Установка web интерфейса 2.0 на WB 6.7
При установке web интерфейса 2.0 на WB 6.7 выдается ошибка, см.ниже
root@wirenboard-AJLDR4R4:~# apt install wb-mqtt-homeui=2.0.0~rc4
Reading package lists… Done
Building dependency tree
The following NEW packages will be installed:
wb-mqtt-homeui
0 upgraded, 1 newly installed, 0 to remove and 2 not upgraded.
Need to get 0 B/1976 kB of archives.
After this operation, 6338 kB of additional disk space will be used.
Selecting previously unselected package wb-mqtt-homeui.
(Reading database … 26936 files and directories currently installed.)
Preparing to unpack …/wb-mqtt-homeui_2.0.0~rc4_all.deb …
Unpacking wb-mqtt-homeui (2.0.0~rc4) …
Setting up wb-mqtt-homeui (2.0.0~rc4) …
File “/usr/lib/wb-mqtt-homeui/convert_config_v1v2”, line 157, in
run_script()
File “/usr/lib/wb-mqtt-homeui/convert_config_v1v2”, line 146, in run_script
output_file.write(json.dumps(make_new_config(result), indent=4, sort_keys=True, ensure_ascii=False))
File “/usr/lib/wb-mqtt-homeui/convert_config_v1v2”, line 42, in make_new_config
new_dashboards = _format_dashboards(old_config[‘dashboards’])
File “/usr/lib/wb-mqtt-homeui/convert_config_v1v2”, line 78, in _format_dashboards
d_widgets = old_dashboard[‘widgets’]
KeyError: ‘widgets’
dpkg: error processing package wb-mqtt-homeui (–configure):
subprocess installed post-installation script returned error exit status 1
Errors were encountered while processing:
wb-mqtt-homeui
E: Sub-process /usr/bin/dpkg returned an error code (1)
А что уже rc4 вышла? Вроде последняя в теме про бета тест UPD: wb-mqtt-homeui=2.0.0~rc2.
инфу взял отсюда
Пришлите, пожалуйста, результат команды
mqtt-get-dump "/config/#"
root@wirenboard-AJLDR4R4:~# mqtt-get-dump “/config/#”
/config/default_dashboard/uid dashboard2
/config/rooms/room1/uid room1
/config/rooms/room1/name Комната с Wiren Board
/config/rooms/room2/uid room2
/config/rooms/room2/name котельная
/config/widgets/widget1/controls/slot0/uid slot0
/config/widgets/widget1/controls/slot0/topic /devices/power_status/controls/Vin
/config/widgets/widget1/name Напряжение питания
/config/widgets/widget1/room room1
/config/widgets/widget1/template sensor
/config/widgets/widget1/uid widget1
/config/widgets/widget2/controls/slot0/uid slot0
/config/widgets/widget2/controls/slot0/topic /devices/buzzer/controls/enabled
/config/widgets/widget2/name Звуковой сигнал
/config/widgets/widget2/room room1
/config/widgets/widget2/template alarm
/config/widgets/widget2/uid widget2
/config/widgets/widget3/controls/slot0/uid slot0
/config/widgets/widget3/controls/slot0/topic /devices/network/controls/Ethernet IP
/config/widgets/widget3/name IP-адрес Ethernet
/config/widgets/widget3/room room1
/config/widgets/widget3/template sensor
/config/widgets/widget3/uid widget3
/config/widgets/widget4/controls/slot0/uid slot0
/config/widgets/widget4/controls/slot0/topic /devices/wb-adc/controls/A1
/config/widgets/widget4/name Напряжение на клемме A1
/config/widgets/widget4/room room1
/config/widgets/widget4/template sensor
/config/widgets/widget4/uid widget4
/config/widgets/widget5/controls/slot0/uid slot0
/config/widgets/widget5/controls/slot0/topic /devices/BCG301_10/controls/OT_BoilerTemperature
/config/widgets/widget5/name котельная
/config/widgets/widget5/room room2
/config/widgets/widget5/template temperature
/config/widgets/widget5/uid widget5
/config/dashboards/dashboard1/name Порты контроллера
/config/dashboards/dashboard1/uid dashboard1
/config/dashboards/dashboard1/widgets/widget0/controls/slot0/uid slot0
/config/dashboards/dashboard1/widgets/widget0/controls/slot0/topic/topic /devices/power_status/controls/Vin
/config/dashboards/dashboard1/widgets/widget0/controls/slot0/topic/name Vin
