[Вентиляция] Увлажнитель CAREL Humisonic
Ультразвуковой канальный увлажнитель воздуха
config-carel-humisonic-uu.json (17.8 КБ)
Получаю ошибку при добавлении шаблона:
# wb-mqtt-serial -g
<3>ERROR: [serial config] File: /etc/wb-mqtt-serial.conf.d/templates/config-carel-humisonic-uu.json error: Validation failed.
Error 1
  context: <root>[device][channels][16][name]
  desc: Failed to match regex specified by 'pattern' constraint.
Error 2
  desc: Failed to validate against schema associated with property name 'name'.
Error 3
  desc: Failed to validate against child schema #0.
Error 4
Error 5
  desc: Missing required property 'consists_of'.
Error 6
  desc: Failed to validate against child schema #1.
Error 7
Error 8
Error 9
Error 10
  desc: Failed to validate against child schema #2.
Error 11
Error 12
Error 13
Error 14
  desc: Failed to validate against child schema #3.
Error 15
  desc: Failed to validate against any child schemas allowed by oneOf constraint.
Error 16
Error 17
Error 18
  desc: Missing required property 'device_type'.
Error 19
Error 20
Error 21
  desc: Failed to validate item #16 in array.
Error 22
  desc: Failed to validate against schema associated with property name 'channels'.
Error 23
Error 24
Error 25
Error 26
  context: <root>
  desc: Failed to validate against schema associated with property name 'device'.
В строке 195
 "name": "Slave On/Off"
Замените на
 "name": "Slave On-Off"
Можно, в общем экранировать слэш, но тогда экранирование надо будет использовать при любом обращении к нему, что неудобно.
