Проблемы после обновления на WB-2606
root@wirenboard-AUIX2ZRY:~# journalctl -u wb-mqtt-serial --since “96 hour ago” --no-pager |grep “override property”
Jun 02 19:29:07 wirenboard-AUIX2ZRY wb-mqtt-serial[452399]: INFO: [serial config] WB-MWAC-v2 25 override property “id”
Jun 02 19:29:08 wirenboard-AUIX2ZRY wb-mqtt-serial[452399]: INFO: [serial config] WB-LED 39 override property “id”
Jun 02 19:29:08 wirenboard-AUIX2ZRY wb-mqtt-serial[452399]: INFO: [serial config] WB-MSW v.4 64 override property “id”
Jun 02 19:29:08 wirenboard-AUIX2ZRY wb-mqtt-serial[452399]: INFO: [serial config] WB-MIR v.3 133 override property “id”
Jun 02 19:29:08 wirenboard-AUIX2ZRY wb-mqtt-serial[452399]: INFO: [serial config] WB-M1W2 30 override property “id”
Jun 02 19:29:08 wirenboard-AUIX2ZRY wb-mqtt-serial[452399]: INFO: [serial config] WB-MR6C 46 override property “id”
Jun 02 19:29:08 wirenboard-AUIX2ZRY wb-mqtt-serial[452399]: INFO: [serial config] WB-MAP12E fw2 35 override property “id”
Jun 02 19:29:08 wirenboard-AUIX2ZRY wb-mqtt-serial[452399]: INFO: [serial config] WB-MDM3 57 override property “id”
Jun 02 19:29:08 wirenboard-AUIX2ZRY wb-mqtt-serial[452399]: INFO: [serial config] Energomera CE102 1 override property “id”
Jun 02 19:37:20 wirenboard-AUIX2ZRY wb-mqtt-serial[1756]: INFO: [serial config] WB-MWAC-v2 25 override property “id”
Jun 02 19:37:20 wirenboard-AUIX2ZRY wb-mqtt-serial[1756]: INFO: [serial config] WB-LED 39 override property “id”
Jun 02 19:37:20 wirenboard-AUIX2ZRY wb-mqtt-serial[1756]: INFO: [serial config] WB-MSW v.4 64 override property “id”
Jun 02 19:37:20 wirenboard-AUIX2ZRY wb-mqtt-serial[1756]: INFO: [serial config] WB-MIR v.3 133 override property “id”
Jun 02 19:37:20 wirenboard-AUIX2ZRY wb-mqtt-serial[1756]: INFO: [serial config] WB-M1W2 30 override property “id”
Jun 02 19:37:20 wirenboard-AUIX2ZRY wb-mqtt-serial[1756]: INFO: [serial config] WB-MR6C 46 override property “id”
Jun 02 19:37:20 wirenboard-AUIX2ZRY wb-mqtt-serial[1756]: INFO: [serial config] WB-MAP12E fw2 35 override property “id”
Jun 02 19:37:20 wirenboard-AUIX2ZRY wb-mqtt-serial[1756]: INFO: [serial config] WB-MDM3 57 override property “id”
Jun 02 19:37:20 wirenboard-AUIX2ZRY wb-mqtt-serial[1756]: INFO: [serial config] Energomera CE102 1 override property “id”
Jun 02 20:30:44 wirenboard-AUIX2ZRY wb-mqtt-serial[38111]: INFO: [serial config] WB-MWAC-v2 25 override property “id”
Jun 02 20:30:44 wirenboard-AUIX2ZRY wb-mqtt-serial[38111]: INFO: [serial config] WB-LED 39 override property “id”
Jun 02 20:30:44 wirenboard-AUIX2ZRY wb-mqtt-serial[38111]: INFO: [serial config] WB-MSW v.4 64 override property “id”
Jun 02 20:30:44 wirenboard-AUIX2ZRY wb-mqtt-serial[38111]: INFO: [serial config] WB-MIR v.3 133 override property “id”
Jun 02 20:30:44 wirenboard-AUIX2ZRY wb-mqtt-serial[38111]: INFO: [serial config] WB-M1W2 30 override property “id”