/config/dashboards/dashboard1/widgets/widget0/controls/slot0/topic/value 25.35
/config/dashboards/dashboard1/widgets/widget0/controls/slot0/topic/metaType voltage
/config/dashboards/dashboard1/widgets/widget0/controls/slot0/topic/metaOrder 1
/config/dashboards/dashboard1/widgets/widget0/controls/slot0/topic/metaReadonly 1
/config/dashboards/dashboard1/widgets/widget0/controls/slot0/topic/$$hashKey object:280
/config/dashboards/dashboard1/widgets/widget0/uid widget1
/config/dashboards/dashboard1/widgets/widget0/name Напряжение питания
/config/dashboards/dashboard1/widgets/widget0/room room1
/config/dashboards/dashboard1/widgets/widget0/template sensor
/config/dashboards/dashboard1/widgets/widget0/canEdit false
/config/dashboards/dashboard1/widgets/widget2/controls/slot0/uid slot0
/config/dashboards/dashboard1/widgets/widget2/controls/slot0/topic/topic /devices/buzzer/controls/enabled
/config/dashboards/dashboard1/widgets/widget2/controls/slot0/topic/name enabled
/config/dashboards/dashboard1/widgets/widget2/controls/slot0/topic/value 0
/config/dashboards/dashboard1/widgets/widget2/controls/slot0/topic/metaType switch
/config/dashboards/dashboard1/widgets/widget2/controls/slot0/topic/metaOrder 1
/config/dashboards/dashboard1/widgets/widget2/controls/slot0/topic/metaReadonly 0
/config/dashboards/dashboard1/widgets/widget2/controls/slot0/topic/$$hashKey object:258
/config/dashboards/dashboard1/widgets/widget2/uid widget2
/config/dashboards/dashboard1/widgets/widget2/name Звуковой сигнал
/config/dashboards/dashboard1/widgets/widget2/room room1
/config/dashboards/dashboard1/widgets/widget2/template alarm
/config/dashboards/dashboard1/widgets/widget2/canEdit false
/config/dashboards/dashboard1/widgets/widget3/controls/slot0/uid slot0
/config/dashboards/dashboard1/widgets/widget3/controls/slot0/topic/topic /devices/network/controls/Ethernet IP
/config/dashboards/dashboard1/widgets/widget3/controls/slot0/topic/name Ethernet IP
/config/dashboards/dashboard1/widgets/widget3/controls/slot0/topic/value 192.168.211.33
/config/dashboards/dashboard1/widgets/widget3/controls/slot0/topic/metaType text
/config/dashboards/dashboard1/widgets/widget3/controls/slot0/topic/metaOrder 2
/config/dashboards/dashboard1/widgets/widget3/controls/slot0/topic/metaReadonly 1
/config/dashboards/dashboard1/widgets/widget3/controls/slot0/topic/$$hashKey object:271
/config/dashboards/dashboard1/widgets/widget3/uid widget3
/config/dashboards/dashboard1/widgets/widget3/name IP-адрес Ethernet
/config/dashboards/dashboard1/widgets/widget3/room room1
/config/dashboards/dashboard1/widgets/widget3/template sensor
/config/dashboards/dashboard1/widgets/widget3/canEdit false
/config/dashboards/dashboard1/widgets/widget4/controls/slot0/uid slot0
/config/dashboards/dashboard1/widgets/widget4/controls/slot0/topic/name A1
/config/dashboards/dashboard1/widgets/widget4/controls/slot0/topic/topic /devices/wb-adc/controls/A1
/config/dashboards/dashboard1/widgets/widget4/uid widget4
/config/dashboards/dashboard1/widgets/widget4/name Напряжение на клемме A1
/config/dashboards/dashboard1/widgets/widget4/room room1
/config/dashboards/dashboard1/widgets/widget4/template sensor
/config/dashboards/dashboard1/widgets/widget4/$$hashKey object:369
/config/dashboards/dashboard2/name котельная
/config/dashboards/dashboard2/uid dashboard2
/config/dashboards/dashboard2/widgets/widget0/controls/slot0/uid slot0
/config/dashboards/dashboard2/widgets/widget0/controls/slot0/topic/name OT_BoilerTemperature
/config/dashboards/dashboard2/widgets/widget0/controls/slot0/topic/value 51
/config/dashboards/dashboard2/widgets/widget0/controls/slot0/topic/topic /devices/BCG301_10/controls/OT_BoilerTemperature
