Вот эти устройства, 84, 203 - они на отключенном порту?
покажите файл конфиг от wb-mqtt-serial
/etc/wb-mqtt-serial.conf
на отключенном порту 81 и 85
“debug”: false,
“ports”: [
“path”: “/dev/ttyRS485-1”,
“devices”: [
“slave_id”: “201”,
“device_type”: “WB-MR6C”,
“name”: “R201”,
“id”: “R201”,
“setup”: [],
“poll_interval”: 10,
“delay_ms”: 10
“slave_id”: “202”,
“name”: “R202”,
“id”: “R202”,
“setup”: [],
“delay_ms”: 10
“slave_id”: “203”,
“name”: “R203”,
“id”: “R203”,
“setup”: [],
“delay_ms”: 10
“slave_id”: “204”,
“device_type”: “WB-MR3”,
“name”: “R204”,
“id”: “R204”,
“setup”: [],
“delay_ms”: 10
“slave_id”: “206”,
“device_type”: “WB-MRPS6”,
“name”: “R206”,
“id”: “R206”,
“setup”: [],
“delay_ms”: 10
“slave_id”: “207”,
“name”: “R207”,
“id”: “R207”,
“setup”: [],
“delay_ms”: 10
“slave_id”: “208”,
“name”: “R208”,
“id”: “R208”,
“setup”: [],
“delay_ms”: 10
“slave_id”: “209”,
“name”: “R209”,
“id”: “R209”,
“setup”: [],
“delay_ms”: 10
“slave_id”: “50”,
“device_type”: “WB-MDM3”,
“name”: “DIM50”,
“id”: “DIM50”,
“setup”: [],
“delay_ms”: 10
“slave_id”: “51”,
“name”: “DIM51”,
“id”: “DIM51”,
“setup”: [],
“delay_ms”: 10
“slave_id”: “52”,
“name”: “DIM52”,
“id”: “DIM52”,
“setup”: [],
“delay_ms”: 10
“baud_rate”: 19200,
“parity”: “E”,
“data_bits”: 8,
“stop_bits”: 1,
“enabled”: true,
“response_timeout_ms”: 50,
“guard_interval_us”: 0
“path”: “/dev/ttyRS485-2”,
“devices”: [
“slave_id”: “80”,
“device_type”: “WB-MSW v.3”,
“name”: “D80 (Датчик движения на кухне)”,
“id”: “D80”,
“setup”: [
“address”: “282”,
“title”: “Ширина временного окна”,
“value”: “0”
“delay_ms”: 10
“slave_id”: “82”,
“name”: “D82 (Датчик движения в кабинете)”,
“id”: “D82”,
“setup”: [
“address”: “282”,
“value”: “0”
“delay_ms”: 10
“slave_id”: “83”,
“name”: “D83 (Датчик движения в столовой)”,
“id”: “D83”,
“setup”: [
“address”: “282”,
“value”: “0”
“delay_ms”: 10
“slave_id”: “84”,
“name”: “D84 (Датчик движения в с/у 1 этажа)”,
“id”: “D84”,
“setup”: [
“address”: “282”,
“value”: “0”
“delay_ms”: 10
“slave_id”: “86”,
“name”: “D86 (Датчик движения в прихожей)”,
“id”: “D86”,
“setup”: [
“address”: “282”,
“value”: “0”
“delay_ms”: 10
“slave_id”: “87”,
“name”: “D87 (Датчик движения в гостиной)”,
“id”: “D87”,
“setup”: [
“address”: “282”,
“value”: “0”
“delay_ms”: 10
“baud_rate”: 19200,
“parity”: “E”,
“data_bits”: 8,
“stop_bits”: 1,
“enabled”: true,
“path”: “/dev/ttyRS485-3”,
“devices”: [
“slave_id”: “81”,
“name”: “D81 (Датчик движения в холле 2 этажа)”,
“id”: “D81”,
“setup”: [
“address”: “282”,
“value”: “0”
“delay_ms”: 10
“slave_id”: “85”,
“name”: “D85 (Датчик движения в с/у 2 этажа)”,
“id”: “D85”,
“setup”: [
“address”: “282”,
“value”: “0”
“delay_ms”: 10
“baud_rate”: 19200,
“parity”: “E”,
“data_bits”: 8,
“stop_bits”: 1,
“enabled”: false,
“path”: “/dev/ttyRS485-4”,
“devices”: [],
“baud_rate”: 19200,
“parity”: “E”,
“data_bits”: 8,
“stop_bits”: 1,
“enabled”: false
“path”: “/dev/ttyMOD3”,
“devices”: [],
“baud_rate”: 9600,
“parity”: “N”,
“data_bits”: 8,
“stop_bits”: 2,
“enabled”: false
Можно в настройках портов поднять poll interval до 30 и посмотреть.