Jun 02 20:30:44 wirenboard-AUIX2ZRY wb-mqtt-serial[38111]: INFO: [serial config] WB-MR6C 46 override property “id”
Jun 02 20:30:44 wirenboard-AUIX2ZRY wb-mqtt-serial[38111]: INFO: [serial config] WB-MAP12E fw2 35 override property “id”
Jun 02 20:30:44 wirenboard-AUIX2ZRY wb-mqtt-serial[38111]: INFO: [serial config] WB-MDM3 57 override property “id”
Jun 02 20:30:44 wirenboard-AUIX2ZRY wb-mqtt-serial[38111]: INFO: [serial config] Energomera CE102 1 override property “id”
Jun 02 20:34:43 wirenboard-AUIX2ZRY wb-mqtt-serial[1724]: INFO: [serial config] WB-MWAC-v2 25 override property “id”
Jun 02 20:34:43 wirenboard-AUIX2ZRY wb-mqtt-serial[1724]: INFO: [serial config] WB-LED 39 override property “id”
Jun 02 20:34:43 wirenboard-AUIX2ZRY wb-mqtt-serial[1724]: INFO: [serial config] WB-MSW v.4 64 override property “id”
Jun 02 20:34:43 wirenboard-AUIX2ZRY wb-mqtt-serial[1724]: INFO: [serial config] WB-MIR v.3 133 override property “id”
Jun 02 20:34:43 wirenboard-AUIX2ZRY wb-mqtt-serial[1724]: INFO: [serial config] WB-M1W2 30 override property “id”
Jun 02 20:34:43 wirenboard-AUIX2ZRY wb-mqtt-serial[1724]: INFO: [serial config] WB-MR6C 46 override property “id”
Jun 02 20:34:43 wirenboard-AUIX2ZRY wb-mqtt-serial[1724]: INFO: [serial config] WB-MAP12E fw2 35 override property “id”
Jun 02 20:34:43 wirenboard-AUIX2ZRY wb-mqtt-serial[1724]: INFO: [serial config] WB-MDM3 57 override property “id”
Jun 02 20:34:43 wirenboard-AUIX2ZRY wb-mqtt-serial[1724]: INFO: [serial config] Energomera CE102 1 override property “id”
Jun 02 20:44:00 wirenboard-AUIX2ZRY wb-mqtt-serial[1712]: INFO: [serial config] WB-MWAC-v2 25 override property “id”
Jun 02 20:44:00 wirenboard-AUIX2ZRY wb-mqtt-serial[1712]: INFO: [serial config] WB-LED 39 override property “id”
Jun 02 20:44:00 wirenboard-AUIX2ZRY wb-mqtt-serial[1712]: INFO: [serial config] WB-MSW v.4 64 override property “id”
Jun 02 20:44:00 wirenboard-AUIX2ZRY wb-mqtt-serial[1712]: INFO: [serial config] WB-MIR v.3 133 override property “id”
Jun 02 20:44:00 wirenboard-AUIX2ZRY wb-mqtt-serial[1712]: INFO: [serial config] WB-M1W2 30 override property “id”
Jun 02 20:44:00 wirenboard-AUIX2ZRY wb-mqtt-serial[1712]: INFO: [serial config] WB-MR6C 46 override property “id”
Jun 02 20:44:01 wirenboard-AUIX2ZRY wb-mqtt-serial[1712]: INFO: [serial config] WB-MAP12E fw2 35 override property “id”
Jun 02 20:44:01 wirenboard-AUIX2ZRY wb-mqtt-serial[1712]: INFO: [serial config] WB-MDM3 57 override property “id”
Jun 02 20:44:01 wirenboard-AUIX2ZRY wb-mqtt-serial[1712]: INFO: [serial config] Energomera CE102 1 override property “id”
Jun 02 20:49:33 wirenboard-AUIX2ZRY wb-mqtt-serial[9446]: INFO: [serial config] WB-MWAC-v2 25 override property “id”
Jun 02 20:49:33 wirenboard-AUIX2ZRY wb-mqtt-serial[9446]: INFO: [serial config] WB-LED 39 override property “id”