/config/dashboards/dashboard2/widgets/widget0/controls/slot0/topic/metaType temperature
/config/dashboards/dashboard2/widgets/widget0/controls/slot0/topic/metaOrder 7
/config/dashboards/dashboard2/widgets/widget0/uid widget5
/config/dashboards/dashboard2/widgets/widget0/name котельная
/config/dashboards/dashboard2/widgets/widget0/room room2
/config/dashboards/dashboard2/widgets/widget0/template temperature
/config/dashboards/dashboard3/name test
/config/dashboards/dashboard3/uid dashboard3
Ровно та ж фигня…
Исправили в wb-mqtt-homeui=2.0.0~rc5
Подобная ошибка и у меня по пакету:
Calculating upgrade… Done
The following packages have been kept back:
device-tree-compiler wb-homa-adc wb-hwconf-manager wb-test-suite
0 upgraded, 0 newly installed, 0 to remove and 4 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up wb-mqtt-homeui (2.0.0) …
File “/usr/lib/wb-mqtt-homeui/convert_config_v1v2”, line 159, in
run_script()
File “/usr/lib/wb-mqtt-homeui/convert_config_v1v2”, line 145, in run_script
result = _merge_dicts(result, i)
File “/usr/lib/wb-mqtt-homeui/convert_config_v1v2”, line 30, in _merge_dicts
result[key] = _merge_dicts(d1.get(key), d2.get(key))
File “/usr/lib/wb-mqtt-homeui/convert_config_v1v2”, line 24, in _merge_dicts
d1_keys = set(d1.keys())
AttributeError: ‘str’ object has no attribute ‘keys’
wb-mqtt-homeui
WB5
Вы ставили rc5?
Если да, то пришлите, пожалуйста, результат команды
Ставится из репо:
apt show wb-mqtt-homeui
Package: wb-mqtt-homeui
Version: 2.0.0
Priority: optional
Section: misc
Maintainer: Evgeny Boger boger@contactless.ru
Installed-Size: 6340 kB
Depends: mosquitto, mqtt-wss, mqtt-tools, nginx-extras, wb-utils (>= 2.0)
Conflicts: wb-homa-webinterface
Breaks: wb-mqtt-confed (<< 1.0.3), wb-mqtt-db (<< 1.5)
Download-Size: 1976 kB
APT-Sources: http://releases.contactless.ru/stable/stretch stretch/main armel Packages
Description: Wiren Board Web UI web interface
Хмм… У меня WB5.5, не WB6.7 (только сейчас обратил внимание на название темы). Это принципиально?
Откатился обратно на 1.8.0… Всё работает штатно:
apt policy wb-mqtt-homeui
wb-mqtt-homeui:
Installed: 1.8.0
Candidate: 2.0.0
Version table:
2.0.0 990
990 http://releases.contactless.ru/stable/stretch stretch/main armel Packages
990 http://releases.contactless.ru/stable/stretch stretch/main all Packages
*** 1.8.0 990
100 /var/lib/dpkg/status
/config/default_dashboard/uid dashboard1
/config/widgets/widget2/controls/slot0/topic /devices/power_status/controls/working on battery
/config/widgets/widget2/name Питание от аккумулятора
/config/widgets/widget2/template binary_sensor
/config/widgets/widget4/controls/slot0/topic /devices/power_status/controls/Vin
/config/widgets/widget4/name Напряжение питания
/config/widgets/widget7/controls/slot0/uid slot0
/config/widgets/widget7/controls/slot0/topic /devices/wb-mir_11/controls/External Temperature Sensor
/config/widgets/widget7/name Floor
/config/widgets/widget7/room room1
/config/widgets/widget7/template temperature
/config/widgets/widget7/uid widget7
/config/widgets/widget8/controls/slot0/uid slot0
/config/widgets/widget8/controls/slot0/topic /devices/wb-msw-v3_12/controls/Temperature
/config/widgets/widget8/name Ceiling
/config/widgets/widget8/room room1
/config/widgets/widget8/template temperature
/config/widgets/widget8/uid widget8
/config/widgets/widget9/controls/slot0/uid slot0
/config/widgets/widget9/controls/slot0/topic /devices/wb-w1/controls/28-0316fa123asd
/config/widgets/widget9/controls/slot1/uid slot1
/config/widgets/widget9/controls/slot1/topic /devices/wb-w1/controls/28-0316fa123asd
/config/widgets/widget9/name Outside
/config/widgets/widget9/room room1
