Хотел поставить посмотреть IntraHouse
В консоле пишет ошибку
root@wirenboard-AZM33WFM:~# apt install intrahouse
Reading package lists… Done
Building dependency tree
You might want to run ‘apt --fix-broken install’ to correct these.
The following packages have unmet dependencies:
g++ : Depends: g+±6 (>= 6.3.0-9~) but it is not going to be installed
intrahouse : Depends: zip but it is not going to be installed
E: Unmet dependencies. Try ‘apt --fix-broken install’ with no packages (or specify a solution).
Выходит ошибка при запуске обновления apt-get после обновления
Попытался убрать командой apt --fix-broken install`
При запуске apt --fix-broken install
root@wirenboard-AZM33WFM:~# apt --fix-broken install Reading package lists… Done
Correcting dependencies… Done
The following additional packages will be installed:
g+±6 libstdc+±6-dev
Suggested packages:
gcc-6-doc libstdc++6-6-dbg libstdc+±6-doc
The following NEW packages will be installed:
g+±6 libstdc+±6-dev
0 upgraded, 2 newly installed, 0 to remove and 3 not upgraded.
25 not fully installed or removed.
Need to get 0 B/7152 kB of archives.
After this operation, 28.3 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
(Reading database … 53858 files and directories currently installed.)
Preparing to unpack …/libstdc+±6-dev_6.3.0-18+deb9u1_armhf.deb …
Unpacking libstdc+±6-dev:armhf (6.3.0-18+deb9u1) …
dpkg: error processing archive /var/cache/apt/archives/libstdc+±6-dev_6.3.0-18+deb9u1_armhf.deb (–unpack):
cannot copy extracted data for ‘./usr/include/c++/6/tr1/cmath’ to ‘/usr/include/c++/6/tr1/cmath.dpkg-new’: failed to write (No space left on device)
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Preparing to unpack …/g+±6_6.3.0-18+deb9u1_armhf.deb …
Unpacking g+±6 (6.3.0-18+deb9u1) …
dpkg: error processing archive /var/cache/apt/archives/g+±6_6.3.0-18+deb9u1_armhf.deb (–unpack):
cannot copy extracted data for ‘./usr/lib/gcc/arm-linux-gnueabihf/6/cc1plus’ to ‘/usr/lib/gcc/arm-linux-gnueabihf/6/cc1plus.dpkg-new’: failed to write (No space left on device)
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
Подскажите как это сделать.
И еще бы понять, что там не нужное
Я устанавливал только home asistant и брокер
Если я удалю каталог с ним, перед этим остановив home asistant это нормально? Или его по другому удалять надо?
И вот тут я не пойму.
вначале пишет 2.7G /mnt/data,
root@wirenboard-AZM33WFM:/mnt# du -sh /mnt/*
2.7G /mnt/data
2.0G /mnt/sdcard
а потом
root@wirenboard-AZM33WFM:/mnt# du -sh /mnt/data/*
2.6M /mnt/data/etc
260M /mnt/data/root
8.0K /mnt/data/uploads
693M /mnt/data/var
а где еще 1,7 gb пропало? как посмотреть?
Нашел docker скушал место )))
root@wirenboard-AZM33WFM:/mnt/data# du -sh /mnt/data/.docker/
1.6G /mnt/data/.docker/
Как докер установить в другое место?
И логи, и докер лежат на /mnt/data и сейчас совершенно не мешают, хотя логи можно и почистить (логротейт, например, настроить, чтобы хранил их поменьше).
Уместно смотреть du -sh /
Скорей всего что-то тяжелое обитает в /usr/share или /usr/bin
