Проблемы после обновления WB6
заработало, большое спасибо
добрый день
снова на этом же контроллере столкнулся с проблемами
root@wirenboard-AU4Q2YRB:~# sudo apt update --fix-missing
Err:1 http://deb.wirenboard.com/wb6/bullseye stable InRelease
  Cannot initiate the connection to deb.wirenboard.com:80 (2606:4700:3035::ac43:c059). - connect (101: Network is unreachable) Cannot initiate the connection to deb.wirenboard.com:80 (2606:4700:3032::6815:146b). - connect (101: Network is unreachable) Could not connect to deb.wirenboard.com:80 (104.21.20.107), connection timed out Could not connect to deb.wirenboard.com:80 (172.67.192.89), connection timed out
Err:2 http://debian-mirror.wirenboard.com/debian bullseye InRelease
  Cannot initiate the connection to debian-mirror.wirenboard.com:80 (2606:4700:3035::ac43:c059). - connect (101: Network is unreachable) Cannot initiate the connection to debian-mirror.wirenboard.com:80 (2606:4700:3032::6815:146b). - connect (101: Network is unreachable) Could not connect to debian-mirror.wirenboard.com:80 (172.67.192.89), connection timed out Could not connect to debian-mirror.wirenboard.com:80 (104.21.20.107), connection timed out
Err:3 http://debian-mirror.wirenboard.com/debian bullseye-updates InRelease
Err:4 http://debian-mirror.wirenboard.com/debian bullseye-backports InRelease
Err:5 http://debian-mirror.wirenboard.com/debian-security bullseye-security InRelease
Reading package lists... Done
Building dependency tree... Done
5 packages can be upgraded. Run 'apt list --upgradable' to see them.
W: Failed to fetch http://debian-mirror.wirenboard.com/debian/dists/bullseye/InRelease  Cannot initiate the connection to debian-mirror.wirenboard.com:80 (2606:4700:3035::ac43:c059). - connect (101: Network is unreachable) Cannot initiate the connection to debian-mirror.wirenboard.com:80 (2606:4700:3032::6815:146b). - connect (101: Network is unreachable) Could not connect to debian-mirror.wirenboard.com:80 (172.67.192.89), connection timed out Could not connect to debian-mirror.wirenboard.com:80 (104.21.20.107), connection timed out
W: Failed to fetch http://debian-mirror.wirenboard.com/debian/dists/bullseye-updates/InRelease  Cannot initiate the connection to debian-mirror.wirenboard.com:80 (2606:4700:3035::ac43:c059). - connect (101: Network is unreachable) Cannot initiate the connection to debian-mirror.wirenboard.com:80 (2606:4700:3032::6815:146b). - connect (101: Network is unreachable)
W: Failed to fetch http://debian-mirror.wirenboard.com/debian/dists/bullseye-backports/InRelease  Cannot initiate the connection to debian-mirror.wirenboard.com:80 (2606:4700:3035::ac43:c059). - connect (101: Network is unreachable) Cannot initiate the connection to debian-mirror.wirenboard.com:80 (2606:4700:3032::6815:146b). - connect (101: Network is unreachable)
W: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/dists/bullseye-security/InRelease  Cannot initiate the connection to debian-mirror.wirenboard.com:80 (2606:4700:3035::ac43:c059). - connect (101: Network is unreachable) Cannot initiate the connection to debian-mirror.wirenboard.com:80 (2606:4700:3032::6815:146b). - connect (101: Network is unreachable)
W: Failed to fetch http://deb.wirenboard.com/wb6/bullseye/dists/stable/InRelease  Cannot initiate the connection to deb.wirenboard.com:80 (2606:4700:3035::ac43:c059). - connect (101: Network is unreachable) Cannot initiate the connection to deb.wirenboard.com:80 (2606:4700:3032::6815:146b). - connect (101: Network is unreachable) Could not connect to deb.wirenboard.com:80 (104.21.20.107), connection timed out Could not connect to deb.wirenboard.com:80 (172.67.192.89), connection timed out
W: Some index files failed to download. They have been ignored, or old ones used instead.
при создании диагностического архива такой текст, делался очень долго. через веб не делается, только по ssh
(226,8 КБ)
root@wirenboard-AU4Q2YRB:~# wb-diag-collect diag
Start data collecting
2025-01-21 15:53:13,897 [WARNING] Command systemctl list-unit-files --all --output=json didn't finish in 10s
  File "/usr/share/wb-diag-collect/wb/diag/collector.py", line 119, in execute_commands
    proc.wait(timeout)
  File "/usr/lib/python3.9/subprocess.py", line 1189, in wait
    return self._wait(timeout=timeout)
  File "/usr/lib/python3.9/subprocess.py", line 1911, in _wait
    raise TimeoutExpired(self.args, timeout)
subprocess.TimeoutExpired: Command 'systemctl list-unit-files --all --output=json' timed out after 10 seconds
Data was collected successfully
Судя по выводу и лога - на контроллере имеется действующий и не локальный ipv6 адрес. При этом соединение с его использованием - недоступно. Я рекомендую отключить использование протокола v6, если он не работает в сети, куда подключен контроллер.