/config/widgets/widget9/template temperature
/config/widgets/widget9/uid widget9
/config/widgets/widget10/controls/slot0/uid slot0
/config/widgets/widget10/controls/slot0/topic /devices/light1/controls/enabled
/config/widgets/widget10/name Light1
/config/widgets/widget10/room room1
/config/widgets/widget10/template light
/config/widgets/widget10/uid widget10
/config/widgets/widget11/controls/slot0/uid slot0
/config/widgets/widget11/controls/slot0/topic /devices/light2/controls/enabled
/config/widgets/widget11/name Light2
/config/widgets/widget11/room room1
/config/widgets/widget11/template light
/config/widgets/widget11/uid widget11
/config/widgets/widget12/controls/slot0/uid slot0
/config/widgets/widget12/controls/slot0/topic /devices/socket1/controls/enabled
/config/widgets/widget12/name sockets
/config/widgets/widget12/room room1
/config/widgets/widget12/template light
/config/widgets/widget12/uid widget12
/config/widgets/widget13/controls/slot0/uid slot0
/config/widgets/widget13/controls/slot0/topic /devices/heater1/controls/enabled
/config/widgets/widget13/name Heater1
/config/widgets/widget13/room room1
/config/widgets/widget13/template light
/config/widgets/widget13/uid widget13
/config/widgets/widget14/controls/slot0/uid slot0
/config/widgets/widget14/controls/slot0/topic /devices/wb-msw-v3_12/controls/Sound Level
/config/widgets/widget14/name Sound Level
/config/widgets/widget14/room room1
/config/widgets/widget14/template sensor
/config/widgets/widget14/uid widget14
/config/widgets/widget15/controls/slot0/uid slot0
/config/widgets/widget15/controls/slot0/topic /devices/light3/controls/enabled
/config/widgets/widget15/name Light3
/config/widgets/widget15/room room1
/config/widgets/widget15/template light
/config/widgets/widget15/uid widget15
/config/dashboards/dashboard1/name zzzzzz
/config/dashboards/dashboard1/widgets/widget0/controls/slot0/topic/name Temperature
/config/dashboards/dashboard1/widgets/widget0/controls/slot0/topic/value 23.2
/config/dashboards/dashboard1/widgets/widget0/controls/slot0/topic/topic /devices/wb-msw-v3_12/controls/Temperature
/config/dashboards/dashboard1/widgets/widget0/controls/slot0/topic/metaType temperature
/config/dashboards/dashboard1/widgets/widget0/controls/slot0/topic/$$hashKey object:301
/config/dashboards/dashboard1/widgets/widget0/uid widget8
/config/dashboards/dashboard1/widgets/widget0/name Ceiling
/config/dashboards/dashboard1/widgets/widget0/template temperature
/config/dashboards/dashboard1/widgets/widget1/controls/slot0/uid slot0
/config/dashboards/dashboard1/widgets/widget1/controls/slot0/topic/name External Temperature Sensor
/config/dashboards/dashboard1/widgets/widget1/controls/slot0/topic/value 21.875
/config/dashboards/dashboard1/widgets/widget1/controls/slot0/topic/topic /devices/wb-mir_11/controls/External Temperature Sensor
/config/dashboards/dashboard1/widgets/widget1/controls/slot0/topic/metaType temperature
/config/dashboards/dashboard1/widgets/widget1/controls/slot0/topic/metaOrder 26
/config/dashboards/dashboard1/widgets/widget1/controls/slot0/topic/$$hashKey object:270
/config/dashboards/dashboard1/widgets/widget1/uid widget7
/config/dashboards/dashboard1/widgets/widget1/name Floor
/config/dashboards/dashboard1/widgets/widget1/room room1
/config/dashboards/dashboard1/widgets/widget1/template temperature
/config/dashboards/dashboard1/widgets/widget1/canEdit false
/config/dashboards/dashboard1/widgets/widget2/controls/slot0/topic/name 28-0316fa123asd
/config/dashboards/dashboard1/widgets/widget2/controls/slot0/topic/value 7.25
/config/dashboards/dashboard1/widgets/widget2/controls/slot0/topic/topic /devices/wb-w1/controls/28-0316fa123asd
