Хотел добавить на другой порт еще один виртуальный хост и сбил настройки nginx. Подскажите настройки по умолчанию и в каком файле. Я запутался
/etc/nginx/sites-enabled/default
Но этот линк в итоге ссылается на /etc/nginx/sites-available/default.wb
/etc/nginx/sites-available/default.wb я этот файл изменял. Его просто скопировать, куда? Предоставьте пожалуйста конфиг
> root@wirenboard-AYKBQYRG:~# cat /etc/nginx/sites-available/default.wb
> # You should look at the following URL's in order to grasp a solid understanding
> # of Nginx configuration files in order to fully unleash the power of Nginx.
> # http://wiki.nginx.org/Pitfalls
> # http://wiki.nginx.org/QuickStart
> # http://wiki.nginx.org/Configuration
> # Generally, you will want to move this file somewhere, and start with a clean
> # file but keep this around for reference. Or just disable in sites-enabled.
> # Please see /usr/share/doc/nginx-doc/examples/ for more detailed examples.
> # Default server configuration
> server {
> listen 80 default_server;
> #listen [::]:80 default_server;
> # SSL configuration
> listen 443 ssl default_server;
> #listen [::]:443 ssl default_server;
> # Self signed certs generated by the ssl-cert package
> # Don't use them in a production server!
> # include snippets/snakeoil.conf;
> root /var/www/;
> # Add index.php to the list if you are using PHP
> index index.html index.htm index.nginx-debian.html;
> server_name _;
> location / {
> # First attempt to serve request as file, then
> # as directory, then fall back to displaying a 404.
> try_files $uri $uri/ =404;
> # pass the PHP scripts to FastCGI server listening on 127.0.0.1:9000
> #location ~ \.php$ {
> # include snippets/fastcgi-php.conf;
> # # With php5-cgi alone:
> # fastcgi_pass 127.0.0.1:9000;
> # # With php5-fpm:
> # fastcgi_pass unix:/var/run/php5-fpm.sock;
> # deny access to .htaccess files, if Apache's document root
> # concurs with nginx's one
> #location ~ /\.ht {
> # deny all;
> # Virtual Host configuration for example.com
> # You can move that to a different file under sites-available/ and symlink that
> # to sites-enabled/ to enable it.
> #server {
> # listen 80;
> # listen [::]:80;
> # server_name example.com;
> # root /var/www/example.com;
> # index index.html;
> # location / {
> # try_files $uri $uri/ =404;
тут верно?
Все же открыто:
Спасибо
