Добрый день, наш клиент на объекте имеет wirenBoard 6 и контроллер Razberry 7 Z-Way 4.0.0
В Z-Way одноименный плагин создаёт кучу ошибок в логах на постоянной основе и так же постоянно интеграция теряет соединение. Так же через Wirenboard 6 не получается управлять состоянием реле в Z-Way. Значения с сенсоров и состоняие реле приходят хорошо, а вот управлять реле не получается, во время попытки управлять в логе Z-Way ничего не происходит
Log
at floor (native)
at Object.ceil (native)
at coerce (automation/userModules/WBMQTT/lib/buffer.js:481:18)
at new Buffer (automation/userModules/WBMQTT/lib/buffer.js:54:19)
at Function.WBMQTTClient.buildMessage (automation/userModules/WBMQTT/lib/mqtt.js:117:13)
at WBMQTTClient._onData (automation/userModules/WBMQTT/lib/mqtt.js:313:31)
at WBMQTTClient._onData (automation/userModules/WBMQTT/lib/mqtt.js:313:10)
^C
pi@raspberrypi:~ $ tail -f /var/log/z-way-server.log | /opt/z-way-server/colorize-log.sh
at floor (native)
[2022-11-09 15:52:54.554] [E] [core] Callback execution error: RangeError: Maximum call stack size exceeded
at floor (native)
[2022-11-09 15:53:04.560] [E] [core] Callback execution error: RangeError: Maximum call stack size exceeded
at floor (native)
[2022-11-09 15:53:14.901] [E] [core] Callback execution error: RangeError: Maximum call stack size exceeded
at floor (native)
[2022-11-09 15:53:24.981] [E] [core] Callback execution error: RangeError: Maximum call stack size exceeded
at floor (native)
[2022-11-09 15:53:35.301] [E] [core] Callback execution error: RangeError: Maximum call stack size exceeded
at floor (native)
[2022-11-09 15:53:45.756] [E] [core] Callback execution error: RangeError: Maximum call stack size exceeded
at floor (native)
[2022-11-09 15:53:56.099] [E] [core] Callback execution error: RangeError: Maximum call stack size exceeded
at floor (native)
[2022-11-09 15:54:06.487] [E] [core] Callback execution error: RangeError: Maximum call stack size exceeded
at floor (native)
[2022-11-09 15:54:16.997] [E] [core] Callback execution error: RangeError: Maximum call stack size exceeded
at floor (native)
[2022-11-09 15:54:27.206] [E] [core] Callback execution error: RangeError: Maximum call stack size exceeded
at floor (native)
[2022-11-09 15:54:37.899] [E] [core] Callback execution error: RangeError: Maximum call stack size exceeded
at floor (native)
[2022-11-09 15:54:48.292] [E] [core] Callback execution error: RangeError: Maximum call stack size exceeded
at floor (native)
[2022-11-09 15:54:58.475] [E] [core] Callback execution error: RangeError: Maximum call stack size exceeded
at floor (native)
[2022-11-09 15:55:08.735] [E] [core] Callback execution error: RangeError: Maximum call stack size exceeded
at floor (native)
[2022-11-09 15:55:23.052] [E] [core] Callback execution error: RangeError: Maximum call stack size exceeded
at floor (native)
[2022-11-09 15:55:33.896] [E] [core] Callback execution error: RangeError: Maximum call stack size exceeded
at floor (native)
[2022-11-09 15:55:44.430] [E] [core] Callback execution error: RangeError: Maximum call stack size exceeded
at floor (native)
[2022-11-09 15:55:55.067] [E] [core] Callback execution error: RangeError: Maximum call stack size exceeded
at floor (native)
[2022-11-09 15:56:05.424] [E] [core] Callback execution error: RangeError: Maximum call stack size exceeded
[2022-11-09 15:56:16.250] [E] [core] Callback execution error: RangeError: Maximum call stack size exceeded
[2022-11-09 15:56:26.483] [E] [core] Callback execution error: RangeError: Maximum call stack size exceeded
[2022-11-09 15:56:40.333] [E] [core] Callback execution error: RangeError: Maximum call stack size exceeded
[2022-11-09 15:56:53.987] [E] [core] Callback execution error: RangeError: Maximum call stack size exceeded
[2022-11-09 15:56:53.988] [I] [core] [WBMQTT-16] Socket connection closed.