/config/dashboards/dashboard1/widgets/widget2/controls/slot0/topic/metaType temperature
/config/dashboards/dashboard1/widgets/widget2/controls/slot0/topic/metaReadonly 1
/config/dashboards/dashboard1/widgets/widget2/controls/slot0/topic/$$hashKey object:321
/config/dashboards/dashboard1/widgets/widget2/controls/slot1/uid slot1
/config/dashboards/dashboard1/widgets/widget2/controls/slot1/topic/name 28-0316fa123asd
/config/dashboards/dashboard1/widgets/widget2/controls/slot1/topic/value 7.25
/config/dashboards/dashboard1/widgets/widget2/controls/slot1/topic/topic /devices/wb-w1/controls/28-0316fa123asd
/config/dashboards/dashboard1/widgets/widget2/controls/slot1/topic/metaType temperature
/config/dashboards/dashboard1/widgets/widget2/controls/slot1/topic/$$hashKey object:321
/config/dashboards/dashboard1/widgets/widget2/uid widget9
/config/dashboards/dashboard1/widgets/widget2/name Outside
/config/dashboards/dashboard1/widgets/widget2/template temperature
/config/dashboards/dashboard1/widgets/widget3/controls/slot0/topic/name working on battery
/config/dashboards/dashboard1/widgets/widget3/controls/slot0/topic/value 0
/config/dashboards/dashboard1/widgets/widget3/controls/slot0/topic/topic /devices/power_status/controls/working on battery
/config/dashboards/dashboard1/widgets/widget3/controls/slot0/topic/metaType switch
/config/dashboards/dashboard1/widgets/widget3/controls/slot0/topic/$$hashKey object:98
/config/dashboards/dashboard1/widgets/widget3/uid widget2
/config/dashboards/dashboard1/widgets/widget3/name Питание от аккумулятора
/config/dashboards/dashboard1/widgets/widget3/template binary_sensor
/config/dashboards/dashboard1/widgets/widget4/controls/slot0/topic undefined
/config/dashboards/dashboard1/widgets/widget4/controls/slot0/topic/name Sound Level
/config/dashboards/dashboard1/widgets/widget4/controls/slot0/topic/value 33.29
/config/dashboards/dashboard1/widgets/widget4/controls/slot0/topic/topic /devices/wb-msw2_32/controls/Sound Level
/config/dashboards/dashboard1/widgets/widget4/controls/slot0/topic/metaType sound_level
/config/dashboards/dashboard1/widgets/widget4/controls/slot0/topic/metaOrder 3
/config/dashboards/dashboard1/widgets/widget4/controls/slot0/topic/$$hashKey object:303
/config/dashboards/dashboard1/widgets/widget4/controls/slot0/topic/metaReadonly 1
/config/dashboards/dashboard1/widgets/widget4/uid widget14
/config/dashboards/dashboard1/widgets/widget4/name Sound Level
Выложили в unstable версию 2.0.1 с исправлением вашей проблемы.
Спасибо, установил без ошибок. Web изменился.
У меня такая же проблема, делал обновление: apt update && apt upgrade
В процессе редактор спросил замену конфиг-файла wb-hardware.conf, я согласился (вдруг это важно)
Далее он сразу свалился на установке wb-mqtt-homeui:
wb-mqtt-homeui
Еще раз запустил apt update && apt upgrade и вывелось много ошибок:
Сводка
root@wirenboard-AX6YUNG3:~# apt update && apt upgrade
Hit:1 http://releases.contactless.ru/stable/stretch stretch InRelease
Hit:3 https://deb.nodesource.com/node_12.x stretch InRelease
Hit:2 http://cdn-fastly.deb.debian.org/debian stretch-backports InRelease
Hit:4 http://security.debian.org stretch/updates InRelease
Ign:5 http://deb.debian.org/debian stretch InRelease
Hit:6 http://deb.debian.org/debian stretch-updates InRelease
Hit:7 http://deb.debian.org/debian stretch Release
Reading package lists... Done
All packages are up to date.
Calculating upgrade... Done
The following package was automatically installed and is no longer required:
  wb-homa-gpio
Use 'apt autoremove' to remove it.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Do you want to continue? [Y/n] Y
Setting up wb-mqtt-homeui (2.0.1) ...
