Добрый день. Ситуация:
- В логах после загрузки контроллера наблюдаю предупреждения:
Спойлер
24-12-2024 13:55:37.979 WARNING: [device] Unknown metadata for device Basement_Relay: 'error'
24-12-2024 13:55:37.300 WARNING: [device] Unknown metadata for device Basement_Relay: 'error'
24-12-2024 13:55:33.525 WARNING: [device] Unknown metadata for device wb-w1: 'error'
24-12-2024 13:55:32.982 WARNING: [device] Unknown metadata for device Vaillant: 'error'
24-12-2024 13:55:32.949 WARNING: [device] Unknown metadata for device LivingRoom_Sensor: 'error'
24-12-2024 13:55:32.705 WARNING: [device] Unknown metadata for device Bedroom_Relay: 'error'
24-12-2024 13:55:32.529 WARNING: [device] Unknown metadata for device 2floor_Relay_4: 'error'
24-12-2024 13:55:32.359 WARNING: [device] Unknown metadata for device 2floor_Relay_3: 'error'
24-12-2024 13:55:32.255 WARNING: [device] Unknown metadata for device 2floor_Relay_2: 'error'
24-12-2024 13:55:32.073 WARNING: [device] Unknown metadata for device 2floor_Relay_1: 'error'
24-12-2024 13:55:31.867 WARNING: [device] Unknown metadata for device 1floor_Relay_2: 'error'
24-12-2024 13:55:31.764 WARNING: [device] Unknown metadata for device 1floor_Relay_1: 'error'
24-12-2024 13:55:31.673 WARNING: [device] Unknown metadata for device EnergyMeter: 'error'
24-12-2024 13:55:31.624 WARNING: [device] Unknown metadata for device Basement_Relay: 'error'
24-12-2024 13:55:31.600 WARNING: [device] Unknown metadata for device Garage_Sensor: 'error'
24-12-2024 13:55:31.291 WARNING: [device] Unknown metadata for device Garage_DiscreteInput: 'error'
24-12-2024 13:55:31.268 WARNING: [device] Unknown metadata for device Garage_HighVoltage: 'error'
24-12-2024 13:55:31.249 WARNING: [device] Unknown metadata for device Garage_Relay: 'error'
24-12-2024 13:55:30.989 WARNING: [device] Unknown metadata for device Basement_DiscreteInput_1: 'error'
24-12-2024 13:55:30.871 WARNING: [device] Unknown metadata for device Basement_DiscreteInput_2: 'error'
24-12-2024 13:55:30.849 WARNING: [device] Unknown metadata for device Basement_Relay_2: 'error'
24-12-2024 13:55:30.807 WARNING: [device] Unknown metadata for device Basement_Relay_3: 'error'
24-12-2024 13:55:30.592 WARNING: [device] Unknown metadata for device Garage_Sensor_2: 'error'
24-12-2024 13:55:30.338 WARNING: [device] Unknown metadata for device Outside_Sensor: 'error'
24-12-2024 13:55:30.106 WARNING: [device] Unknown metadata for device Basement_Sensor: 'error'
24-12-2024 13:55:29.936 WARNING: [device] Unknown metadata for device BoilerRoom_Relay_2: 'error'
24-12-2024 13:55:29.823 WARNING: [device] Unknown metadata for device Workspace_Sensor: 'error'
24-12-2024 13:55:29.800 WARNING: [device] Unknown metadata for device BoilerRoom_HighVoltage: 'error'
24-12-2024 13:55:29.727 WARNING: [device] Unknown metadata for device BoilerRoom_Sensor: 'error'
24-12-2024 13:55:29.679 WARNING: [device] Unknown metadata for device BoilerRoom_Relay: 'error'
24-12-2024 13:55:28.866 WARNING: [device] Unknown metadata for device wb-adc: 'error'
- Устройства из этих логов либо совсем не отображаются в UI на вкладке “Устройства”, либо отображаются пустыми:
- Сама вкладка “Устройства” работает странно: на долю секуны там появляется больше виджетов, и они тут же исчезают (я не успеваю рассмотреть, что именно там появляется). Когда сворачиваешь виджет, он может сам развернуться обратно в произвольный момент времени.
- Помимо этого, у меня есть скрипт, который регистрирует устройства в HomeAssistant. Не один год скрипт отрабатывал нормально, и устройства уже были в HA к моменту его старта. Сейчас же именно первый автоматический запуск этого скрипта падает из-за того, что не может найти некоторые устройства. Например:
хотя 1-wire датчики подключены. - Топики этих устройств существуют. В MQTTExplorer они отображаются. И эти устройства не молчат, т.е. пишут в эти топики.
- Перезапуск скрипта из пункта (4) вручную чуть позже проходит без ошибок, устройства прокидываются в HA, и дом оживает.
Просуммирую: Устройства есть в MQTT, они появляются хоть и не с первого раза в HA, но отсутствуют в web ui на вкладке “Устройства”. В логах предупреждения.
