Контроллер подключен по проводу. WiFi для резерва использую. Всё было хорошо, но после возможно обновления WiFI перестал цепляться.
В логах пишет ошибку:
association request to the driver failed
Покажите состояние сети (интерфейсов), статус hostapd, логи.
> eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
> inet 10.115.0.101 netmask 255.255.255.0 broadcast 10.115.0.255
> inet6 fe80::6a27:19ff:fe81:61b prefixlen 64 scopeid 0x20<link>
> ether 68:27:19:81:06:1b txqueuelen 1000 (Ethernet)
> RX packets 43956124 bytes 3759101548 (3.5 GiB)
> RX errors 0 dropped 0 overruns 0 frame 0
> TX packets 37449946 bytes 1761061331 (1.6 GiB)
> TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
> eth1: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
> ether 68:27:19:80:ec:26 txqueuelen 1000 (Ethernet)
> RX packets 0 bytes 0 (0.0 B)
> TX packets 0 bytes 0 (0.0 B)
> lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
> inet 127.0.0.1 netmask 255.0.0.0
> inet6 ::1 prefixlen 128 scopeid 0x10<host>
> loop txqueuelen 1000 (Local Loopback)
> RX packets 1060569278 bytes 79527337040 (74.0 GiB)
> TX packets 1060569278 bytes 79527337040 (74.0 GiB)
> wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
> inet6 fe80::d6d2:d6ff:fee5:42ff prefixlen 64 scopeid 0x20<link>
> ether d4:d2:d6:e5:42:ff txqueuelen 1000 (Ethernet)
> RX packets 544461 bytes 0 (0.0 B)
> RX errors 0 dropped 95 overruns 0 frame 0
> TX packets 1 bytes 104 (104.0 B)
> wlan1: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
> ether d6:d2:d6:e5:42:ff txqueuelen 1000 (Ethernet)
> RX packets 2139 bytes 229338 (223.9 KiB)
> RX errors 0 dropped 544239 overruns 0 frame 0
> TX packets 2569 bytes 2092742 (1.9 MiB)
> TX errors 0 dropped 2 overruns 0 carrier 0 collisions 0
● hostapd.service - LSB: Advanced IEEE 802.11 management daemon
Loaded: loaded (/etc/init.d/hostapd; generated; vendor preset: enabled)
Active: active (running) since Wed 2021-12-29 04:46:36 UTC; 1 months 2 days ago
Docs: man:systemd-sysv-generator(8)
CGroup: /system.slice/hostapd.service
└─1292 /usr/sbin/hostapd -B -P /run/hostapd.pid /etc/hostapd.confWarning: Journal has been rotated since unit was started. Log output is incomplete or unavailable.
Логи какие именно?
/var/log/messages?
И у меня проблемы с WiFi в качестве клиента, а не точки доступа. Я не могу подключиться к своей WiFi сети.
Для использования wlan0 в качестве клиента - -надо отключить и остановить hostapd. А тут вижу - запущено.
У меня wlan1 как клиент используется.
Делал по инструкции Wi-Fi — Wiren Board
А “вручную” по той же инструкции - подключается?
Вручную не пробовал.