  File "/usr/lib/wb-mqtt-homeui/convert_config_v1v2", line 163, in <module>
    run_script()
  File "/usr/lib/wb-mqtt-homeui/convert_config_v1v2", line 149, in run_script
  File "/usr/lib/wb-mqtt-homeui/convert_config_v1v2", line 34, in _merge_dicts
  File "/usr/lib/wb-mqtt-homeui/convert_config_v1v2", line 28, in _merge_dicts
AttributeError: 'str' object has no attribute 'keys'
dpkg: error processing package wb-mqtt-homeui (--configure):
 wb-mqtt-homeui
Потом я удалил этот пакет “apt remove wb-mqtt-homeui” (наверное зря) и обратно он все равно не ставится
Сводка
root@wirenboard-AX6YUNG3:~# apt remove wb-mqtt-homeui
  wb-homa-gpio
The following packages will be REMOVED:
  wb-mqtt-homeui
0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
After this operation, 6340 kB disk space will be freed.
(Reading database ... 45175 files and directories currently installed.)
Removing wb-mqtt-homeui (2.0.1) ...
root@wirenboard-AX6YUNG3:~# apt install wb-mqtt-homeui
  wb-homa-gpio
  wb-mqtt-homeui
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
After this operation, 6340 kB of additional disk space will be used.
(Reading database ... 45113 files and directories currently installed.)
Preparing to unpack .../wb-mqtt-homeui_2.0.1_all.deb ...
Unpacking wb-mqtt-homeui (2.0.1) ...
    run_script()
 wb-mqtt-homeui
mqtt-get-dump “/config/#”:
Сводка
root@wirenboard-AX6YUNG3:~# mqtt-get-dump "/config/#"
/config/rooms/room2/name        SW-1
/config/widgets/widget1/controls/slot0/topic    /devices/power_status/controls/V        in
/config/widgets/widget3/controls/slot0/topic    /devices/network/controls/Ethern        et IP
/config/widgets/widget5/controls/slot0/topic    /devices/SW-Hydro/controls/1s_Де        тская_BatteryDevice _11
/config/widgets/widget5/name    SW
/config/widgets/widget5/template        sensor
/config/widgets/widget6/controls/slot0/uid      slot0
/config/widgets/widget6/controls/slot0/topic    /devices/SW-Hydro/controls/2s_За        л 1-го этажа_BatteryDevice _13
/config/widgets/widget6/name    SW-2
/config/widgets/widget6/room    room2
/config/widgets/widget6/template        sensor
/config/widgets/widget6/uid     widget6
/config/widgets/widget7/controls/slot0/topic    /devices/SW-Hydro/controls/3_Fib        aro на 108 адресе BatteryDevice _10
/config/widgets/widget7/name    SW-1
/config/widgets/widget7/room    room2
/config/widgets/widget7/template        sensor
/config/dashboards/dashboard1/widgets/widget0/controls/slot0/topic/topic       /        devices/power_status/controls/Vin
/config/dashboards/dashboard1/widgets/widget2/controls/slot0/topic/topic       /        devices/buzzer/controls/enabled
/config/dashboards/dashboard1/widgets/widget3/controls/slot0/topic/topic       /        devices/network/controls/Ethernet IP
/config/dashboards/dashboard1/widgets/widget4/controls/slot0/topic/topic       /        devices/wb-adc/controls/A1
/config/dashboards/dashboard2/name      SW
/config/dashboards/dashboard2/widgets/widget0/controls/slot0/topic      undefine        d
/config/dashboards/dashboard2/widgets/widget0/controls/slot0/topic/name 1s_Детск        ая_BatteryDevice _11
/config/dashboards/dashboard2/widgets/widget0/controls/slot0/topic/value       2        4.3
/config/dashboards/dashboard2/widgets/widget0/controls/slot0/topic/topic       /        devices/SW-Hydro/controls/1s_Детская_BatteryDevice _11
/config/dashboards/dashboard2/widgets/widget0/controls/slot0/topic/$$hashKey   o        bject:274
/config/dashboards/dashboard2/widgets/widget0/name      SW
/config/dashboards/dashboard2/widgets/widget0/template  sensor
/config/dashboards/dashboard2/widgets/widget1/controls/slot0/uid        slot0
/config/dashboards/dashboard2/widgets/widget1/controls/slot0/topic      undefine        d
