Не доступен 'http://deb.wirenboard.com/wb7/bullseye
root@wirenboard-A7PCPNM5:~# apt update; apt upgrade
Ign:1 http://deb.wirenboard.com/wb7/bullseye stable InRelease
Err:2 http://deb.wirenboard.com/wb7/bullseye stable Release
Cannot initiate the connection to deb.wirenboard.com:80 (52.218.98.20). - connect (101: Network is unreachable) Cannot initiate the connection to deb.wirenboard.com:80 (52.218.93.108). - connect (101: Network is unreachable) Cannot initiate the connection to deb.wirenboard.com:80 (52.218.88.228). - connect (101: Network is unreachable) Cannot initiate the connection to deb.wirenboard.com:80 (52.218.46.92). - connect (101: Network is unreachable) Cannot initiate the connection to deb.wirenboard.com:80 (52.218.30.252). - connect (101: Network is unreachable) Cannot initiate the connection to deb.wirenboard.com:80 (52.218.90.76). - connect (101: Network is unreachable) Cannot initiate the connection to deb.wirenboard.com:80 (52.92.33.148). - connect (101: Network is unreachable) Cannot initiate the connection to deb.wirenboard.com:80 (52.218.98.44). - connect (101: Network is unreachable)
Hit:3 Index of /debian-security bullseye-security InRelease
Hit:4 Index of /debian bullseye InRelease
Hit:5 Index of /debian bullseye-updates InRelease
Hit:6 Index of /debian bullseye-backports InRelease
Hit:7 Index of /node_16.x/ bullseye InRelease
Reading package lists… Done
E: The repository ‘http://deb.wirenboard.com/wb7/bullseye stable Release’ does not have a Release file.
N: Updating from such a repository can’t be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
Calculating upgrade… Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Какой у вас сейчас релиз на контроллере?
Проверил - http://deb.wirenboard.com/wb7/bullseye сейчас доступен.
Проверьте пожалуйста настройки сети на контроллере.
Если просто прочитать вывод - то проблему видно.
Как контроллер должен получать доступ в сеть и как он ее получает? Что именно (интерфейс, соединение) используется для маршрута по умолчанию, что должно использоваться?