Jun 02 20:49:33 wirenboard-AUIX2ZRY wb-mqtt-serial[9446]: INFO: [serial config] WB-MSW v.4 64 override property “id”
Jun 02 20:49:33 wirenboard-AUIX2ZRY wb-mqtt-serial[9446]: INFO: [serial config] WB-MIR v.3 133 override property “id”
Jun 02 20:49:33 wirenboard-AUIX2ZRY wb-mqtt-serial[9446]: INFO: [serial config] WB-M1W2 30 override property “id”
Jun 02 20:49:33 wirenboard-AUIX2ZRY wb-mqtt-serial[9446]: INFO: [serial config] WB-MR6C 46 override property “id”
Jun 02 20:49:33 wirenboard-AUIX2ZRY wb-mqtt-serial[9446]: INFO: [serial config] WB-MDM3 57 override property “id”
Jun 02 20:49:33 wirenboard-AUIX2ZRY wb-mqtt-serial[9446]: INFO: [serial config] Energomera CE102 1 override property “id”
Jun 02 20:50:11 wirenboard-AUIX2ZRY wb-mqtt-serial[9851]: INFO: [serial config] WB-MWAC-v2 25 override property “id”
Jun 02 20:50:11 wirenboard-AUIX2ZRY wb-mqtt-serial[9851]: INFO: [serial config] WB-LED 39 override property “id”
Jun 02 20:50:11 wirenboard-AUIX2ZRY wb-mqtt-serial[9851]: INFO: [serial config] WB-MSW v.4 64 override property “id”
Jun 02 20:50:11 wirenboard-AUIX2ZRY wb-mqtt-serial[9851]: INFO: [serial config] WB-MIR v.3 133 override property “id”
Jun 02 20:50:11 wirenboard-AUIX2ZRY wb-mqtt-serial[9851]: INFO: [serial config] WB-M1W2 30 override property “id”
Jun 02 20:50:11 wirenboard-AUIX2ZRY wb-mqtt-serial[9851]: INFO: [serial config] WB-MR6C 46 override property “id”
Jun 02 20:50:11 wirenboard-AUIX2ZRY wb-mqtt-serial[9851]: INFO: [serial config] WB-MDM3 57 override property “id”
Jun 02 20:50:11 wirenboard-AUIX2ZRY wb-mqtt-serial[9851]: INFO: [serial config] Energomera CE102 1 override property “id”
Jun 02 20:55:06 wirenboard-AUIX2ZRY wb-mqtt-serial[12872]: INFO: [serial config] WB-MWAC-v2 25 override property “id”
Jun 02 20:55:06 wirenboard-AUIX2ZRY wb-mqtt-serial[12872]: INFO: [serial config] WB-LED 39 override property “id”
Jun 02 20:55:06 wirenboard-AUIX2ZRY wb-mqtt-serial[12872]: INFO: [serial config] WB-MSW v.4 64 override property “id”
Jun 02 20:55:06 wirenboard-AUIX2ZRY wb-mqtt-serial[12872]: INFO: [serial config] WB-MIR v.3 133 override property “id”
Jun 02 20:55:06 wirenboard-AUIX2ZRY wb-mqtt-serial[12872]: INFO: [serial config] WB-M1W2 30 override property “id”
Jun 02 20:55:06 wirenboard-AUIX2ZRY wb-mqtt-serial[12872]: INFO: [serial config] WB-MR6C 46 override property “id”
Jun 02 20:55:06 wirenboard-AUIX2ZRY wb-mqtt-serial[12872]: INFO: [serial config] WB-MDM3 57 override property “id”
Jun 02 20:55:06 wirenboard-AUIX2ZRY wb-mqtt-serial[12872]: INFO: [serial config] Energomera CE102 1 override property “id”
Jun 02 21:01:27 wirenboard-AUIX2ZRY wb-mqtt-serial[1735]: INFO: [serial config] WB-MWAC-v2 25 override property “id”
Jun 02 21:01:27 wirenboard-AUIX2ZRY wb-mqtt-serial[1735]: INFO: [serial config] WB-LED 39 override property “id”
