Есть контроллер
У него проблема: постоянно “отваливается” USB-flash и Sdcard - пробовал разные, в т.ч. и купленную в WB
Решил обновить прошивку но не получилось.
Не могу обновиться никакой версией - перепробовал с 10 шт. Пишет:
Received good update FIT /var/www/uploads/202401220754_wb-2401_bullseye_wb7x.fit, starting update
Tue Feb 27 18:52:34 MSK 2024: started update from /mnt/data/uploads/202401220754_wb-2401_bullseye_wb7x.fit
Description: WirenBoard firmware update
Compatible device: wirenboard,wirenboard-720
Firmware version: 202401220754
Firmware compatible: +single-rootfs +fit-factory-reset +force-repartition +repartition-ramsize-fix
Release name: wb-2401
Release suite: stable
Release target: wb7/bullseye
Release repo prefix:
Time of creation: Mon Jan 22 10:56:47 MSK 2024
Checking SHA1 hash of install
SHA1 hash of install ok
Firmware seems to be compatible with this controller
Extracting install script
Running install script
Console logging enabled; tempfile /tmp/tmp.nMIn5LdDDp, final file /mnt/data/uploads/wb-console.log will be written on exit
/dev/shm/tmp.9386KgQg8y: line 975: fw_has_proper_dtb: command not found
This firmware is too old for this device, please use newer one from https://fw-releases.wirenboard.com/
!!! Firmware is not compatible with this device, no proper DTB found
Removing FIT /mnt/data/uploads/202401220754_wb-2401_bullseye_wb7x.fit
