сен 20 13:06:45 wirenboard-AIAYP3DV wb-mqtt-serial[16276]: WARNING: <192.168.1.26:23>: closed due to repetitive errors
сен 20 13:08:54 wirenboard-AIAYP3DV wb-mqtt-serial[16276]: WARNING: <192.168.1.26:23>: closed due to repetitive errors
сен 20 13:11:03 wirenboard-AIAYP3DV wb-mqtt-serial[16276]: WARNING: <192.168.1.26:23>: closed due to repetitive errors
сен 20 13:13:11 wirenboard-AIAYP3DV wb-mqtt-serial[16276]: WARNING: <192.168.1.26:23>: closed due to repetitive errors
сен 20 13:15:19 wirenboard-AIAYP3DV wb-mqtt-serial[16276]: WARNING: <192.168.1.26:23>: closed due to repetitive errors
сен 20 13:17:28 wirenboard-AIAYP3DV wb-mqtt-serial[16276]: WARNING: <192.168.1.26:23>: closed due to repetitive errors
сен 20 13:19:36 wirenboard-AIAYP3DV wb-mqtt-serial[16276]: WARNING: <192.168.1.26:23>: closed due to repetitive errors
сен 20 13:21:45 wirenboard-AIAYP3DV wb-mqtt-serial[16276]: WARNING: <192.168.1.26:23>: closed due to repetitive errors
сен 20 13:23:54 wirenboard-AIAYP3DV wb-mqtt-serial[16276]: WARNING: <192.168.1.26:23>: closed due to repetitive errors
сен 20 13:26:02 wirenboard-AIAYP3DV wb-mqtt-serial[16276]: WARNING: <192.168.1.26:23>: closed due to repetitive errors
сен 20 13:28:10 wirenboard-AIAYP3DV wb-mqtt-serial[16276]: WARNING: <192.168.1.26:23>: closed due to repetitive errors
сен 20 13:30:19 wirenboard-AIAYP3DV wb-mqtt-serial[16276]: WARNING: <192.168.1.26:23>: closed due to repetitive errors
сен 20 13:32:32 wirenboard-AIAYP3DV wb-mqtt-serial[16276]: WARNING: <192.168.1.26:23>: closed due to repetitive errors
сен 20 13:34:41 wirenboard-AIAYP3DV wb-mqtt-serial[16276]: WARNING: <192.168.1.26:23>: closed due to repetitive errors
сен 20 13:36:49 wirenboard-AIAYP3DV wb-mqtt-serial[16276]: WARNING: <192.168.1.26:23>: closed due to repetitive errors
сен 20 13:38:57 wirenboard-AIAYP3DV wb-mqtt-serial[16276]: WARNING: <192.168.1.26:23>: closed due to repetitive errors
сен 20 13:41:04 wirenboard-AIAYP3DV wb-mqtt-serial[16276]: WARNING: <192.168.1.26:23>: closed due to repetitive errors
сен 20 13:43:12 wirenboard-AIAYP3DV wb-mqtt-serial[16276]: WARNING: <192.168.1.26:23>: closed due to repetitive errors
сен 20 13:45:19 wirenboard-AIAYP3DV wb-mqtt-serial[16276]: WARNING: <192.168.1.26:23>: closed due to repetitive errors
сен 20 13:47:28 wirenboard-AIAYP3DV wb-mqtt-serial[16276]: WARNING: <192.168.1.26:23>: closed due to repetitive errors
сен 20 13:49:38 wirenboard-AIAYP3DV wb-mqtt-serial[16276]: WARNING: <192.168.1.26:23>: closed due to repetitive errors
сен 20 13:51:46 wirenboard-AIAYP3DV wb-mqtt-serial[16276]: WARNING: <192.168.1.26:23>: closed due to repetitive errors
Посмотрел физическое подключение, аномалий не выявил.
Снял датчик и подключил на modbus линию от самого контроллера, отключив исправный датчик WB-MSW v3. Результат был аналогичный closed due to repetitive errors.
Сделав заключение, что проблема не в линии, а в датчике, я вернул на место старый датчик и уже было хотел отписать сюда результаты, как началось странное.
От старого рабочего датчика начинают приходить все контролы, кроме Co2 и VOC. Через какое то время (меньше минуты) данные от Co2 появляются, а ещё через несколько секунд все контролы помечаются красным. Более того красным помечаются все контролы от реле WB-MR6LV/S, который стоит перед датчиком.
Отключив датчик от линии реле WB-MR6LV/S вернулось в штатный режим. Попытавшись подключить датчик обратно всё повторилось: Co2, VOC, задержка, отказ датчика и отказ реле.
Итого теперь у меня вышли из строя 2 датчика WB-MSW v3. Кто-то понимает, что происходит?)
Посмотрите, пожалуйста, если подать на WB-MSW только питание, зелёный светодиод статуса как себя ведёт? Включается в первые две секунды подачи питания? Горит ли после?
Выше по видео вижу, что зелёный статусный светодиод не горел.
Подключил первый, все контролы заработали кроме VOC. Через пару минут VOC стал в состояние ОК, но на экране устройств показывал 0.
Из строя за 5 мин не вышел.
Диод моргает.
Вроде же достаточно быстро переписываемся?
Сейчас уже рабочий день окончен, можем завтра в рабочее время (с 10 до 18 МСК) в том же темпе разобрать проблему?