Jun 02 21:01:27 wirenboard-AUIX2ZRY wb-mqtt-serial[1735]: INFO: [serial config] WB-MSW v.4 64 override property “id”
Jun 02 21:01:27 wirenboard-AUIX2ZRY wb-mqtt-serial[1735]: INFO: [serial config] WB-MIR v.3 133 override property “id”
Jun 02 21:01:27 wirenboard-AUIX2ZRY wb-mqtt-serial[1735]: INFO: [serial config] WB-M1W2 30 override property “id”
Jun 02 21:01:27 wirenboard-AUIX2ZRY wb-mqtt-serial[1735]: INFO: [serial config] WB-MR6C 46 override property “id”
Jun 02 21:01:27 wirenboard-AUIX2ZRY wb-mqtt-serial[1735]: INFO: [serial config] WB-MDM3 57 override property “id”
Jun 02 21:01:27 wirenboard-AUIX2ZRY wb-mqtt-serial[1735]: INFO: [serial config] Energomera CE102 1 override property “id”
Jun 02 21:07:00 wirenboard-AUIX2ZRY wb-mqtt-serial[9423]: INFO: [serial config] WB-MWAC-v2 25 override property “id”
Jun 02 21:07:00 wirenboard-AUIX2ZRY wb-mqtt-serial[9423]: INFO: [serial config] WB-LED 39 override property “id”
Jun 02 21:07:00 wirenboard-AUIX2ZRY wb-mqtt-serial[9423]: INFO: [serial config] WB-MSW v.4 64 override property “id”
Jun 02 21:07:00 wirenboard-AUIX2ZRY wb-mqtt-serial[9423]: INFO: [serial config] WB-MIR v.3 133 override property “id”
Jun 02 21:07:00 wirenboard-AUIX2ZRY wb-mqtt-serial[9423]: INFO: [serial config] WB-M1W2 30 override property “id”
Jun 02 21:07:00 wirenboard-AUIX2ZRY wb-mqtt-serial[9423]: INFO: [serial config] WB-MR6C 46 override property “id”
Jun 02 21:07:00 wirenboard-AUIX2ZRY wb-mqtt-serial[9423]: INFO: [serial config] WB-MDM3 57 override property “id”
Jun 02 21:07:00 wirenboard-AUIX2ZRY wb-mqtt-serial[9423]: INFO: [serial config] Energomera CE102 1 override property “id”
Jun 02 21:09:37 wirenboard-AUIX2ZRY wb-mqtt-serial[10959]: INFO: [serial config] WB-MWAC-v2 25 override property “id”
Jun 02 21:09:37 wirenboard-AUIX2ZRY wb-mqtt-serial[10959]: INFO: [serial config] WB-LED 39 override property “id”
Jun 02 21:09:37 wirenboard-AUIX2ZRY wb-mqtt-serial[10959]: INFO: [serial config] WB-MSW v.4 64 override property “id”
Jun 02 21:09:37 wirenboard-AUIX2ZRY wb-mqtt-serial[10959]: INFO: [serial config] WB-MIR v.3 133 override property “id”
Jun 02 21:09:37 wirenboard-AUIX2ZRY wb-mqtt-serial[10959]: INFO: [serial config] WB-M1W2 30 override property “id”
Jun 02 21:09:37 wirenboard-AUIX2ZRY wb-mqtt-serial[10959]: INFO: [serial config] WB-MR6C 46 override property “id”
Jun 02 21:09:37 wirenboard-AUIX2ZRY wb-mqtt-serial[10959]: INFO: [serial config] WB-MDM3 57 override property “id”
Jun 02 21:09:37 wirenboard-AUIX2ZRY wb-mqtt-serial[10959]: INFO: [serial config] Energomera CE102 1 override property “id”
Jun 02 21:11:31 wirenboard-AUIX2ZRY wb-mqtt-serial[12096]: INFO: [serial config] WB-MWAC-v2 25 override property “id”
Jun 02 21:11:32 wirenboard-AUIX2ZRY wb-mqtt-serial[12096]: INFO: [serial config] WB-LED 39 override property “id”
Jun 02 21:11:32 wirenboard-AUIX2ZRY wb-mqtt-serial[12096]: INFO: [serial config] WB-MSW v.4 64 override property “id”
