wb6 очень долго грузится. Подключился через debug-порт, в нескольких местах останавливается на несколько минут, основные строки скопировал:
[ 81.612315] usb 2-1.2: config 1 interface 0 altsetting 0 endpoint 0x81 has an invalid bInterval 255, changing to 11
[ 81.643544] usb 2-1.2: New USB device found, idVendor=058b, idProduct=0041
[ 81.650683] usb 2-1.2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 81.749268] usbcore: registered new interface driver cdc_acm
[ 81.755100] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ *** ] A start job is running for LSB: Har…Tree overlays (1min 19s / 5min 9s)[ 82.932188] usb 2-1.2: USB disconnect, device number 4
[ 83.260270] usb 2-1.2: new high-speed USB device number 5 using ci_hdrc
[ *** ] A start job is running for LSB: Har…Tree overlays (1min 20s / 5min 9s)[ 83.411431] usb 2-1.2: New USB device found, idVendor=8087, idProduct=07ed
[ 83.418380] usb 2-1.2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ ***] A start job is running for LSB: Har…Tree overlays (1min 20s / 5min 9s)[ 83.956341] usb 2-1.2: USB disconnect, device number 5
[* ] A start job is running for LSB: Har…Tree overlays (1min 25s / 5min 9s)[ 88.350317] usb 2-1.2: new high-speed USB device number 6 using ci_hdrc
[ 88.512712] usb 2-1.2: New USB device found, idVendor=1e0e, idProduct=0020
[ 88.519697] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 88.527171] usb 2-1.2: Product: SIMCOM_PRODUCT
[ 88.531698] usb 2-1.2: Manufacturer: SIMCOM_VENDOR
[ 88.536510] usb 2-1.2: SerialNumber: 004999010640000
[ 88.623505] cdc_acm 2-1.2:1.0: ttyACM0: USB ACM device
[ 88.644043] cdc_acm 2-1.2:1.2: ttyACM1: USB ACM device
[ 88.671358] cdc_acm 2-1.2:1.4: ttyACM2: USB ACM device
[ 88.698705] cdc_acm 2-1.2:1.6: ttyACM3: USB ACM device
[ 88.724377] cdc_acm 2-1.2:1.8: ttyACM4: USB ACM device
[ 88.750108] cdc_acm 2-1.2:1.10: ttyACM5: USB ACM device
[** ] A start job is running for LSB: Har…Tree overlays (1min 25s /[ 88.775942] cdc_acm 2-1.2:1.12: ttyACM6: USB ACM device
[*** ] A start job is running for LSB: Har…ice Tree overlays (4min / 5min 9s)[ 243.690444] INFO: task cat:1141 blocked for more than 120 seconds.
[FAILED] Failed to start LSB: Hardware configuration with Device Tree overlays.
[FAILED] Failed to start Raise network interfaces.
Могу скопировать всё целиком.
После загрузки периодически падает интерфейс ppp0.
wb-mqtt-serial стартует с ошибкой: FATAL: Serial protocol error: cannot open serial port
Как это всё исправлять?
