Вижу что настроено чтение всех каналов
"channels" :
"enabled" : true,
"name" : "Ch. 0 Time of operation, total"
"enabled" : true,
"name" : "Ch. 0 Nominal voltage"
"enabled" : true,
"name" : "Ch. 0 Basic/nominal current"
"enabled" : true,
"name" : "Ch. 0 Nominal frequency"
"enabled" : true,
"name" : "Ch. 0 Maximum current"
"enabled" : true,
"name" : "Ch. 0 Reference voltage for power quality measurement"
"enabled" : true,
"name" : "Ch. 0 Sum Li Active power+ (QI+QIV) Inst. value"
"enabled" : true,
"name" : "Ch. 0 Sum Li Active power+ (QI+QIV) Time integral 1 Rate 0 (0 is total)"
"enabled" : true,
"name" : "Ch. 0 Sum Li Active power+ (QI+QIV) Time integral 1 Rate 1 (0 is total)"
"enabled" : true,
"name" : "Ch. 0 Sum Li Active power+ (QI+QIV) Time integral 1 Rate 2 (0 is total)"
"enabled" : true,
"name" : "Ch. 0 Sum Li Active power+ (QI+QIV) Time integral 1 Rate 3 (0 is total)"
"enabled" : true,
"name" : "Ch. 0 Sum Li Active power+ (QI+QIV) Time integral 1 Rate 4 (0 is total)"
"enabled" : true,
"name" : "Ch. 0 Sum Li Active power+ (QI+QIV) Time integral 1 Rate 5 (0 is total)"
"enabled" : true,
"name" : "Ch. 0 Sum Li Active power+ (QI+QIV) Time integral 1 Rate 6 (0 is total)"
"enabled" : true,
"name" : "Ch. 0 Sum Li Active power+ (QI+QIV) Time integral 1 Rate 7 (0 is total)"
"enabled" : true,
"name" : "Ch. 0 Sum Li Active power+ (QI+QIV) Time integral 1 Rate 8 (0 is total)"
"enabled" : true,
"name" : "Ch. 0 Sum Li Active power+ (QI+QIV) Time integral 5"
"enabled" : true,
"name" : "Ch. 0 Sum Li Active power- (QII+QIII) Time integral 1 Rate 0 (0 is total)"
"enabled" : true,
"name" : "Ch. 0 Sum Li Active power- (QII+QIII) Time integral 1 Rate 1 (0 is total)"
"enabled" : true,
"name" : "Ch. 0 Sum Li Active power- (QII+QIII) Time integral 1 Rate 2 (0 is total)"
"enabled" : true,
"name" : "Ch. 0 Sum Li Active power- (QII+QIII) Time integral 1 Rate 3 (0 is total)"
"enabled" : true,
"name" : "Ch. 0 Sum Li Active power- (QII+QIII) Time integral 1 Rate 4 (0 is total)"
"enabled" : true,
"name" : "Ch. 0 Sum Li Active power- (QII+QIII) Time integral 1 Rate 5 (0 is total)"
"enabled" : true,
"name" : "Ch. 0 Sum Li Active power- (QII+QIII) Time integral 1 Rate 6 (0 is total)"
"enabled" : true,
"name" : "Ch. 0 Sum Li Active power- (QII+QIII) Time integral 1 Rate 7 (0 is total)"
"enabled" : true,
"name" : "Ch. 0 Sum Li Active power- (QII+QIII) Time integral 1 Rate 8 (0 is total)"
"enabled" : true,
"name" : "Ch. 0 Sum Li Active power- (QII+QIII) Time integral 5"
"enabled" : true,
"name" : "Ch. 0 Sum Li Reactive power+ (QI+QII) Inst. value"
"enabled" : true,
"name" : "Ch. 0 Sum Li Reactive power+ (QI+QII) Time integral 1 Rate 0 (0 is total)"
"enabled" : true,
"name" : "Ch. 0 Sum Li Reactive power+ (QI+QII) Time integral 1 Rate 1 (0 is total)"
"enabled" : true,
"name" : "Ch. 0 Sum Li Reactive power+ (QI+QII) Time integral 1 Rate 2 (0 is total)"
"enabled" : true,
