Контроллер WB6.8 не загружается. Вывод debug console:
│ • MobaXterm Personal Edition v23.4 • │
│ (X server, SSH client and network tools) │
│ ⮞ Your computer drives are accessible through the /drives path │
│ ⮞ Your DISPLAY is set to 192.168.101.112:0.0 │
│ ⮞ When using SSH, your remote DISPLAY is automatically forwarded │
│ ⮞ Your HOME folder is not persistent: it will be erased on restart │
│ ⮞ Each command status is specified by a special symbol (✓ or ✗) │
│ • Important: │
│ This is MobaXterm Personal Edition. The Professional edition │
│ allows you to customize MobaXterm for your company: you can add │
│ your own logo, your parameters, your welcome message and generate │
│ either an MSI installation package or a portable executable. │
│ We can also modify MobaXterm or develop the plugins you need. │
│ For more information: https://mobaxterm.mobatek.net/download.html │
Connecting to COM port /dev/ttyS2...
- Press ESC,S to send file using x/y/zmodem
- Press ESC,R to receive file using x/y/zmodem
- Press ESC,Q to exit
U-Boot SPL 2021.10-wb1.7.0-gc221f7953f (Jul 26 2023 - 08:32:47 +0000)
DRAM init ok, rows:15, ncs:1, size: 512MB
.p0_mpdgctrl0 = 0x01180117
.p0_mpdgctrl1 = 0x0e3f0e3f
.p0_mprddlctl = 0x3f3f3f41
.p0_mpwrdlctl = 0x3f3f3936
.p0_mpwldectrl0 = 0x00010005
.p0_mpwldectrl1 = 0x00060006
Trying to boot from MMC1
Warning - USDHC2 controller not supporting
U-Boot 2021.10-wb1.7.0-gc221f7953f (Jul 26 2023 - 08:32:47 +0000)
CPU: Freescale i.MX6ULL rev1.1 792 MHz (running at 396 MHz)
CPU: Industrial temperature grade (-40C to 105C) at 36C
Reset cause: POR
Model: Wiren Board rev. 6.1 (i.MX6UL)
Board: Wiren Board MX6UL
DRAM: 512 MiB
MMC: FSL_SDHC: 1
In: serial
Out: serial
Err: serial
Loading Environment from MMC... OK
Will only keep env vars: mmcpart bootcount upgrade_available uenvcmd wb_webupd otp_program otp_aes_program
## Info: input data size = 43 = 0x2B
bootcount=0
mmcpart=2
upgrade_available=0
Environment size: 43/8188 bytes
## Resetting to default environment
Net: eth0: ethernet@2188000
Hit any key to stop autoboot: 0
## Info: input data size = 4285 = 0x10BD
switch to partitions #0, OK
mmc1(part 0) is current device
eMMC found on device 1
Press FW button to enter firmware update mode
Checking if there is a USB storage with update file wb6_update.fit
dev: usb1_vbus @ regulator@0
starting USB...
Bus usb@2184000: USB EHCI 1.00
Bus usb@2184200: USB EHCI 1.00
scanning bus usb@2184000 for devices...
.p0_mpdgctrl0 = 0x01180118
CPU: Industrial temperature grade (-40C to 105C) at 38C
Reset cause: POR
DRAM: 512 MiB
MMC: FSL_SDHC: 1
In: serial
Out: serial
Err: serial
bootcount=0
mmcpart=2
upgrade_available=0
starting USB...
scanning bus usb@2184000 for devices... 1 USB Device(s) found
scanning bus usb@2184200 for devices... EHCI timed out on TD - token=0x80008d80
USB device not accepting new address (error=22)
scanning usb for storage devices... 0 Storage Device(s) found
No storage devices, perhaps not 'usb start'ed..?
No USB update detected, continuing boot
323 bytes read in 2 ms (157.2 KiB/s)
Importing environment from 0x82000000...
Checking if uenvcmd is set ...
Running default loadzimage ...
6304360 bytes read in 275 ms (21.9 MiB/s)
MMC read: dev # 1, block # 2016, count 32 ... 32 blocks read: OK
Reading overlays list from eMMC
Reading factory fdt name from eMMC
Loading factory fdt imx6ul-wirenboard680
47686 bytes read in 5 ms (9.1 MiB/s)
485 bytes read in 4 ms (118.2 KiB/s)
Applying DT overlay wb6-nogsm
597 bytes read in 3 ms (194.3 KiB/s)
Applying DT overlay wb6-wifi-rtl8723bu
509 bytes read in 4 ms (124 KiB/s)
Applying DT overlay wb6-noradio
334 bytes read in 4 ms (81.1 KiB/s)
Applying DT overlay wb6-eth1
254 bytes read in 4 ms (61.5 KiB/s)
Applying DT overlay temp-industrial
Applying extra overlay
Booting from mmc ...