/config/dashboards/dashboard2/widgets/widget1/controls/slot0/topic/name 3_Fibaro        на 108 адресе BatteryDevice _10
/config/dashboards/dashboard2/widgets/widget1/controls/slot0/topic/value       2        1.5
/config/dashboards/dashboard2/widgets/widget1/controls/slot0/topic/topic       /        devices/SW-Hydro/controls/3_Fibaro на 108 адресе BatteryDevice _10
/config/dashboards/dashboard2/widgets/widget1/controls/slot0/topic/$$hashKey   o        bject:271
/config/dashboards/dashboard2/widgets/widget1/uid       widget7
/config/dashboards/dashboard2/widgets/widget1/name      SW-1
/config/dashboards/dashboard2/widgets/widget1/room      room2
/config/dashboards/dashboard2/widgets/widget1/template  sensor
/config/dashboards/dashboard2/widgets/widget2/controls/slot0/uid        slot0
/config/dashboards/dashboard2/widgets/widget2/controls/slot0/topic      undefine        d
/config/dashboards/dashboard2/widgets/widget2/controls/slot0/topic/name 2s_Зал 1        -го этажа_BatteryDevice _13
/config/dashboards/dashboard2/widgets/widget2/controls/slot0/topic/value       1        9.6
/config/dashboards/dashboard2/widgets/widget2/controls/slot0/topic/topic       /        devices/SW-Hydro/controls/2s_Зал 1-го этажа_BatteryDevice _13
/config/dashboards/dashboard2/widgets/widget2/controls/slot0/topic/$$hashKey   o        bject:277
/config/dashboards/dashboard2/widgets/widget2/uid       widget6
/config/dashboards/dashboard2/widgets/widget2/name      SW-2
/config/dashboards/dashboard2/widgets/widget2/room      room2
/config/dashboards/dashboard2/widgets/widget2/template  sensor
/config/devices/SW-Hydro/controls/RedNode/      infostringBIRTH
/config/devices/SW-Hydro/controls/RedNode/info  1611351459840
mqtt-delete-retained /config/# не помог
Сводка
root@wirenboard-AX6YUNG3:~# mqtt-delete-retained /config/#
100% [#############################################################] 109 of 109
wb-mqtt-homeui is already the newest version (2.0.1).
  wb-homa-gpio
    run_script()
  File "/usr/lib/wb-mqtt-homeui/convert_config_v1v2", line 147, in run_script
    result = dicts[0]
IndexError: list index out of range
 wb-mqtt-homeui
Попробуйте версию 2.0.4 из репозитория experimental.
Не помогло =(
Сводка
root@wirenboard-AX6YUNG3:~# echo "deb http://releases.contactless.ru/experimenta        l/stretch stretch main" > /etc/apt/sources.list.d/experimental.list
Get:2 http://releases.contactless.ru/experimental/stretch stretch InRelease [13.6 kB]
Get:3 http://cdn-fastly.deb.debian.org/debian stretch-backports InRelease [91.8 kB]
Hit:4 https://deb.nodesource.com/node_12.x stretch InRelease
Get:6 http://security.debian.org stretch/updates InRelease [53.0 kB]
Get:7 http://deb.debian.org/debian stretch-updates InRelease [93.6 kB]
Hit:8 http://deb.debian.org/debian stretch Release
Get:9 http://releases.contactless.ru/experimental/stretch stretch/main all Packages [57.6 kB]
Get:10 http://releases.contactless.ru/experimental/stretch stretch/main armhf Packages [157 kB]
Get:11 http://security.debian.org stretch/updates/main armhf Packages [627 kB]
Fetched 1093 kB in 25s (42.3 kB/s)
root@wirenboard-AX6YUNG3:~# apt install wb-mqtt-homeui=2.0.4
  wb-homa-gpio
  wb-mqtt-homeui
1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 1973 kB of archives.
After this operation, 2048 B of additional disk space will be used.
Get:1 http://releases.contactless.ru/experimental/stretch stretch/main armhf wb-mqtt-homeui all 2.0.4 [1973 kB]
Fetched 1973 kB in 5s (384 kB/s)
Preparing to unpack .../wb-mqtt-homeui_2.0.4_all.deb ...
Unpacking wb-mqtt-homeui (2.0.4) over (2.0.1) ...
Setting up wb-mqtt-homeui (2.0.4) ...
  File "/usr/lib/wb-mqtt-homeui/convert_config_v1v2", line 165, in <module>
    run_script()
    result = dicts[0]
 wb-mqtt-homeui
В общем я устал бороться, залил файл с прошивкой через веб-интерфейс и все обновил, проблема исчерпана.