"name" : "Ch. 0 Sum Li Reactive power+ (QI+QII) Time integral 1 Rate 3 (0 is total)"
"enabled" : true,
"name" : "Ch. 0 Sum Li Reactive power+ (QI+QII) Time integral 1 Rate 4 (0 is total)"
"enabled" : true,
"name" : "Ch. 0 Sum Li Reactive power+ (QI+QII) Time integral 1 Rate 5 (0 is total)"
"enabled" : true,
"name" : "Ch. 0 Sum Li Reactive power+ (QI+QII) Time integral 1 Rate 6 (0 is total)"
"enabled" : true,
"name" : "Ch. 0 Sum Li Reactive power+ (QI+QII) Time integral 1 Rate 7 (0 is total)"
"enabled" : true,
"name" : "Ch. 0 Sum Li Reactive power+ (QI+QII) Time integral 1 Rate 8 (0 is total)"
"enabled" : true,
"name" : "Ch. 0 Sum Li Reactive power+ (QI+QII) Time integral 5"
"enabled" : true,
"name" : "Ch. 0 Sum Li Reactive power- (QIII+QIV) Time integral 1 Rate 0 (0 is total)"
"enabled" : true,
"name" : "Ch. 0 Sum Li Reactive power- (QIII+QIV) Time integral 1 Rate 1 (0 is total)"
"enabled" : true,
"name" : "Ch. 0 Sum Li Reactive power- (QIII+QIV) Time integral 1 Rate 2 (0 is total)"
"enabled" : true,
"name" : "Ch. 0 Sum Li Reactive power- (QIII+QIV) Time integral 1 Rate 3 (0 is total)"
"enabled" : true,
"name" : "Ch. 0 Sum Li Reactive power- (QIII+QIV) Time integral 1 Rate 4 (0 is total)"
"enabled" : true,
"name" : "Ch. 0 Sum Li Reactive power- (QIII+QIV) Time integral 1 Rate 5 (0 is total)"
"enabled" : true,
"name" : "Ch. 0 Sum Li Reactive power- (QIII+QIV) Time integral 1 Rate 6 (0 is total)"
"enabled" : true,
"name" : "Ch. 0 Sum Li Reactive power- (QIII+QIV) Time integral 1 Rate 7 (0 is total)"
"enabled" : true,
"name" : "Ch. 0 Sum Li Reactive power- (QIII+QIV) Time integral 1 Rate 8 (0 is total)"
"enabled" : true,
"name" : "Ch. 0 Sum Li Reactive power- (QIII+QIV) Time integral 5"
"enabled" : true,
"name" : "Ch. 0 Sum Li Apparent power+ (QI+QIV) Inst. value"
"enabled" : true,
"name" : "Ch. 0 Voltage: any phase Inst. value Harmonic 1"
"enabled" : true,
"name" : "Ch. 0 Voltage: any phase Inst. value Harmonic 2"
"enabled" : true,
"name" : "Ch. 0 Voltage: any phase Inst. value Harmonic 3"
"enabled" : true,
"name" : "Ch. 0 Voltage: any phase Under limit threshold Harmonic / Distortion factor 0 Threshold 255"
"enabled" : true,
"name" : "Ch. 0 Voltage: any phase Over limit threshold Harmonic / Distortion factor 0 Threshold 255"
"enabled" : true,
"name" : "Ch. 0 Voltage: any phase Missing threshold Harmonic / Distortion factor 0 Threshold 255"
"enabled" : true,
"name" : "Ch. 0 Sum Li Power factor Inst. value"
"enabled" : true,
"name" : "Ch. 0 Supply frequency Inst. value"
"enabled" : true,
"name" : "Ch. 0 Sum Li Active power (abs(QI+QIV)+abs(QII+QIII)) Time integral 1 Rate 0 (0 is total)"
"enabled" : true,
"name" : "Ch. 0 Sum Li Active power (abs(QI+QIV)+abs(QII+QIII)) Time integral 1 Rate 1 (0 is total)"
"enabled" : true,
"name" : "Ch. 0 Sum Li Active power (abs(QI+QIV)+abs(QII+QIII)) Time integral 1 Rate 2 (0 is total)"
"enabled" : true,
"name" : "Ch. 0 Sum Li Active power (abs(QI+QIV)+abs(QII+QIII)) Time integral 1 Rate 3 (0 is total)"
