Wiren Board 6.6.0 (s/n AQXCHWEZ), release wb-2310 (as stable)
После обновление на debian 11, через usb появилась проблема с gsm wb-gsm выдает следующие ошибки:
Спойлер
DEBUG=TRUE wb-gsm restart_if_broken
DEBUG: main: Called from pid 4605 (bash)
DEBUG: guess_of_node: Got of_gsm_node: wirenboard/gsm
DEBUG: gsm_check_present: Modem is enabled in DT (wirenboard/gsm)
DEBUG: gsm_init: Connecting via uart; port: /dev/ttyGSM
DEBUG: is_driven_by_mm: Modem is NOT driven by ModemManager
DEBUG: restart_if_broken: Modem switched off, switch it on instead of testing the connection
DEBUG: ensure_on: switching on GSM modem using POWER FET
DEBUG: toggle: toggle GSM modem state using PWRKEY
DEBUG: ensure_on: Waiting for modem to start
Error in /usr/lib/wb-utils/wb-gsm-common.sh:169. ‘/usr/bin/timeout --signal=SIGKILL --preserve-status $2 /usr/sbin/chat -v TIMEOUT $2 ABORT “ERROR” ABORT “BUSY” “” AT OK “” > $1 < $1’ exited with status 0
Call tree:
1: /usr/lib/wb-utils/wb-gsm-common.sh:650 test_connection(…)
2: /usr/bin/wb-gsm:33 restart_if_broken(…)
Exiting with status 1
DEBUG: test_connection: (port:/dev/ttyGSM(/dev/ttymxc5); timeout:5) => 137
137
DEBUG: restart_if_broken: WARNING: modem restarted, still no answer (1/10)
Call tree:
137
DEBUG: restart_if_broken: WARNING: modem restarted, still no answer (2/10)
Call tree:
137
DEBUG: restart_if_broken: WARNING: modem restarted, still no answer (3/10)
Call tree:
137
DEBUG: restart_if_broken: WARNING: modem restarted, still no answer (4/10)
Call tree:
137
DEBUG: restart_if_broken: WARNING: modem restarted, still no answer (5/10)
Call tree:
137
DEBUG: restart_if_broken: WARNING: modem restarted, still no answer (6/10)
Call tree:
137
DEBUG: restart_if_broken: WARNING: modem restarted, still no answer (7/10)
Call tree:
137
DEBUG: restart_if_broken: WARNING: modem restarted, still no answer (8/10)
Call tree:
137
DEBUG: restart_if_broken: WARNING: modem restarted, still no answer (9/10)
DEBUG: restart_if_broken: ERROR: modem restarted, still no answer
Так же данную проблему наблюдаю на еще трех таких же устройствах,но на двух которые были обновлены через web интерфейс проблем не наблюдается.
