Как исправить проблему?
U-Boot SPL 2017.03-wb1.3.0-g520058c326 (Jan 18 2022 - 10:56:38)
DRAM init ok, rows:15, ncs:1, size: 512MB
.p0_mpdgctrl0 = 0x010c010c
.p0_mpdgctrl1 = 0x0e3f0e3f
.p0_mprddlctl = 0x3f3f3e40
.p0_mpwrdlctl = 0x3f3f3937
.p0_mpwldectrl0 = 0x00030005
.p0_mpwldectrl1 = 0x00060006
Trying to boot from MMC1
Warning - USDHC2 controller not supporting
U-Boot 2017.03-wb1.3.0-g520058c326 (Jan 18 2022 - 10:56:38 +0000)
CPU: Freescale i.MX6ULL rev1.1 792 MHz (running at 396 MHz)
CPU: Industrial temperature grade (-40C to 105C) at 44C
Reset cause: WDOG
Model: Wiren Board rev. 6.1 (i.MX6UL)
Board: Wiren Board MX6UL
DRAM: 512 MiB
MMC: FSL_SDHC: 0
Using default environment
In: serial
Out: serial
Err: serial
Net: eth0: ethernet@02188000
Hit any key to stop autoboot: 0
Writing to MMC(0)… done
Info: input data size = 2 = 0x2
!!! No Wiren Board bootlib loaded, u-boot is corrupted
resetting …
Reset cause: WDOG
DRAM: 512 MiB
MMC: FSL_SDHC: 0
In: serial
Out: serial
Err: serial
resetting …
Reset cause: WDOG
DRAM: 512 MiB
MMC: FSL_SDHC: 0
In: serial
Out: serial
Err: serial
Hit any key to stop autoboot: 1
.p0_mpdgctrl0 = 0x010d010d
.p0_mprddlctl = 0x3f3f3f40
.p0_mpwrdlctl = 0x3f3f3837
CPU: Industrial temperature grade (-40C to 105C) at 42C
Reset cause: POR
DRAM: 512 MiB
MMC: FSL_SDHC: 0
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Warning: Bootlimit (3) exceeded. Using altbootcmd.
Switching to rootfs on partition 2
Saving Environment to MMC…
resetting …
