Вот тут описано.
wb-mqtt-serial.service - MQTT Driver for serial devices
Loaded: loaded (/lib/systemd/system/wb-mqtt-serial.service; enabled; vendor preset: enabled)
Active: active (running) since Fri 2026-07-17 11:17:35 UTC; 18min ago
Process: 1733 ExecStartPre=/usr/lib/wb-mqtt-serial/generate-system-config.sh (code=exited, status=0/SUCCESS)
Main PID: 1769 (wb-mqtt-serial)
Tasks: 14 (limit: 4408)
Memory: 49.5M
CPU: 57.250s
CGroup: /system.slice/wb-mqtt-serial.service
└─1769 /usr/bin/wb-mqtt-serial
Jul 17 11:17:45 wirenboard-ACLGRDHM wb-mqtt-serial[1769]: INFO: [serial client] Events are enabled for <modbus:93:input: 3512>
Jul 17 11:17:45 wirenboard-ACLGRDHM wb-mqtt-serial[1769]: INFO: [serial client] Events are enabled for <modbus:93:input: 3513>
Jul 17 11:17:45 wirenboard-ACLGRDHM wb-mqtt-serial[1769]: INFO: [serial client] Events are enabled for <modbus:93:input: 3514>
Jul 17 11:17:45 wirenboard-ACLGRDHM wb-mqtt-serial[1769]: INFO: [serial client] Events are enabled for <modbus:93:input: 3515>
Jul 17 11:17:45 wirenboard-ACLGRDHM wb-mqtt-serial[1769]: INFO: [serial client] Events are enabled for <modbus:93:input: 3900>
Jul 17 11:17:45 wirenboard-ACLGRDHM wb-mqtt-serial[1769]: INFO: [serial client] Events are enabled for <modbus:93:input: 3904>
Jul 17 11:17:45 wirenboard-ACLGRDHM wb-mqtt-serial[1769]: INFO: [serial client] Events are enabled for <modbus:93:input: 3908>
Jul 17 11:17:45 wirenboard-ACLGRDHM wb-mqtt-serial[1769]: INFO: [serial client] Events are enabled for <modbus:93:input: 3912>
Jul 17 11:17:45 wirenboard-ACLGRDHM wb-mqtt-serial[1769]: INFO: [serial client] Events are disabled for <modbus:93: reboot>
Jul 17 11:17:45 wirenboard-ACLGRDHM wb-mqtt-serial[1769]: INFO: [serial device] device modbus:93 is connected
root@wirenboard-ACLGRDHM:~#
Ну это просто статус службы, причем в логе только старт.
Для анализа - просмотрите логи за несколько минут.
В приложеном архиве ошибок не вижу, то есть за период с перезапуска сервиса с 17:17 до 17:30.
Увеличьте пожалуйста скорость шины rs-485, текущей ширины мало для нормальной работы с устройствами.
До какой скорости поднять опрос?
проверьте на 115200.
Если не будет ошибок (шина нормальная) - то ее и оставьте.
Ну и - давайте, наверное доступ к самому контроллеру. Посмотрел - и думаю проще будет.
Проверю сам наличие ошибок.
И укажите почтовый адрес:
Подскажите, как сейчас у вас дела? Осталась ли проблема?
Нехорошо получилось, что не смогли помочь за три дня переписки. Давайте к вам удалённо подключимся и попробуем решить? Можно он-лайн созвон устроить, на ходу всё менять - проверять.
Ещё подскажите, где географически находитесь, может приехать?
Ещё скажите, пожалуйста, серийный номер шлюза.
Добрый день! Был небольшой переыв на объекте, сейчас вот вернулись туда. Лучше так сказать не стало, все еще анамалии есть. Можете сейчас удаленно подключится?
Вполне можем.
Добавьте пользователя в организацию.
Приглашение прислал.
Из последнего что сделали разонали шину и осатвили шлюз на одном порту, как будто стало чуть лучше, но все равно временами с выключателей команды не проходят
На какой шине выключатели?
Как они управляют шиной (что отправляют в нее)
“не проходит” - не отображается в интерфейсе контроллера?
Есть ли возможность управлять выключателем (например подключить его вход к модулю реле)?
Выключатели на всех шинах дали есть. Они просто шлют по адресу кадого светильника команды вкл/выкл
Это значит что не всегда светильник включатеся от выключателя, из 10 нажатий отрабатывает только 5-7. Но когда мы отключаем шлюз дали, все начинает работать идеально
Отлично. Напишите пожалуйста - что отправляет этот выключатель в шину?
Ну и - есть возможность подключить его вход к каналу реле?
Еще, проверьте пожалуйста следующее - отключите от шлюза DALI только положительный провод шины. После этого проверьте, так же выключателем.
<< 4800 FF16 ArcPower(<address (control gear) 36>,OFF) (fc: 10923)
<< 48fe FF16 ArcPower(<address (control gear) 36>,254) (fc: 10924)
<< 4800 FF16 ArcPower(<address (control gear) 36>,OFF) (fc: 10925)
<< 48fe FF16 ArcPower(<address (control gear) 36>,254) (fc: 10926)
<< 4800 FF16 ArcPower(<address (control gear) 36>,OFF) (fc: 10927)
<< 48fe FF16 ArcPower(<address (control gear) 36>,254) (fc: 10928)
