]|<info>  [1690308343.9921] device (ttyUSB1): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')|
|25-07-2023 21:02:53.414 [NetworkManager]|<info>  [1690308173.3985] device (ttyUSB1): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')|
|23-07-2023 22:33:22.280 [NetworkManager]|<info>  [1690140802.2781] device (ttyUSB1): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')|
|23-07-2023 22:13:05.281 [NetworkManager]|<info>  [1690139585.2769] device (ttyUSB1): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')|
|14-07-2023 18:07:19.168 [NetworkManager]|<info>  [1689347239.1674] device (ttyUSB1): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')|
|13-07-2023 19:42:08.878 [NetworkManager]|<info>  [1689266528.8783] device (ttyUSB1): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')|
|12-07-2023 10:06:45.593 [NetworkManager]|<info>  [1689145605.5933] device (ttyUSB1): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')|
|07-07-2023 22:50:53.449 [NetworkManager]|<info>  [1688759453.4467] device (ttyUSB1): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')|
|19-06-2023 11:56:46.760 [NetworkManager]|<info>  [1687165006.7530] device (ttyUSB1): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')|
|05-06-2023 23:44:33.952 [NetworkManager]|<info>  [1685997873.9521] device (ttyUSB1): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')|
|31-05-2023 23:47:36.801 [NetworkManager]|<info>  [1685566056.7992] device (ttyUSB1): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')|
|20-05-2023 23:46:06.458 [NetworkManager]|<info>  [1684615566.4553] device (ttyUSB1): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')|
|19-05-2023 09:49:22.202 [NetworkManager]|<info>  [1684478962.2013] device (ttyUSB1): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')|
|16-05-2023 16:14:35.451 [NetworkManager]|<info>  [1684242875.4488] device (ttyUSB1): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')|
|16-05-2023 16:13:31.354 [NetworkManager]|<info>  [1684242811.3537] device (ttyUSB1): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')|
Подскажите, в чем проблема, как диагностировать?
(302,3 КБ)
Посмотрел, увидел что соединение так же прерывается. Не совсем диагностика, если канал не пользуется приоритетом.
ournalctl -u NetworkManager |grep "Activation: starting connection 'gsm 1'"
Oct 11 12:02:48 wirenboard-AWI3MCGC NetworkManager[10052]: <info>  [1697025768.7531] device (ttyUSB1): Activation: starting connection 'gsm 1' (1eb7ab23-9aed-4817-81af-954ebe384491)
Oct 11 12:02:52 wirenboard-AWI3MCGC NetworkManager[10052]: <info>  [1697025772.6950] device (ttyUSB1): Activation: starting connection 'gsm 1' (1eb7ab23-9aed-4817-81af-954ebe384491)
Oct 11 12:25:31 wirenboard-AWI3MCGC NetworkManager[478]: <info>  [1697027131.3217] device (ttyUSB1): Activation: starting connection 'gsm 1' (1eb7ab23-9aed-4817-81af-954ebe384491)
Oct 13 09:35:58 wirenboard-AWI3MCGC NetworkManager[465]: <info>  [1697189758.9135] device (ttyUSB1): Activation: starting connection 'gsm 1' (1eb7ab23-9aed-4817-81af-954ebe384491)
Oct 18 12:58:59 wirenboard-AWI3MCGC NetworkManager[465]: <info>  [1697633939.4188] device (ttyUSB1): Activation: starting connection 'gsm 1' (1eb7ab23-9aed-4817-81af-954ebe384491)
Oct 18 12:59:03 wirenboard-AWI3MCGC NetworkManager[465]: <info>  [1697633943.7977] device (ttyUSB1): Activation: starting connection 'gsm 1' (1eb7ab23-9aed-4817-81af-954ebe384491)
Oct 18 13:03:53 wirenboard-AWI3MCGC NetworkManager[482]: <info>  [1697634233.2583] device (ttyUSB1): Activation: starting connection 'gsm 1' (1eb7ab23-9aed-4817-81af-954ebe384491)
Oct 18 13:03:57 wirenboard-AWI3MCGC NetworkManager[482]: <info>  [1697634237.9878] device (ttyUSB1): Activation: starting connection 'gsm 1' (1eb7ab23-9aed-4817-81af-954ebe384491)
Oct 18 13:11:34 wirenboard-AWI3MCGC NetworkManager[482]: <info>  [1697634694.5702] device (ttyUSB1): Activation: starting connection 'gsm 1' (1eb7ab23-9aed-4817-81af-954ebe384491)
Oct 18 13:12:40 wirenboard-AWI3MCGC NetworkManager[482]: <info>  [1697634760.5016] device (ttyUSB1): Activation: starting connection 'gsm 1' (1eb7ab23-9aed-4817-81af-954ebe384491)
Oct 18 13:13:43 wirenboard-AWI3MCGC NetworkManager[482]: <info>  [1697634823.2697] device (ttyUSB1): Activation: starting connection 'gsm 1' (1eb7ab23-9aed-4817-81af-954ebe384491)
Oct 23 07:58:41 wirenboard-AWI3MCGC NetworkManager[482]: <info>  [1698047921.2931] device (ttyUSB1): Activation: starting connection 'gsm 1' (1eb7ab23-9aed-4817-81af-954ebe384491)
Oct 23 07:58:44 wirenboard-AWI3MCGC NetworkManager[482]: <info>  [1698047924.5426] device (ttyUSB1): Activation: starting connection 'gsm 1' (1eb7ab23-9aed-4817-81af-954ebe384491)
Вот вывод MM показательней, совпадает с dmesg.
Вердикт: проблема в usb между контроллером и модемом.
  • WB7.4 - 1 шт
  • WBC2-4G - 1 шт.
  • WBMZ4-BATTERY - 1 шт.
  1. ссылку на эту тему,
  2. серийный номер устройства, если есть,
Спасибо, написал. Теперь понятно, почему я не смог в свое время обновить образ с флешки, и не смог заставить работать Z-Wave донгл. Оказывается, в целом с USB проблемы…
Возможно, до исследования нельзя утверждать. Может быть брак компонентов, например. Но дело точно не в настройках и ПО.