[2022-11-09 15:56:53.990] [I] [core] [WBMQTT_16] Error: Disconnected, will retry to connect…
at WBMQTT.BaseModule.error (automation/userModules/BaseModule/index.js:122:17)
at WBMQTT.onDisconnect (automation/userModules/WBMQTT/index.js:161:7)
at WBMQTTClient._disconnectCallback (automation/userModules/WBMQTT/index.js:71:46)
at WBMQTTClient._onClose (automation/userModules/WBMQTT/lib/mqtt.js:303:10)
at tcp._connection.onclose (automation/userModules/WBMQTT/lib/mqtt.js:173:10)
[2022-11-09 15:56:53.991] [I] [zway] Adding job: Get background noise level
[2022-11-09 15:56:53.992] [D] [zway] SENDING: ( 01 03 00 3B C7 )
[2022-11-09 15:56:53.994] [D] [zway] RECEIVED ACK
[2022-11-09 15:56:53.995] [D] [zway] RECEIVED: ( 01 07 01 3B A2 9F 9F 7F 1F )
[2022-11-09 15:56:53.995] [D] [zway] SENT ACK
[2022-11-09 15:56:53.995] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel1 = 162 (0x000000a2)
[2022-11-09 15:56:53.995] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel2 = 159 (0x0000009f)
[2022-11-09 15:56:53.996] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel3 = 159 (0x0000009f)
[2022-11-09 15:56:53.996] [I] [zway] Job 0x3b (Get background noise level): RSSI Ch#1: -94 dBm, Ch#2: -97 dBm, Ch#3: -97 dBm
[2022-11-09 15:56:53.996] [D] [zway] Job 0x3b (Get background noise level): success
[2022-11-09 15:56:53.997] [I] [zway] Removing job: Get background noise level
[2022-11-09 15:56:53.998] [I] [core] Notification: device-info (device-status): {“dev”:“Виртуальное устройство (JavaScript)”,“l”:“26.060651428997517”,“location”:0}
[2022-11-09 15:56:54.000] [I] [core] HK: updated Code_Device_sensorMultilevel_18
[2022-11-09 15:56:54.062] [I] [core] [WBMQTT_16] Error: Error: Please connect to server first
at WBMQTTClient._errorCallback (automation/userModules/WBMQTT/index.js:70:46)
at WBMQTTClient._onError (automation/userModules/WBMQTT/lib/mqtt.js:276:10)
at WBMQTTClient._ping (automation/userModules/WBMQTT/lib/mqtt.js:502:10)
at Function. (automation/userModules/WBMQTT/lib/mqtt.js:544:33)
[2022-11-09 15:56:54.064] [I] [core] [WBMQTT_16] Error: Error: Please connect to server first
at Function. (automation/userModules/WBMQTT/lib/mqtt.js:642:32)
[2022-11-09 15:56:54.065] [I] [core] [WBMQTT_16] Error: Error: Please connect to server first
[2022-11-09 15:56:54.075] [I] [core] [WBMQTT_16] Error: Error: Please connect to server first
[2022-11-09 15:56:54.078] [I] [core] Notification: device-info (device-status): {“dev”:“Виртуальное устройство (JavaScript)”,“l”:“29.257217538543046”,“location”:0}
[2022-11-09 15:56:54.079] [I] [core] HK: updated Code_Device_sensorMultilevel_18
[2022-11-09 15:56:54.080] [I] [core] [WBMQTT_16] Error: Error: Please connect to server first
[2022-11-09 15:56:54.081] [I] [core] [WBMQTT_16] Error: Error: Please connect to server first
[2022-11-09 15:56:54.082] [I] [core] [WBMQTT_16] Error: Error: Please connect to server first
[2022-11-09 15:56:54.083] [I] [core] [WBMQTT_16] Error: Error: Please connect to server first
[2022-11-09 15:56:54.114] [I] [core] Notification: device-info (device-status): {“dev”:“Виртуальное устройство (JavaScript)”,“l”:“24.12251702044159”,“location”:0}
[2022-11-09 15:56:54.114] [I] [core] HK: updated Code_Device_sensorMultilevel_18
[2022-11-09 15:56:54.115] [I] [zway] Adding job: Get background noise level
[2022-11-09 15:56:54.116] [I] [core] Notification: device-info (device-status): {“dev”:“Виртуальное устройство (JavaScript)”,“l”:“72.90345367509872”,“location”:0}
[2022-11-09 15:56:54.116] [I] [core] HK: updated Code_Device_sensorMultilevel_18
[2022-11-09 15:56:54.117] [I] [core] Notification: device-info (device-status): {“dev”:“Виртуальное устройство (JavaScript)”,“l”:“71.3273860514164”,“location”:0}
[2022-11-09 15:56:54.117] [I] [core] HK: updated Code_Device_sensorMultilevel_18
[2022-11-09 15:56:54.118] [I] [core] Notification: device-info (device-status): {“dev”:“Виртуальное устройство (JavaScript)”,“l”:“82.42516336031258”,“location”:0}
[2022-11-09 15:56:54.118] [I] [core] HK: updated Code_Device_sensorMultilevel_18
[2022-11-09 15:56:54.119] [D] [zway] Job 0x3b (Get background noise level): removing duplicate
[2022-11-09 15:56:54.119] [D] [zway] SENDING: ( 01 03 00 3B C7 )
[2022-11-09 15:56:54.121] [D] [zway] RECEIVED ACK
[2022-11-09 15:56:54.122] [D] [zway] RECEIVED: ( 01 07 01 3B A2 9F 9F 7F 1F )
[2022-11-09 15:56:54.122] [D] [zway] SENT ACK
[2022-11-09 15:56:54.122] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel1 = 162 (0x000000a2)
[2022-11-09 15:56:54.122] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel2 = 159 (0x0000009f)
[2022-11-09 15:56:54.122] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel3 = 159 (0x0000009f)
[2022-11-09 15:56:54.122] [I] [zway] Job 0x3b (Get background noise level): RSSI Ch#1: -94 dBm, Ch#2: -97 dBm, Ch#3: -97 dBm
[2022-11-09 15:56:54.122] [D] [zway] Job 0x3b (Get background noise level): success
[2022-11-09 15:56:54.122] [I] [zway] Removing job: Get background noise level
[2022-11-09 15:56:54.144] [I] [core] Notification: device-info (device-status): {“dev”:“Виртуальное устройство (JavaScript)”,“l”:“70.5741448327899”,“location”:0}
[2022-11-09 15:56:54.144] [I] [core] HK: updated Code_Device_sensorMultilevel_18
[2022-11-09 15:56:54.145] [I] [core] Notification: device-info (device-status): {“dev”:“Виртуальное устройство (JavaScript)”,“l”:“11.181794758886099”,“location”:0}
[2022-11-09 15:56:54.145] [I] [core] HK: updated Code_Device_sensorMultilevel_18
[2022-11-09 15:56:54.146] [I] [core] Notification: device-info (device-status): {“dev”:"Виртуальное