И “guard_interval_us”: 0
А почему четность стоит “E”? Она и на всех устройствах изменена?
надо поднять для проверки до 100000
И да, если включать устройства по одному?
Почему Е? У предыдущего контроллера на линии была вент установка с фиксированными параметрами соединения (19200 8Е1).
“guard_interval_us” и так 0 или я не понимаю что то?
до 100000 что поднять так и не понял?
там всего 2 устройства на 3м порту, я пробовал по одному включать. также виснет.
может скорость поднять до 115200?
Да, поднять до 100000 guard_interval_us
поменять на
“guard_interval_us”: 100000
И все устройства на этом порту должны иметь одинаковые параметры. Если четность E - то на всех.
что это означает? Там очень много таких логов, это только пара из сотен
ничего не изменилось все также виснет
также ничего не изменилось, если выключить 3й порт то все работает, только ждать пока включится теперь гораздо дольше нужно а не 5 сек
появились огромные тормоза, теперь по датчику движения свет включается с большим запозданием >15-20 сек
да
Это для теста, потом можно вернуть.
А если включать порт без утройств - тот же эффект?
Вывести
tail -f /var/log/messages
и посмотреть что творится
да
логи это только часть судя по времени их фиксации. почему то идут с запозданием
Jul 2 16:33:05 wirenboard-AE3UHZCX authpriv.info CRON[29407]: pam_unix(cron:session): session closed for user root
Jul 2 16:33:06 wirenboard-AE3UHZCX user.notice serial: device modbus:203 disconnected
Jul 2 16:33:07 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 holding(s) @ 8 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:33:08 wirenboard-AE3UHZCX user.notice serial: device modbus:203 disconnected
Jul 2 16:33:09 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 holding(s) @ 8 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:33:09 wirenboard-AE3UHZCX user.notice wb-mqtt-db[665]: 2020-07-02 16:33:09.299 NOTICE: Bulk processing took 201ms
Jul 2 16:33:10 wirenboard-AE3UHZCX user.notice serial: device modbus:203 disconnected
Jul 2 16:33:11 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:83: Serial protocol error: request timed out
Jul 2 16:33:11 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 holding(s) @ 8 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:33:12 wirenboard-AE3UHZCX user.notice serial: device modbus:203 disconnected
Jul 2 16:33:12 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:84: Serial protocol error: request timed out
Jul 2 16:33:13 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:87: Serial protocol error: request timed out
Jul 2 16:33:13 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:84: Serial protocol error: request timed out
Jul 2 16:33:13 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 holding(s) @ 8 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:33:14 wirenboard-AE3UHZCX user.notice serial: device modbus:203 disconnected
Jul 2 16:33:14 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 holding(s) @ 8 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:33:16 wirenboard-AE3UHZCX user.notice serial: device modbus:203 disconnected
Jul 2 16:33:17 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 holding(s) @ 8 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:33:18 wirenboard-AE3UHZCX user.notice serial: device modbus:203 disconnected
Jul 2 16:33:18 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 holding(s) @ 8 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:33:19 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:83: Serial protocol error: request timed out
Jul 2 16:33:20 wirenboard-AE3UHZCX user.notice serial: device modbus:203 disconnected
Jul 2 16:33:21 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:87: Serial protocol error: request timed out
Jul 2 16:33:21 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:83: Serial protocol error: request timed out
Jul 2 16:33:22 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 holding(s) @ 8 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:33:22 wirenboard-AE3UHZCX user.notice serial: device modbus:203 disconnected
Jul 2 16:33:23 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 holding(s) @ 8 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:33:24 wirenboard-AE3UHZCX user.notice serial: device modbus:203 disconnected
Jul 2 16:33:25 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:83: Serial protocol error: request timed out
Jul 2 16:33:26 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:84: Serial protocol error: request timed out
Jul 2 16:33:26 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 holding(s) @ 8 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:33:26 wirenboard-AE3UHZCX user.notice serial: device modbus:203 disconnected
