Wb-rules кушают память
Коллеги, добрый день!
Помогите разобраться переполнением памяти как следствие отказом служб.
У меня не сложные скрипты, для умного дома, но за сутки, после перезагрузки контроллер перестает адекватно себя вести до тех пор, пока не будет перезагружен сервис wb-rules
Диагностика
(151,2 КБ)
Правила
wb-rules.zip (10,8 КБ)
Периодически логах выскакивает:
17-01-2024 23:26:38.463 [zigbee2mqtt]	Zigbee2MQTT:debug 2024-01-17 18:26:38: Received Zigbee message from 'Gerkon_vhod', type 'attributeReport', cluster 'genOnOff', data '{"onOff":1}' from endpoint 1 with groupID 0
17-01-2024 23:26:33.242 [zigbee2mqtt]	Zigbee2MQTT:debug 2024-01-17 18:26:33: Saving state to file /mnt/data/root/zigbee2mqtt/data/state.json
17-01-2024 23:26:12.235 [zigbee2mqtt]	Zigbee2MQTT:info  2024-01-17 18:26:12: MQTT publish: topic 'zigbee2mqtt/zvonok1', payload '{"battery":100,"device_temperature":25,"last_seen":1705515972186,"linkquality":10,"power_outage_count":328,"voltage":3005}'
17-01-2024 23:26:12.227 [zigbee2mqtt]	Zigbee2MQTT:debug 2024-01-17 18:26:12: WXKG11LM: Processed data into payload {"voltage":3005,"battery":100,"device_temperature":25,"power_outage_count":328}
17-01-2024 23:26:12.220 [zigbee2mqtt]	Zigbee2MQTT:debug 2024-01-17 18:26:12: WXKG11LM: Processed data into payload {"voltage":3005,"battery":100,"device_temperature":25,"power_outage_count":328}
17-01-2024 23:26:12.202 [zigbee2mqtt]	Zigbee2MQTT:debug 2024-01-17 18:26:12: WXKG11LM: unknown key 6 with value 0,1
17-01-2024 23:26:12.190 [zigbee2mqtt]	Zigbee2MQTT:debug 2024-01-17 18:26:12: Received Zigbee message from 'zvonok1', type 'attributeReport', cluster 'genBasic', data '{"65281":{"1":3005,"10":0,"3":25,"4":5032,"5":329,"6":[0,1]}}' from endpoint 1 with groupID 0
17-01-2024 23:26:11.488 [mosquitto]	1705515971: Error: Permission denied.
17-01-2024 23:26:11.485 [mosquitto]	1705515971: Error saving in-memory database, unable to open /var/lib/mosquitto//mosquitto.db.new for writing.
17-01-2024 23:26:11.477 [mosquitto]	1705515971: Saving in-memory database to /var/lib/mosquitto//mosquitto.db.
17-01-2024 23:25:44.826 [zigbee2mqtt]	Zigbee2MQTT:info  2024-01-17 18:25:44: MQTT publish: topic 'zigbee2mqtt/Svitch_Kuh.dosv', payload '{"last_seen":1705515944797,"linkquality":36,"state_left":"OFF","state_right":"OFF"}'
17-01-2024 23:25:44.802 [zigbee2mqtt]	Zigbee2MQTT:debug 2024-01-17 18:25:44: Received Zigbee message from 'Svitch_Kuh.dosv', type 'raw', cluster 'genPowerCfg', data '{"data":[124,210,21,216,0,160,73,3,24,0,75,18,0,17,0,0],"type":"Buffer"}' from endpoint 6 with groupID 0
17-01-2024 23:25:44.754 [zigbee2mqtt]	Zigbee2MQTT:info  2024-01-17 18:25:44: MQTT publish: topic 'zigbee2mqtt/Svitch_Kuh.dosv', payload '{"last_seen":1705515944749,"linkquality":32,"state_left":"OFF","state_right":"OFF"}'
Подскажите куда копать!?
Судя по логам - весьма похоже на Тормоза при работе Zigbee - #30 от пользователя ekateluv
Как рекомендуют в теме - переключитесь на testing и проверьте.
А какие права на каталог?
Посмотрите в тему Mosquitto после обновления ругается в логах на свою БД
Ругался на БД! Я обновил ПО до последнего стабильного релиза.
После этого, стал получать вот такой лог критических ошибок:
Лог ошибок
log_20240118T211141.log (361,3 КБ)
Вы выложили произвольный кцусок лога, на какой именно сервис стоит обратить внимание?
Вы знаете, я бы разобрал последние двое суток, что-бы понять почему он так себя ведет.
Тут лучше все ж по порядку. Какие сейчас права на /mnt/data/var/lib/mosquitto?