Jun 02 21:11:32 wirenboard-AUIX2ZRY wb-mqtt-serial[12096]: INFO: [serial config] WB-MIR v.3 133 override property “id”
Jun 02 21:11:32 wirenboard-AUIX2ZRY wb-mqtt-serial[12096]: INFO: [serial config] WB-M1W2 30 override property “id”
Jun 02 21:11:32 wirenboard-AUIX2ZRY wb-mqtt-serial[12096]: INFO: [serial config] WB-MR6C 46 override property “id”
Jun 02 21:11:32 wirenboard-AUIX2ZRY wb-mqtt-serial[12096]: INFO: [serial config] WB-MDM3 57 override property “id”
Jun 02 21:11:32 wirenboard-AUIX2ZRY wb-mqtt-serial[12096]: INFO: [serial config] Energomera CE102 1 override property “id”
Jun 02 21:14:38 wirenboard-AUIX2ZRY wb-mqtt-serial[13948]: INFO: [serial config] WB-MWAC-v2 25 override property “id”
Jun 02 21:14:38 wirenboard-AUIX2ZRY wb-mqtt-serial[13948]: INFO: [serial config] WB-LED 39 override property “id”
Jun 02 21:14:38 wirenboard-AUIX2ZRY wb-mqtt-serial[13948]: INFO: [serial config] WB-MSW v.4 64 override property “id”
Jun 02 21:14:38 wirenboard-AUIX2ZRY wb-mqtt-serial[13948]: INFO: [serial config] WB-MIR v.3 133 override property “id”
Jun 02 21:14:38 wirenboard-AUIX2ZRY wb-mqtt-serial[13948]: INFO: [serial config] WB-M1W2 30 override property “id”
Jun 02 21:14:38 wirenboard-AUIX2ZRY wb-mqtt-serial[13948]: INFO: [serial config] WB-MR6C 46 override property “id”
Jun 02 21:14:38 wirenboard-AUIX2ZRY wb-mqtt-serial[13948]: INFO: [serial config] WB-MDM3 57 override property “id”
Jun 02 21:14:38 wirenboard-AUIX2ZRY wb-mqtt-serial[13948]: INFO: [serial config] Energomera CE102 1 override property “id”
Jun 02 21:21:09 wirenboard-AUIX2ZRY wb-mqtt-serial[17742]: INFO: [serial config] WB-MWAC-v2 25 override property “id”
Jun 02 21:21:09 wirenboard-AUIX2ZRY wb-mqtt-serial[17742]: INFO: [serial config] WB-LED 39 override property “id”
Jun 02 21:21:09 wirenboard-AUIX2ZRY wb-mqtt-serial[17742]: INFO: [serial config] WB-MIR v.3 133 override property “id”
Jun 02 21:21:09 wirenboard-AUIX2ZRY wb-mqtt-serial[17742]: INFO: [serial config] WB-M1W2 30 override property “id”
Jun 02 21:21:09 wirenboard-AUIX2ZRY wb-mqtt-serial[17742]: INFO: [serial config] WB-MR6C 46 override property “id”
Jun 02 21:21:09 wirenboard-AUIX2ZRY wb-mqtt-serial[17742]: INFO: [serial config] WB-MDM3 57 override property “id”
Jun 02 21:21:09 wirenboard-AUIX2ZRY wb-mqtt-serial[17742]: INFO: [serial config] Energomera CE102 1 override property “id”
Jun 02 21:22:33 wirenboard-AUIX2ZRY wb-mqtt-serial[18612]: INFO: [serial config] WB-MWAC-v2 25 override property “id”
Jun 02 21:22:33 wirenboard-AUIX2ZRY wb-mqtt-serial[18612]: INFO: [serial config] WB-LED 39 override property “id”
Jun 02 21:22:33 wirenboard-AUIX2ZRY wb-mqtt-serial[18612]: INFO: [serial config] WB-MIR v.3 133 override property “id”
Jun 02 21:22:33 wirenboard-AUIX2ZRY wb-mqtt-serial[18612]: INFO: [serial config] WB-M1W2 30 override property “id”