Jul 2 16:33:27 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:84: Serial protocol error: request timed out
Jul 2 16:33:27 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 holding(s) @ 8 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:33:28 wirenboard-AE3UHZCX user.notice serial: device modbus:203 disconnected
Jul 2 16:33:28 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 holding(s) @ 8 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:33:29 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:82: Serial protocol error: request timed out
Jul 2 16:33:30 wirenboard-AE3UHZCX user.notice serial: device modbus:203 disconnected
Jul 2 16:33:30 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:87: Serial protocol error: request timed out
Jul 2 16:33:31 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 holding(s) @ 8 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:33:31 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:84: Serial protocol error: request timed out
Jul 2 16:33:32 wirenboard-AE3UHZCX user.notice serial: device modbus:203 disconnected
Jul 2 16:33:32 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 holding(s) @ 8 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:33:32 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:87: Serial protocol error: request timed out
Jul 2 16:33:34 wirenboard-AE3UHZCX user.notice serial: device modbus:203 disconnected
Jul 2 16:33:34 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:82: Serial protocol error: request timed out
Jul 2 16:33:34 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 holding(s) @ 8 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:33:35 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:84: Serial protocol error: request timed out
Jul 2 16:33:36 wirenboard-AE3UHZCX user.notice serial: device modbus:203 disconnected
Jul 2 16:33:36 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:84: Serial protocol error: request timed out
Jul 2 16:33:36 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:80: Serial protocol error: request timed out
Jul 2 16:33:37 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:87: Serial protocol error: request timed out
Jul 2 16:33:38 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 holding(s) @ 8 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:33:38 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:86: Serial protocol error: request timed out
Jul 2 16:33:38 wirenboard-AE3UHZCX user.notice serial: device modbus:203 disconnected
Jul 2 16:33:39 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 holding(s) @ 8 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:33:40 wirenboard-AE3UHZCX user.notice serial: device modbus:203 disconnected
Jul 2 16:33:42 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 holding(s) @ 8 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:33:42 wirenboard-AE3UHZCX user.notice serial: device modbus:203 disconnected
Jul 2 16:33:43 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 holding(s) @ 8 of device modbus:82: Serial protocol error: request timed out
Jul 2 16:33:43 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:82: Serial protocol error: request timed out
Jul 2 16:33:43 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 holding(s) @ 8 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:33:44 wirenboard-AE3UHZCX user.notice serial: device modbus:203 disconnected
Jul 2 16:33:44 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 holding(s) @ 8 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:33:45 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:87: Serial protocol error: request timed out
Jul 2 16:33:46 wirenboard-AE3UHZCX user.notice serial: device modbus:203 disconnected
Jul 2 16:33:46 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:84: Serial protocol error: request timed out
Jul 2 16:33:47 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 3 input(s) @ 9 of device modbus:87: Serial protocol error: request timed out
Jul 2 16:33:47 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:86: Serial protocol error: request timed out
Jul 2 16:33:48 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 holding(s) @ 8 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:33:48 wirenboard-AE3UHZCX user.notice serial: device modbus:203 disconnected
Jul 2 16:33:48 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:87: Serial protocol error: request timed out
Jul 2 16:33:50 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 holding(s) @ 8 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:33:50 wirenboard-AE3UHZCX user.notice serial: device modbus:203 disconnected