Kernel image @ 0x82000000 [ 0x000000 - 0x603268 ]
## Flattened Device Tree blob at 83000000
Booting using the fdt blob at 0x83000000
Loading Device Tree to 9ef77000, end 9ef99fff ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.10.35-wb151 (root@wbdevenv) (arm-linux-gnueabihf-gcc (Debian 10.2.1-6) 10.2.1 20210110, GNU ld (GNU Binutils for Deb3
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Wiren Board rev. 6.8.0 (i.MX6UL/ULL)
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] cma: Reserved 16 MiB at 0x9f000000
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x0000000080000000-0x000000009fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000009fffffff]
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 129920
[ 0.000000] Kernel command line: console=ttymxc0,115200 root=/dev/mmcblk0p2 rootwait ro
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 489360K/524288K available (8192K kernel code, 728K rwdata, 2776K rodata, 1024K init, 283K bss, 18544K reserved, 16384K cma-r)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] random: get_random_bytes called from start_kernel+0x234/0x3dc with crng_init=0
[ 0.000000] Switching to timer-based delay loop, resolution 41ns
[ 0.000019] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000058] clocksource: mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.002777] Console: colour dummy device 80x30
[ 0.002841] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.002878] pid_max: default: 32768 minimum: 301
[ 0.003271] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.003304] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.005001] CPU: Testing write buffer coherency: ok
[ 0.006235] Setting up static identity map fo
.p0_mpdgctrl0 = 0x01180115
.p0_mpwrdlctl = 0x3f3f3836
.p0_mpwldectrl0 = 0x00020005
CPU: Industrial temperature grade (-40C to 105C) at 40C
Reset cause: POR
DRAM: 512 MiB
MMC: FSL_SDHC: 1
In: serial
Out: serial
Err: serial
bootcount=0
mmcpart=2
upgrade_available=0
starting USB...
485 bytes read in 3 ms (157.2 KiB/s)
334 bytes read in 3 ms (108.4 KiB/s)
Starting kernel ...
[ 0.000000] Memory: 489360K/524288K available (8192K kernel code, 728K rwdata, 2776K rodata, 1024K init, 283K bss, 18544K reser▒
.p0_mpwldectrl0 = 0x00030005
CPU: Industrial temperature grade (-40C to 105C) at 41C
Reset cause: POR
DRAM: 512 MiB
MMC: FSL_SDHC: 1
In: serial
Out: serial
Err: serial
bootcount=0
mmcpart=2
upgrade_available=0
starting USB...
Starting kernel ...
[ 0.000000] Dentry cache hash ta▒
Reset cause: POR
DRAM: 512 MiB
MMC: FSL_SDHC: 1
In: serial
Out: serial
Err: serial
bootcount=0
mmcpart=2
upgrade_available=0
starting USB...
Starting kernel ...
CPU: Industrial temperature grade (-40C to 105C) at 43C
Reset cause: POR
DRAM: 512 MiB
MMC: FSL_SDHC: 1
In: serial
Out: serial
Err: serial
bootcount=0
mmcpart=2
upgrade_available=0
starting USB...
47686 bytes read in 6 ms (7.6 MiB/s)
Starting kernel ...
[ 0.000000] Memory: 489360K/524288K available (8192K kernel code, 728K rwdata, 2776K rodata, 1024K init, 283K bss, 18544K reserved, 1¢
.p0_mpdgctrl0 = 0x01180116
.p0_mprddlctl = 0x3f3f3e41
.p0_mpwrdlctl = 0x3f3f3935
Reset cause: POR
DRAM: 512 MiB
MMC: FSL_SDHC: 1
In: serial
Out: serial
Err: serial
bootcount=0
mmcpart=2
upgrade_available=0
starting USB...
Starting kernel ...
[ 0.000000] random: get_random_bytes cal +---------------------------+
U-Boot SPL 2021.10-wb1.7.0-gc221f7953f (Jul 26 2023 - 08:32:| |
DRAM init ok, rows:15, ncs:1, size: 512MB | Cannot open /dev/ttyS2! |
.p0_mpdgctrl0 = 0x01180115 | |
.p0_mpdgctrl1 = 0x0e3f0e3f +---------------------------+
.p0_mprddlctl = 0x3f3f3d41
.p0_mpwrdlctl = 0x3f3f3835
Reset cause: POR
DRAM: 512 MiB
MMC: FSL_SDHC: 1
In: serial
Out: serial
Err: serial
bootcount=0
mmcpart=2
upgrade_available=0
Hit any key to stop autoboot: 1
ESC,Z for help |115200 8N1 | NOR | Minicom 2.6.2 | VT102 | Offline