Jun 02 21:22:33 wirenboard-AUIX2ZRY wb-mqtt-serial[18612]: INFO: [serial config] WB-MR6C 46 override property “id”
Jun 02 21:22:33 wirenboard-AUIX2ZRY wb-mqtt-serial[18612]: INFO: [serial config] WB-MDM3 57 override property “id”
Jun 02 21:22:33 wirenboard-AUIX2ZRY wb-mqtt-serial[18612]: INFO: [serial config] Energomera CE102 1 override property “id”
Jun 02 22:00:58 wirenboard-AUIX2ZRY wb-mqtt-serial[1751]: INFO: [serial config] WB-MWAC-v2 25 override property “id”
Jun 02 22:00:58 wirenboard-AUIX2ZRY wb-mqtt-serial[1751]: INFO: [serial config] WB-LED 39 override property “id”
Jun 02 22:00:58 wirenboard-AUIX2ZRY wb-mqtt-serial[1751]: INFO: [serial config] WB-MIR v.3 133 override property “id”
Jun 02 22:00:58 wirenboard-AUIX2ZRY wb-mqtt-serial[1751]: INFO: [serial config] WB-M1W2 30 override property “id”
Jun 02 22:00:58 wirenboard-AUIX2ZRY wb-mqtt-serial[1751]: INFO: [serial config] WB-MR6C 46 override property “id”
Jun 02 22:00:58 wirenboard-AUIX2ZRY wb-mqtt-serial[1751]: INFO: [serial config] WB-MDM3 57 override property “id”
Jun 02 22:00:58 wirenboard-AUIX2ZRY wb-mqtt-serial[1751]: INFO: [serial config] Energomera CE102 1 override property “id”
Jun 02 22:20:28 wirenboard-AUIX2ZRY wb-mqtt-serial[1740]: INFO: [serial config] WB-MWAC-v2 25 override property “id”
Jun 02 22:20:28 wirenboard-AUIX2ZRY wb-mqtt-serial[1740]: INFO: [serial config] WB-LED 39 override property “id”
Jun 02 22:20:28 wirenboard-AUIX2ZRY wb-mqtt-serial[1740]: INFO: [serial config] WB-MIR v.3 133 override property “id”
Jun 02 22:20:28 wirenboard-AUIX2ZRY wb-mqtt-serial[1740]: INFO: [serial config] WB-M1W2 30 override property “id”
Jun 02 22:20:28 wirenboard-AUIX2ZRY wb-mqtt-serial[1740]: INFO: [serial config] WB-MR6C 46 override property “id”
Jun 02 22:20:28 wirenboard-AUIX2ZRY wb-mqtt-serial[1740]: INFO: [serial config] WB-MDM3 57 override property “id”
Jun 02 22:20:28 wirenboard-AUIX2ZRY wb-mqtt-serial[1740]: INFO: [serial config] Energomera CE102 1 override property “id”
Jun 03 06:33:52 wirenboard-AUIX2ZRY wb-mqtt-serial[1729]: INFO: [serial config] WB-MWAC-v2 25 override property “id”
Jun 03 06:33:52 wirenboard-AUIX2ZRY wb-mqtt-serial[1729]: INFO: [serial config] WB-LED 39 override property “id”
Jun 03 06:33:53 wirenboard-AUIX2ZRY wb-mqtt-serial[1729]: INFO: [serial config] WB-MIR v.3 133 override property “id”
Jun 03 06:33:53 wirenboard-AUIX2ZRY wb-mqtt-serial[1729]: INFO: [serial config] WB-M1W2 30 override property “id”
Jun 03 06:33:53 wirenboard-AUIX2ZRY wb-mqtt-serial[1729]: INFO: [serial config] WB-MR6C 46 override property “id”
Jun 03 06:33:53 wirenboard-AUIX2ZRY wb-mqtt-serial[1729]: INFO: [serial config] WB-MDM3 57 override property “id”
Jun 03 06:33:53 wirenboard-AUIX2ZRY wb-mqtt-serial[1729]: INFO: [serial config] Energomera CE102 1 override property “id”