Jul 2 16:33:52 wirenboard-AE3UHZCX user.notice serial: device modbus:203 disconnected
Jul 2 16:33:52 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:87: Serial protocol error: request timed out
Jul 2 16:33:54 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 holding(s) @ 8 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:33:54 wirenboard-AE3UHZCX user.notice serial: device modbus:203 disconnected
Jul 2 16:33:54 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:86: Serial protocol error: request timed out
Jul 2 16:33:56 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 holding(s) @ 8 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:33:56 wirenboard-AE3UHZCX user.notice serial: device modbus:203 disconnected
Jul 2 16:33:56 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:86: Serial protocol error: request timed out
Jul 2 16:33:58 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 holding(s) @ 8 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:33:58 wirenboard-AE3UHZCX user.notice serial: device modbus:203 disconnected
Jul 2 16:33:58 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:83: Serial protocol error: request timed out
Jul 2 16:34:00 wirenboard-AE3UHZCX user.notice serial: device modbus:203 disconnected
Jul 2 16:34:00 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:83: Serial protocol error: request timed out
Jul 2 16:34:01 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:84: Serial protocol error: request timed out
Jul 2 16:34:01 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 3 input(s) @ 9 of device modbus:84: Serial protocol error: request timed out
Jul 2 16:34:01 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 holding(s) @ 8 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:34:01 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:83: Serial protocol error: request timed out
Jul 2 16:34:01 wirenboard-AE3UHZCX authpriv.info CRON[29478]: pam_unix(cron:session): session opened for user root by (uid=0)
Jul 2 16:34:01 wirenboard-AE3UHZCX cron.info CRON[29482]: (root) CMD (/usr/share/wb-daemon-watchdogs/check_confed.sh 2>&1 | logger -t wb-daemon-watchdogs)
Jul 2 16:34:02 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 input(s) @ 121 of device modbus:83: Serial protocol error: request timed out
Jul 2 16:34:02 wirenboard-AE3UHZCX user.notice serial: device modbus:203 disconnected
Jul 2 16:34:03 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 holding(s) @ 8 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:34:03 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:82: Serial protocol error: request timed out
Jul 2 16:34:04 wirenboard-AE3UHZCX user.notice serial: device modbus:203 disconnected
Jul 2 16:34:05 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 holding(s) @ 8 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:34:05 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 input(s) @ 280 of device modbus:87: Serial protocol error: request timed out
Jul 2 16:34:05 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:83: Serial protocol error: request timed out
Jul 2 16:34:06 wirenboard-AE3UHZCX user.notice serial: device modbus:203 disconnected
Jul 2 16:34:06 wirenboard-AE3UHZCX authpriv.info CRON[29478]: pam_unix(cron:session): session closed for user root
Jul 2 16:34:06 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:87: Serial protocol error: request timed out
Jul 2 16:34:07 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:82: Serial protocol error: request timed out
Jul 2 16:34:08 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 holding(s) @ 8 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:34:08 wirenboard-AE3UHZCX user.notice serial: device modbus:203 disconnected
Jul 2 16:34:10 wirenboard-AE3UHZCX user.notice serial: device modbus:203 disconnected
Jul 2 16:34:11 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:83: Serial protocol error: request timed out
Jul 2 16:34:11 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 holding(s) @ 8 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:34:12 wirenboard-AE3UHZCX user.notice serial: device modbus:203 disconnected
Jul 2 16:34:12 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 holding(s) @ 8 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:34:13 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:83: Serial protocol error: request timed out
Jul 2 16:34:14 wirenboard-AE3UHZCX user.notice serial: device modbus:203 disconnected
Jul 2 16:34:15 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 holding(s) @ 8 of device modbus:203: Serial protocol error: request timed out
Ну так неподключенные устройства надо отключить, программно. Удалять не надо просто выключить.
