Добрый день. Есть контроллер 8.5 с модулем Z-Wave. Настроил все по инструкции Подключение Z-Wave устройств к контроллеру Wiren Board — Wiren Board, есть проблема с удаленным доступом.
root@wirenboard-AJE5HNOV:~# apt install zbw
Reading package lists… Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
zbw : Depends: z-way-server but it is not installable
E: Unable to correct problems, you have held broken packages.
В веб морде Z-wave пакет remote access установил, но где взять remote id/login/password непонятно
