Странное падение WB7
Вчера было странное падение WB, через пол часа она сама ожила, но что было, не ясно, и подобные ситуации повторялись ранее.
17-05-2023 23:10:48.762 [apcupsd]	Cannot open mail:25
17-05-2023 23:10:48.759 [apcupsd]	Unable to locate mail
17-05-2023 23:09:55.950 [init.scope]	Failed to start tasmota to WB.
17-05-2023 23:09:19.479 [bluetooth]	sap-server: Operation not permitted (1)
17-05-2023 23:09:19.478 [bluetooth]	profiles/sap/server.c:sap_server_register() Sap driver initialization failed.
17-05-2023 23:09:19.463 [bluetooth]	sap-server: Operation not permitted (1)
17-05-2023 23:09:19.461 [bluetooth]	profiles/sap/server.c:sap_server_register() Sap driver initialization failed.
17-05-2023 23:09:10.280	vcc-gmac-phy: failed to get the current voltage: -EPROBE_DEFER
17-05-2023 23:09:10.278	dwmac-sun8i 1c50000.ethernet: Error applying setting, reverse things back
17-05-2023 23:09:10.276	sun4i-pinctrl 1c20800.pinctrl: could not request pin 0 (PA0) from group PA0  on device 1c20800.pinctrl
17-05-2023 23:09:10.275	sun4i-pinctrl 1c20800.pinctrl: pin-0 (1c50000.ethernet) status -517
17-05-2023 23:09:10.274	sun4i-pinctrl 1c20800.pinctrl: request() failed for pin 0
17-05-2023 23:09:10.273	sun4i-pinctrl 1c20800.pinctrl: Couldn't get bank PA regulator
17-05-2023 23:09:10.272	sun4i-emac 1c0b000.ethernet: Error applying setting, reverse things back
17-05-2023 23:09:10.270	sun4i-pinctrl 1c20800.pinctrl: could not request pin 232 (PH8) from group PH8  on device 1c20800.pinctrl
17-05-2023 23:09:10.269	sun4i-pinctrl 1c20800.pinctrl: pin-232 (1c0b000.ethernet) status -517
17-05-2023 23:09:10.268	sun4i-pinctrl 1c20800.pinctrl: request() failed for pin 232
17-05-2023 23:09:10.267	sun4i-pinctrl 1c20800.pinctrl: Couldn't get bank PH regulator
17-05-2023 23:09:10.266	sun4i-pinctrl 1c20800.pinctrl: pin-236 (1c20800.pinctrl:236) status -517
17-05-2023 23:09:10.265	sun4i-pinctrl 1c20800.pinctrl: request() failed for pin 236
17-05-2023 23:09:10.264	sun4i-pinctrl 1c20800.pinctrl: Couldn't get bank PH regulator
17-05-2023 22:44:52.266	dwmac-sun8i 1c50000.ethernet: Error applying setting, reverse things back
17-05-2023 22:44:52.265	sun4i-pinctrl 1c20800.pinctrl: could not request pin 0 (PA0) from group PA0  on device 1c20800.pinctrl
17-05-2023 22:44:52.264	sun4i-pinctrl 1c20800.pinctrl: pin-0 (1c50000.ethernet) status -517
17-05-2023 22:44:52.263	sun4i-pinctrl 1c20800.pinctrl: request() failed for pin 0
17-05-2023 22:44:52.262	sun4i-pinctrl 1c20800.pinctrl: Couldn't get bank PA regulator
17-05-2023 22:44:52.261	sun4i-emac 1c0b000.ethernet: Error applying setting, reverse things back
17-05-2023 22:44:52.259	sun4i-pinctrl 1c20800.pinctrl: could not request pin 232 (PH8) from group PH8  on device 1c20800.pinctrl
17-05-2023 22:44:52.258	sun4i-pinctrl 1c20800.pinctrl: pin-232 (1c0b000.ethernet) status -517
17-05-2023 22:44:52.257	sun4i-pinctrl 1c20800.pinctrl: request() failed for pin 232
17-05-2023 22:44:52.256	sun4i-pinctrl 1c20800.pinctrl: Couldn't get bank PH regulator
17-05-2023 22:44:52.255	sun4i-pinctrl 1c20800.pinctrl: pin-236 (1c20800.pinctrl:236) status -517
17-05-2023 22:44:52.254	sun4i-pinctrl 1c20800.pinctrl: request() failed for pin 236