очистил лог
подключил порт 3
убедился что зависло
отключил снова
сохранил логи
Часть1
Jul 2 16:36:57 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 holding(s) @ 8 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:36:57 wirenboard-AE3UHZCX user.notice serial: device modbus:203 disconnected
Jul 2 16:36:58 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 holding(s) @ 8 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:36:59 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:83: Serial protocol error: request timed out
Jul 2 16:36:59 wirenboard-AE3UHZCX user.notice serial: device modbus:203 disconnected
Jul 2 16:37:00 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 holding(s) @ 8 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:37:01 wirenboard-AE3UHZCX authpriv.info CRON[29711]: pam_unix(cron:session): session opened for user root by (uid=0)
Jul 2 16:37:01 wirenboard-AE3UHZCX cron.info CRON[29715]: (root) CMD (/usr/share/wb-daemon-watchdogs/check_confed.sh 2>&1 | logger -t wb-daemon-watchdogs)
Jul 2 16:37:01 wirenboard-AE3UHZCX user.notice serial: device modbus:203 disconnected
Jul 2 16:37:02 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:86: Serial protocol error: request timed out
Jul 2 16:37:02 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 holding(s) @ 8 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:37:03 wirenboard-AE3UHZCX user.notice serial: device modbus:203 disconnected
Jul 2 16:37:05 wirenboard-AE3UHZCX authpriv.info CRON[29711]: pam_unix(cron:session): session closed for user root
Jul 2 16:37:05 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 holding(s) @ 8 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:37:05 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:83: Serial protocol error: request timed out
Jul 2 16:37:05 wirenboard-AE3UHZCX user.notice serial: device modbus:203 disconnected
Jul 2 16:37:06 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 holding(s) @ 8 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:37:07 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:83: Serial protocol error: request timed out
Jul 2 16:37:07 wirenboard-AE3UHZCX user.notice serial: device modbus:203 disconnected
Jul 2 16:37:09 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:86: Serial protocol error: request timed out
Jul 2 16:37:09 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 holding(s) @ 8 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:37:09 wirenboard-AE3UHZCX user.notice wb-mqtt-db[665]: 2020-07-02 16:37:09.312 NOTICE: Bulk processing took 213ms
Jul 2 16:37:09 wirenboard-AE3UHZCX user.notice serial: device modbus:203 disconnected
Jul 2 16:37:10 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:84: Serial protocol error: request timed out
Jul 2 16:37:11 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 holding(s) @ 8 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:37:11 wirenboard-AE3UHZCX user.notice serial: device modbus:203 disconnected
Jul 2 16:37:12 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:87: Serial protocol error: request timed out
Jul 2 16:37:13 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 holding(s) @ 8 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:37:13 wirenboard-AE3UHZCX user.notice serial: device modbus:203 disconnected
Jul 2 16:37:13 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:83: Serial protocol error: request timed out
Jul 2 16:37:14 wirenboard-AE3UHZCX user.notice serial: address: 0
Jul 2 16:37:15 wirenboard-AE3UHZCX user.notice serial: address: 1
Jul 2 16:37:15 wirenboard-AE3UHZCX user.notice serial: address: 2
Jul 2 16:37:15 wirenboard-AE3UHZCX user.notice serial: address: 3
Jul 2 16:37:15 wirenboard-AE3UHZCX user.notice serial: address: 4
Jul 2 16:37:15 wirenboard-AE3UHZCX user.notice serial: address: 5
Jul 2 16:37:15 wirenboard-AE3UHZCX user.notice serial: address: 8
Jul 2 16:37:15 wirenboard-AE3UHZCX user.notice serial: address: 0
Jul 2 16:37:15 wirenboard-AE3UHZCX user.notice serial: address: 7
Jul 2 16:37:15 wirenboard-AE3UHZCX user.notice serial: address: 32
Jul 2 16:37:15 wirenboard-AE3UHZCX user.notice serial: address: 33
Jul 2 16:37:15 wirenboard-AE3UHZCX user.notice serial: address: 34
Jul 2 16:37:15 wirenboard-AE3UHZCX user.notice serial: address: 35
Jul 2 16:37:15 wirenboard-AE3UHZCX user.notice serial: address: 36
Jul 2 16:37:15 wirenboard-AE3UHZCX user.notice serial: address: 37
Jul 2 16:37:15 wirenboard-AE3UHZCX user.notice serial: address: 39
