WB-MCM8 постоянная ошибка
Доброго дня! Модуль WB-MCM8 при подключении работал нормально, а после ночи перестал работать, примерно раз в 2 секунды на мгновение загорается индикация всех входов, во вкладке “Устройства” показывает красным
В системном журнале wb-mqtt-serial.service пишет следующее:
24-06-2024 11:45:56.422 	WARNING: </dev/ttyRS485-2 9600 8 N 2>: closed due to repetitive errors
24-06-2024 11:45:52.177 	INFO: [modbus] Continuous read enabled [slave_id is 15]
24-06-2024 11:45:51.396 	WARNING: </dev/ttyRS485-2 9600 8 N 2>: closed due to repetitive errors
24-06-2024 11:45:46.365 	WARNING: </dev/ttyRS485-2 9600 8 N 2>: closed due to repetitive errors
24-06-2024 11:45:41.321 	WARNING: </dev/ttyRS485-2 9600 8 N 2>: closed due to repetitive errors
24-06-2024 11:45:36.430 	INFO: [modbus] Continuous read enabled [slave_id is 15]
24-06-2024 11:45:36.311 	WARNING: </dev/ttyRS485-2 9600 8 N 2>: closed due to repetitive errors
24-06-2024 11:45:31.287 	WARNING: </dev/ttyRS485-2 9600 8 N 2>: closed due to repetitive errors
24-06-2024 11:45:26.258 	WARNING: </dev/ttyRS485-2 9600 8 N 2>: closed due to repetitive errors
24-06-2024 11:45:21.223 	WARNING: </dev/ttyRS485-2 9600 8 N 2>: closed due to repetitive errors
24-06-2024 11:45:18.089 	INFO: [modbus] Continuous read enabled [slave_id is 15]
24-06-2024 11:45:16.211 	WARNING: </dev/ttyRS485-2 9600 8 N 2>: closed due to repetitive errors
24-06-2024 11:45:11.167 	WARNING: </dev/ttyRS485-2 9600 8 N 2>: closed due to repetitive errors
24-06-2024 11:45:06.131 	WARNING: </dev/ttyRS485-2 9600 8 N 2>: closed due to repetitive errors
24-06-2024 11:45:01.101 	WARNING: </dev/ttyRS485-2 9600 8 N 2>: closed due to repetitive errors
24-06-2024 11:44:56.062 	WARNING: </dev/ttyRS485-2 9600 8 N 2>: closed due to repetitive errors
24-06-2024 11:44:51.037 	WARNING: </dev/ttyRS485-2 9600 8 N 2>: closed due to repetitive errors
24-06-2024 11:44:45.992 	WARNING: </dev/ttyRS485-2 9600 8 N 2>: closed due to repetitive errors
24-06-2024 11:44:40.977 	WARNING: </dev/ttyRS485-2 9600 8 N 2>: closed due to repetitive errors
24-06-2024 11:44:35.952 	WARNING: </dev/ttyRS485-2 9600 8 N 2>: closed due to repetitive errors
24-06-2024 11:44:31.024 	WARNING: [serial device] device modbus:15 is disconnected
24-06-2024 11:44:30.923 	INFO: [mqtt] subscription succeeded (message id 152)
Это можно починить или что-то с самим модулем не так?
Добрый день
А какой серийный номер модуля?
От чего питается, какое сейчас напряжение питания на нем?
Серийный номер 204742, питается отдельным блоком питания 12 вольт (от этого же БП запитывал датчик WB-MSW v.4, с ним всё нормально на том же RS482-2)
Кажется я понял в чём дело, блок питания для модуля оказался слишком слаб. Я подключил модуль к тому же БП, от которого питается контроллер WB 7 и всё заработало. Соблюсти питающее напряжение мало, нужно ещё учитывать ток (мощность БП).
