Стартует и отваливается сервис, что можно сделать?
root@wirenboard-ХХХХХХХХ:/mnt/data/root/zigbee2mqtt# npm start
zigbee2mqtt@1.42.0 start
node index.js
Starting Zigbee2MQTT without watchdog.
[2025-02-01 13:13:13] info: z2m: Logging to console, file (filename: log.log)
[2025-02-01 13:13:13] info: z2m: Starting Zigbee2MQTT version 1.42.0 (commit #unknown)
[2025-02-01 13:13:14] info: z2m: Starting zigbee-herdsman (2.1.9)
[2025-02-01 13:13:18] info: zh:zstack:znp: Opening SerialPort with {“path”:“/dev/ttyMOD4”,“baudRate”:115200,“rtscts”:false,“autoOpen”:false}
[2025-02-01 13:13:18] error: z2m: Error while starting zigbee-herdsman
[2025-02-01 13:13:18] error: z2m: Failed to start zigbee
[2025-02-01 13:13:18] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[2025-02-01 13:13:18] error: z2m: Exiting…
[2025-02-01 13:13:18] error: z2m: Error: Error Resource temporarily unavailable Cannot lock port
root@wirenboard-A7FE65ZF:/mnt/data/root/zigbee2mqtt# systemctl start wb-mqtt-serial
root@wirenboard-A7FE65ZF:/mnt/data/root/zigbee2mqtt# systemctl status zigbee2mqtt
● zigbee2mqtt.service - zigbee2mqtt
Loaded: loaded (/lib/systemd/system/zigbee2mqtt.service; enabled; vendor preset: enabled)
Active: activating (auto-restart) (Result: exit-code) since Sat 2025-02-01 13:13:29 UTC; 40s ago
Process: 23530 ExecStart=/usr/bin/npm start (code=exited, status=1/FAILURE)
Main PID: 23530 (code=exited, status=1/FAILURE)
CPU: 33.751s