Jul 2 16:37:15 wirenboard-AE3UHZCX user.notice serial: address: 121
Jul 2 16:37:16 wirenboard-AE3UHZCX user.notice serial: address: 32
Jul 2 16:37:16 wirenboard-AE3UHZCX user.notice serial: address: 33
Jul 2 16:37:16 wirenboard-AE3UHZCX user.notice serial: address: 34
Jul 2 16:37:16 wirenboard-AE3UHZCX user.notice serial: address: 35
Jul 2 16:37:16 wirenboard-AE3UHZCX user.notice serial: address: 36
Jul 2 16:37:16 wirenboard-AE3UHZCX user.notice serial: address: 37
Jul 2 16:37:16 wirenboard-AE3UHZCX user.notice serial: address: 39
Jul 2 16:37:16 wirenboard-AE3UHZCX user.notice serial: address: 121
Jul 2 16:37:16 wirenboard-AE3UHZCX user.notice serial: address: 0
Jul 2 16:37:16 wirenboard-AE3UHZCX user.notice serial: address: 2
Jul 2 16:37:16 wirenboard-AE3UHZCX user.notice serial: address: 4
Jul 2 16:37:16 wirenboard-AE3UHZCX user.notice serial: address: 5
Jul 2 16:37:16 wirenboard-AE3UHZCX user.notice serial: address: 8
Jul 2 16:37:16 wirenboard-AE3UHZCX user.notice serial: address: 7
Jul 2 16:37:16 wirenboard-AE3UHZCX user.notice serial: address: 270
Jul 2 16:37:16 wirenboard-AE3UHZCX user.notice serial: address: 11
Jul 2 16:37:16 wirenboard-AE3UHZCX user.notice serial: address: 9
Jul 2 16:37:16 wirenboard-AE3UHZCX user.notice serial: address: 280
Jul 2 16:37:16 wirenboard-AE3UHZCX user.notice serial: address: 283
Jul 2 16:37:16 wirenboard-AE3UHZCX user.notice serial: address: 10
Jul 2 16:37:16 wirenboard-AE3UHZCX user.notice serial: address: 97
Jul 2 16:37:16 wirenboard-AE3UHZCX user.notice serial: address: 98
Jul 2 16:37:16 wirenboard-AE3UHZCX user.notice serial: address: 5001
Jul 2 16:37:16 wirenboard-AE3UHZCX user.notice serial: address: 5002
Jul 2 16:37:16 wirenboard-AE3UHZCX user.notice serial: address: 5300
Jul 2 16:37:16 wirenboard-AE3UHZCX user.notice serial: address: 5301
Jul 2 16:37:16 wirenboard-AE3UHZCX user.notice serial: address: 5302
Jul 2 16:37:16 wirenboard-AE3UHZCX user.notice serial: address: 5303
Jul 2 16:37:16 wirenboard-AE3UHZCX user.notice serial: address: 5304
Jul 2 16:37:16 wirenboard-AE3UHZCX user.notice serial: address: 5305
Jul 2 16:37:16 wirenboard-AE3UHZCX user.notice serial: address: 5306
Jul 2 16:37:16 wirenboard-AE3UHZCX user.notice serial: address: 5100
Jul 2 16:37:16 wirenboard-AE3UHZCX user.notice serial: address: 5101
Jul 2 16:37:16 wirenboard-AE3UHZCX user.notice serial: address: 5102
Jul 2 16:37:16 wirenboard-AE3UHZCX user.notice serial: address: 5103
Jul 2 16:37:16 wirenboard-AE3UHZCX user.notice serial: address: 5104
Jul 2 16:37:16 wirenboard-AE3UHZCX user.notice serial: address: 5105
Jul 2 16:37:16 wirenboard-AE3UHZCX user.notice serial: address: 5106
Jul 2 16:37:16 wirenboard-AE3UHZCX user.notice serial: address: 5000
Часть2
Jul 2 16:37:16 wirenboard-AE3UHZCX user.notice serial: Init: Ширина временного окна: setup register <modbus:80:: 282> <-- 0
Jul 2 16:37:16 wirenboard-AE3UHZCX user.notice serial: Init: Ширина временного окна: setup register <modbus:82:: 282> <-- 0
Jul 2 16:37:16 wirenboard-AE3UHZCX user.notice serial: Init: Ширина временного окна: setup register <modbus:83:: 282> <-- 0
Jul 2 16:37:16 wirenboard-AE3UHZCX user.notice serial: Init: Ширина временного окна: setup register <modbus:84:: 282> <-- 0
Jul 2 16:37:16 wirenboard-AE3UHZCX user.notice serial: Init: Ширина временного окна: setup register <modbus:86:: 282> <-- 0
Jul 2 16:37:16 wirenboard-AE3UHZCX user.notice serial: Init: Ширина временного окна: setup register <modbus:87:: 282> <-- 0
Jul 2 16:37:16 wirenboard-AE3UHZCX user.notice serial: FATAL: Serial protocol error: cannot open serial port
Jul 2 16:37:31 wirenboard-AE3UHZCX user.notice serial: address: 0
Jul 2 16:37:33 wirenboard-AE3UHZCX user.notice serial: address: 1
Jul 2 16:37:33 wirenboard-AE3UHZCX user.notice serial: address: 2
Jul 2 16:37:33 wirenboard-AE3UHZCX user.notice serial: address: 3
Jul 2 16:37:33 wirenboard-AE3UHZCX user.notice serial: address: 4
Jul 2 16:37:33 wirenboard-AE3UHZCX user.notice serial: address: 5
Jul 2 16:37:33 wirenboard-AE3UHZCX user.notice serial: address: 8
Jul 2 16:37:33 wirenboard-AE3UHZCX user.notice serial: address: 0
Jul 2 16:37:33 wirenboard-AE3UHZCX user.notice serial: address: 7
Jul 2 16:37:33 wirenboard-AE3UHZCX user.notice serial: address: 32
Jul 2 16:37:33 wirenboard-AE3UHZCX user.notice serial: address: 33
Jul 2 16:37:33 wirenboard-AE3UHZCX user.notice serial: address: 34
Jul 2 16:37:33 wirenboard-AE3UHZCX user.notice serial: address: 35
Jul 2 16:37:33 wirenboard-AE3UHZCX user.notice serial: address: 36