"enabled" : true,
"name" : "Ch. 0 Sum Li Active power (abs(QI+QIV)+abs(QII+QIII)) Time integral 1 Rate 4 (0 is total)"
"enabled" : true,
"name" : "Ch. 0 Sum Li Active power (abs(QI+QIV)+abs(QII+QIII)) Time integral 1 Rate 5 (0 is total)"
"enabled" : true,
"name" : "Ch. 0 Sum Li Active power (abs(QI+QIV)+abs(QII+QIII)) Time integral 1 Rate 6 (0 is total)"
"enabled" : true,
"name" : "Ch. 0 Sum Li Active power (abs(QI+QIV)+abs(QII+QIII)) Time integral 1 Rate 7 (0 is total)"
"enabled" : true,
"name" : "Ch. 0 Sum Li Active power (abs(QI+QIV)+abs(QII+QIII)) Time integral 1 Rate 8 (0 is total)"
"enabled" : true,
"name" : "Ch. 0 Sum Li Active power (abs(QI+QIV)-abs(QII+QIII)) Time integral 1 Rate 0 (0 is total)"
"enabled" : true,
"name" : "Ch. 0 Sum Li Active power (abs(QI+QIV)-abs(QII+QIII)) Time integral 1 Rate 1 (0 is total)"
"enabled" : true,
"name" : "Ch. 0 Sum Li Active power (abs(QI+QIV)-abs(QII+QIII)) Time integral 1 Rate 2 (0 is total)"
"enabled" : true,
"name" : "Ch. 0 Sum Li Active power (abs(QI+QIV)-abs(QII+QIII)) Time integral 1 Rate 3 (0 is total)"
"enabled" : true,
"name" : "Ch. 0 Sum Li Active power (abs(QI+QIV)-abs(QII+QIII)) Time integral 1 Rate 4 (0 is total)"
"enabled" : true,
"name" : "Ch. 0 Sum Li Active power (abs(QI+QIV)-abs(QII+QIII)) Time integral 1 Rate 5 (0 is total)"
"enabled" : true,
"name" : "Ch. 0 Sum Li Active power (abs(QI+QIV)-abs(QII+QIII)) Time integral 1 Rate 6 (0 is total)"
"enabled" : true,
"name" : "Ch. 0 Sum Li Active power (abs(QI+QIV)-abs(QII+QIII)) Time integral 1 Rate 7 (0 is total)"
"enabled" : true,
"name" : "Ch. 0 Sum Li Active power (abs(QI+QIV)-abs(QII+QIII)) Time integral 1 Rate 8 (0 is total)"
"enabled" : true,
"name" : "Ch. 0 L1 Active power+ (QI+QIV) Inst. value"
"enabled" : true,
"name" : "Ch. 0 L1 Reactive power+ (QI+QII) Inst. value"
"enabled" : true,
"name" : "Ch. 0 L1 Apparent power+ (QI+QIV) Inst. value"
"enabled" : true,
"name" : "Ch. 0 L1 Power factor Inst. value"
"enabled" : true,
"name" : "Ch. 0 L2 Active power+ (QI+QIV) Inst. value"
"enabled" : true,
"name" : "Ch. 0 L2 Reactive power+ (QI+QII) Inst. value"
"enabled" : true,
"name" : "Ch. 0 L2 Apparent power+ (QI+QIV) Inst. value"
"enabled" : true,
"name" : "Ch. 0 L2 Power factor Inst. value"
"enabled" : true,
"name" : "Ch. 0 L3 Active power+ (QI+QIV) Inst. value"
"enabled" : true,
"name" : "Ch. 0 L3 Reactive power+ (QI+QII) Inst. value"
"enabled" : true,
"name" : "Ch. 0 L3 Apparent power+ (QI+QIV) Inst. value"
"enabled" : true,
"name" : "Ch. 0 L3 Power factor Inst. value"
"enabled" : true,
"name" : "Ch. 0 Angle of I(L1) - U(L1)"
"enabled" : true,
"name" : "Ch. 0 Angle of I(L2) - U(L2)"
"enabled" : true,
"name" : "Ch. 0 Angle of I(L3) - U(L3)"
"enabled" : true,
"name" : "Ch. 0 Sum Li A2h QI+QII+QIII+QIV Time integral 1 Rate 0 (0 is total)"
"device_type" : "energomera_ce308_dlms",
"slave_id" : "11446"
В счетчике настроены и активны все тарифы?