17-05-2023 22:44:52.253	sun4i-pinctrl 1c20800.pinctrl: Couldn't get bank PH regulator
17-05-2023 22:44:52.250	dw-apb-uart 1c28800.serial: Error applying setting, reverse things back
17-05-2023 22:44:52.249	sun4i-pinctrl 1c20800.pinctrl: could not request pin 274 (PI18) from group PI18  on device 1c20800.pinctrl
17-05-2023 22:44:52.247	sun4i-pinctrl 1c20800.pinctrl: pin-274 (1c28800.serial) status -517
17-05-2023 22:44:52.246	sun4i-pinctrl 1c20800.pinctrl: request() failed for pin 274
17-05-2023 22:44:52.245	sun4i-pinctrl 1c20800.pinctrl: Couldn't get bank PI regulator
17-05-2023 22:44:52.241	sun4i-usb-phy 1c13400.phy: Couldn't request ID GPIO
17-05-2023 22:44:52.215	sun4i-usb-phy 1c13400.phy: Couldn't request ID GPIO
17-05-2023 22:44:52.207	/cpus/cpu@3 missing clock-frequency property
17-05-2023 22:44:52.206	/cpus/cpu@2 missing clock-frequency property
17-05-2023 22:44:52.206	/cpus/cpu@1 missing clock-frequency property
17-05-2023 22:44:52.206	/cpus/cpu@0 missing clock-frequency property
log_20230517T232758.log (962,3 КБ)
Добрый день. А что воткнуто в USB? И какой модуль для этого устройства загружен?
да есть там устройство для зигби.
И какой модуль для этого устройства загружен ? не понял это.
чт, 18 мая 2023 г. в 16:04, Андрей Радионов через Wiren Board Support <info@wirenboard.com>:
Какой модуль в ядро под него подгружаете?
никакой zigbee 2 mqtt только
чт, 18 мая 2023 г. в 19:20, Андрей Радионов через Wiren Board Support <info@wirenboard.com>:
Я вижу минимум 7 перезапусков после отключения-подключения USB:
usb 1-1.1: new full-speed USB device
  1. пожалуйста приложите диагностический архив, его можно скачать в веб-интерфейсе
  2. Если есть возможность, приложите фото контроллера
кажется, проблема как-то связана с Wi-Fi или Bluetooth.
diag_output_AQJUWHRZ_2023-05-22-09.53.59.zip (166,6 КБ)
сделайте пожалуйста фото, на которых видно, что подключено в USB.
Я правильно понимаю, что туда воткнуто не “устройство для зигби”, а четырёхпортовый USB-хаб, в который вотнут Wi-Fi-свисток и Zigbee-модуль?
Судя по логам, этот хаб целиком периодически отваливается. В какой-то раз по счёту драйвера для Wi-Fi-свистка сходят с ума и вызывают kernel panic, который кладёт всю систему. Что нужно сделать:
  1. поменять USB-хаб
  2. проверить, что подключенные к нему устройства не требуют слишком много питания. Для этого их можно, например. по одному подключать к WB.
Кроме этого, похоже вы используете Wi-Fi свисток на том же самом чипе, который используется у нас внутри. Проблема в том, что производители очень плохо тестируют драйвера Wi-Fi для работы с несколькими экземплярами одного устройство, и дело может быть в этом. Вы можете явно переключить внешний Wi-Fi на встроенный драйвер rtl8xxxu через bind/unbind. Или купить другой USB-Wi-Fi: с большой вероятностью в нём будет другой чипсет.
Кстати, зачем вам ещё один Wi-Fi?
Незачем, просто такое устройство с зигби.
wifi я по сути не использую.
Тем не менее причина перезапусков именно в его поведении.
Рекомендую отключить и проверить.
Да вы правы без него проблем нет. Буду искать другое зигби стик.
С огромной вероятностью будет работать самый обычный, не комбинированный из верхней части списка Supported Adapters | Zigbee2MQTT