Jul 2 16:37:33 wirenboard-AE3UHZCX user.notice serial: address: 37
Jul 2 16:37:33 wirenboard-AE3UHZCX user.notice serial: address: 39
Jul 2 16:37:33 wirenboard-AE3UHZCX user.notice serial: address: 121
Jul 2 16:37:33 wirenboard-AE3UHZCX user.notice serial: address: 270
Jul 2 16:37:33 wirenboard-AE3UHZCX user.notice serial: address: 11
Jul 2 16:37:33 wirenboard-AE3UHZCX user.notice serial: address: 9
Jul 2 16:37:33 wirenboard-AE3UHZCX user.notice serial: address: 280
Jul 2 16:37:33 wirenboard-AE3UHZCX user.notice serial: address: 283
Jul 2 16:37:33 wirenboard-AE3UHZCX user.notice serial: address: 10
Jul 2 16:37:33 wirenboard-AE3UHZCX user.notice serial: address: 97
Jul 2 16:37:33 wirenboard-AE3UHZCX user.notice serial: address: 98
Jul 2 16:37:33 wirenboard-AE3UHZCX user.notice serial: address: 5001
Jul 2 16:37:33 wirenboard-AE3UHZCX user.notice serial: address: 5002
Jul 2 16:37:33 wirenboard-AE3UHZCX user.notice serial: address: 5300
Jul 2 16:37:33 wirenboard-AE3UHZCX user.notice serial: address: 5301
Jul 2 16:37:33 wirenboard-AE3UHZCX user.notice serial: address: 5302
Jul 2 16:37:33 wirenboard-AE3UHZCX user.notice serial: address: 5303
Jul 2 16:37:33 wirenboard-AE3UHZCX user.notice serial: address: 5304
Jul 2 16:37:33 wirenboard-AE3UHZCX user.notice serial: address: 5305
Jul 2 16:37:33 wirenboard-AE3UHZCX user.notice serial: address: 5306
Jul 2 16:37:33 wirenboard-AE3UHZCX user.notice serial: address: 5100
Jul 2 16:37:33 wirenboard-AE3UHZCX user.notice serial: address: 5101
Jul 2 16:37:33 wirenboard-AE3UHZCX user.notice serial: address: 5102
Jul 2 16:37:33 wirenboard-AE3UHZCX user.notice serial: address: 5103
Jul 2 16:37:33 wirenboard-AE3UHZCX user.notice serial: address: 5104
Jul 2 16:37:33 wirenboard-AE3UHZCX user.notice serial: address: 5105
Jul 2 16:37:33 wirenboard-AE3UHZCX user.notice serial: address: 5106
Jul 2 16:37:33 wirenboard-AE3UHZCX user.notice serial: address: 5000
Часть3
Jul 2 16:37:33 wirenboard-AE3UHZCX user.notice serial: Init: Ширина временного окна: setup register <modbus:80:: 282> <-- 0
Jul 2 16:37:33 wirenboard-AE3UHZCX user.notice serial: Init: Ширина временного окна: setup register <modbus:82:: 282> <-- 0
Jul 2 16:37:33 wirenboard-AE3UHZCX user.notice serial: Init: Ширина временного окна: setup register <modbus:83:: 282> <-- 0
Jul 2 16:37:33 wirenboard-AE3UHZCX user.notice serial: Init: Ширина временного окна: setup register <modbus:84:: 282> <-- 0
Jul 2 16:37:33 wirenboard-AE3UHZCX user.notice serial: Init: Ширина временного окна: setup register <modbus:86:: 282> <-- 0
Jul 2 16:37:33 wirenboard-AE3UHZCX user.notice serial: Init: Ширина временного окна: setup register <modbus:87:: 282> <-- 0
Jul 2 16:37:33 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 holding(s) @ 8 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:37:34 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 6 input(s) @ 32 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:37:34 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 input(s) @ 39 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:37:34 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 input(s) @ 121 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:37:34 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 6 coil(s) @ 0 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:37:34 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 6 discrete(s) @ 0 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:37:34 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 discrete(s) @ 7 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:37:36 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:84: Serial protocol error: request timed out
Jul 2 16:37:37 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:83: Serial protocol error: request timed out
Jul 2 16:37:37 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 holding(s) @ 8 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:37:37 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 6 input(s) @ 32 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:37:38 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 input(s) @ 39 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:37:38 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 input(s) @ 121 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:37:38 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 6 coil(s) @ 0 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:37:38 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 6 discrete(s) @ 0 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:37:38 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 discrete(s) @ 7 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:37:38 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:84: Serial protocol error: request timed out
