Обратите внимание, в логе:
Jun 25 22:38:26 wirenboard-ANVKYF4F wpa_supplicant[326]: wlan1: Trying to associate with 00:be:75:42:31:e7 (SSID='' freq=2412 MHz)
Jun 25 22:38:26 wirenboard-ANVKYF4F wpa_supplicant[326]: FT: Invalid key management type (2)
Jun 25 22:38:26 wirenboard-ANVKYF4F wpa_supplicant[326]: nl80211: kernel reports: Authentication algorithm number required
Jun 25 22:38:26 wirenboard-ANVKYF4F kernel: RTW: rtw_set_802_11_connect(wlan1) fw_state=0x00000008
Jun 25 22:38:26 wirenboard-ANVKYF4F wpa_supplicant[326]: wlan1: CTRL-EVENT-STARTED-CHANNEL-SWITCH freq=2412 ht_enabled=1 ch_offset=0 ch_width=20 MHz cf1=2412 cf2=0
Jun 25 22:38:26 wirenboard-ANVKYF4F NetworkManager[428]: <info> [1719344306.3497] device (wlan1): supplicant interface state: scanning -> associating
Jun 25 22:38:26 wirenboard-ANVKYF4F NetworkManager[428]: <info> [1719344306.3510] device (p2p-dev-wlan1): supplicant management interface state: scanning -> associating
Jun 25 22:38:26 wirenboard-ANVKYF4F kernel: RTW: start auth
Jun 25 22:38:26 wirenboard-ANVKYF4F kernel: RTW: auth success, start assoc
Jun 25 22:38:28 wirenboard-ANVKYF4F wpa_supplicant[326]: wlan1: CTRL-EVENT-ASSOC-REJECT status_code=1
Jun 25 22:38:28 wirenboard-ANVKYF4F wpa_supplicant[326]: wlan1: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
Jun 25 22:38:28 wirenboard-ANVKYF4F NetworkManager[428]: <info> [1719344308.2847] device (wlan1): supplicant interface state: associating -> disconnected
Jun 25 22:38:28 wirenboard-ANVKYF4F NetworkManager[428]: <info> [1719344308.2869] device (p2p-dev-wlan1): supplicant management interface state: associating -> disconnected
Jun 25 22:38:29 wirenboard-ANVKYF4F NetworkManager[428]: <info> [1719344309.2883] device (wlan1): supplicant interface state: disconnected -> scanning
Какой на точке применяется метод аутентификации и алгоритм шифрования?
А если выключить (возможно включен) на точке доступа Fast BSS Transition (IEEE 802.11r-2008)?