Jun 03 15:57:33 wirenboard-AUIX2ZRY wb-mqtt-serial[1763]: INFO: [serial config] WB-MWAC-v2 25 override property “id”
Jun 03 15:57:33 wirenboard-AUIX2ZRY wb-mqtt-serial[1763]: INFO: [serial config] WB-LED 39 override property “id”
Jun 03 15:57:33 wirenboard-AUIX2ZRY wb-mqtt-serial[1763]: INFO: [serial config] WB-MIR v.3 133 override property “id”
Jun 03 15:57:33 wirenboard-AUIX2ZRY wb-mqtt-serial[1763]: INFO: [serial config] WB-M1W2 30 override property “id”
Jun 03 15:57:33 wirenboard-AUIX2ZRY wb-mqtt-serial[1763]: INFO: [serial config] WB-MR6C 46 override property “id”
Jun 03 15:57:33 wirenboard-AUIX2ZRY wb-mqtt-serial[1763]: INFO: [serial config] WB-MDM3 57 override property “id”
Jun 03 15:57:33 wirenboard-AUIX2ZRY wb-mqtt-serial[1763]: INFO: [serial config] Energomera CE102 1 override property “id”
То есть как минимум id был изменен до какого-либо обновления.
но обновление 2602 прошло хорошо. И что делать ? и почему разный формат до обновления на 2606 wb-led_39/Input 4 и после WB-LED/Input 4
это ваш IP 192.168.0.105
Кто-то в конфиг установил (вручную) такие имена.
Я бы поменял обратно. Например используя резервную копию.
Вот это не понял.
При попытке войти по SSH Last login: Wed Jun 3 18:13:44 2026 from 192.168.0.105
Тоже непонятно.
Вы показываете запись lastlogin из лога sshd.
Нет, на контроллер не может зайти никто, кто не знает пароль к нему и не имеет к нему доступа.
А что делать со СХ
    • MobaXterm Personal Edition v25.1 •                 │
│               (SSH client, X server and network tools)               │
│ ⮞ SSH session to root@192.168.0.111                                  │
│   • Direct SSH      :  ✓                                             │
│   • SSH compression :  ✓                                             │
│   • SSH-browser     :  ✓                                             │
│   • X11-forwarding  :  ✓  (remote display is forwarded through SSH)  │
│ ⮞ For more info, ctrl+click on help or visit our website.            │
      _                _                         _
__ ()_ __ __ _ __ | |__ __ __ _ _ __ | |
/ _ \ '_ | '_ \ / _ \ / | '__/ _ |
\ V V /| | | | __/ | | | |
_/_/ |
|| ___|| ||./ _/ _,|| _,_|
Welcome to Wiren Board 8.5.2 (s/n AUIX2ZRY), release wb-2606 (as stable)
Linux wirenboard-AUIX2ZRY 6.8.0-wb158 #1 SMP Thu May 28 10:37:48 UTC 2026 aarch64 GNU/Linux
System load: 0.67 0.97 1.15 Up time: 3:04
Memory usage: 60% of 1.94G Usage of /: 46% of 2.0G /mnt/data: 18% of 13G
Last login: Wed Jun 3 18:57:05 2026 from 192.168.0.105
Может быть это показывает,что вход через вайфай ?
Всё я решил проблему с устройствами ВБ и СХ. просто удалил все устройства в настройках драйвера Serial-устройств,а затем установил автоматом и все заработало. Как говорится " все гениальное-просто"
Если диапазон адресов сети wif-fi включает этот - то да, возможно.
Ну - отлично. Сделайте бэкап для уверенности.