Jul 2 16:37:39 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:87: Serial protocol error: request timed out
Jul 2 16:37:40 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 holding(s) @ 8 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:37:40 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:86: Serial protocol error: request timed out
Jul 2 16:37:40 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 6 input(s) @ 32 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:37:40 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 input(s) @ 39 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:37:40 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 input(s) @ 121 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:37:40 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 6 coil(s) @ 0 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:37:40 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 6 discrete(s) @ 0 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:37:40 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 discrete(s) @ 7 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:37:40 wirenboard-AE3UHZCX user.notice serial: device modbus:203 disconnected
Jul 2 16:37:42 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 holding(s) @ 8 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:37:42 wirenboard-AE3UHZCX user.notice serial: device modbus:203 disconnected
Jul 2 16:37:42 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:83: Serial protocol error: request timed out
Jul 2 16:37:42 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:87: Serial protocol error: request timed out
Jul 2 16:37:43 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:86: Serial protocol error: request timed out
Jul 2 16:37:43 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 holding(s) @ 8 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:37:44 wirenboard-AE3UHZCX user.notice serial: device modbus:203 disconnected
Jul 2 16:37:44 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 holding(s) @ 8 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:37:46 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:87: Serial protocol error: request timed out
Jul 2 16:37:46 wirenboard-AE3UHZCX user.notice serial: device modbus:203 disconnected
Jul 2 16:37:46 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 holding(s) @ 8 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:37:46 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:84: Serial protocol error: request timed out
Jul 2 16:37:47 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:82: Serial protocol error: request timed out
Jul 2 16:37:48 wirenboard-AE3UHZCX user.notice serial: device modbus:203 disconnected
Jul 2 16:37:48 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:87: Serial protocol error: request timed out
Jul 2 16:37:50 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 holding(s) @ 8 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:37:50 wirenboard-AE3UHZCX user.notice serial: device modbus:203 disconnected
Jul 2 16:37:51 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:84: Serial protocol error: request timed out
Jul 2 16:37:51 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 holding(s) @ 8 of device modbus:203: Serial protocol error: request timed out
Jul 2 16:37:51 wirenboard-AE3UHZCX user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 2 input(s) @ 0 of device modbus:80: Serial protocol error: request timed out
А устройства 84,87 и 203 и остальные, которые НЕ могут опроситься - не забыли отключить?
Исключить из опроса.
84 и 87 постоянно в работе
иногда самопроизвольно свет загорается хотя там никого нет.
203 кстати еще не подключил к порту1
он у меня стал инвалидом после того как я я его вставил вместо HV.
был хлопок и дымок, но как не странно по rs485 все работает, сдох вход на котором оказался 220в.
Я сделал фото платы и там повредились несколько деталей. Есть ли возможность о фото мне сообщить их названия я их перепаяю?
По ним же постоянные ошибки, таймауты.
Надо избавиться от ошибок для уже подключенных - а потом подключать новые.
