Ошибки при апдейте
apt update && apt upgrade
Hit:1 Index of linux/debian/ bullseye InRelease
Get:2 https://deb.nodesource.com/node_16.x bullseye InRelease [4586 B]
Err:3 http://deb.wirenboard.com/wb7/bullseye testing InRelease
Connection failed [IP: 188.114.97.1 80]
Err:4 Index of /debian bullseye InRelease
Err:5 Index of /debian bullseye-updates InRelease
Err:6 Index of /debian bullseye-backports InRelease
Err:7 Index of /debian-security bullseye-security InRelease
Fetched 4586 B in 4min 2s (18 B/s)
Reading package lists… Done
4 packages can be upgraded. Run ‘apt list --upgradable’ to see them.
W: Failed to fetch http://debian-mirror.wirenboard.com/debian/dists/bullseye/InRelease Connection failed [IP: 188.114.97.1 80]
W: Failed to fetch http://debian-mirror.wirenboard.com/debian/dists/bullseye-updates/InRelease Connection failed [IP: 188.114.97.1 80]
W: Failed to fetch http://debian-mirror.wirenboard.com/debian/dists/bullseye-backports/InRelease Connection failed [IP: 188.114.97.1 80]
W: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/dists/bullseye-security/InRelease Connection failed [IP: 188.114.97.1 80]
W: Failed to fetch http://deb.wirenboard.com/wb7/bullseye/dists/testing/InRelease Connection failed [IP: 188.114.97.1 80]
W: Some index files failed to download. They have been ignored, or old ones used instead.
Calculating upgrade… Done
как победить?
Интернет точно есть на контроллере?
Попробуйте выполнить команду: ping ya.ru, покажите вывод. Прекратить выполнение команды можно будет секунд через 10 сочетанием клавиш Ctrl+C
интернет есть. я же к нему подключаюсь и он же видит сколько апдейтов нужно сделать
пинги тож идут
root@wirenboard-ALYNHADY:~# ping ya.ru
PING ya.ru (5.255.255.242) 56(84) bytes of data.
64 bytes from ya.ru (5.255.255.242): icmp_seq=1 ttl=54 time=24.1 ms
64 bytes from ya.ru (5.255.255.242): icmp_seq=2 ttl=54 time=25.0 ms
64 bytes from ya.ru (5.255.255.242): icmp_seq=3 ttl=54 time=22.7 ms
64 bytes from ya.ru (5.255.255.242): icmp_seq=4 ttl=54 time=23.5 ms
Welcome to Wiren Board 7.3.4 (s/n ALYNHADY), release unstable.latest (as testing)
Linux wirenboard-ALYNHADY 5.10.35-wb167 #1 SMP Tue Apr 23 10:37:17 UTC 2024 armv7l GNU/Linux
System load: 1.26 1.53 1.57 Up time: 8 days 27 min
Memory usage: 27% of 1.96G Usage of /: 62% of 2.0G /mnt/data: 15% of 55G
35 package updates are available; type ‘apt update && apt upgrade’ to update them.
Last login: Tue Jun 4 15:29:32 2024 from
root@wirenboard-ALYNHADY:~# apt update && apt upgrade
Hit:1 Index of /debian bullseye InRelease
Get:2 Index of /debian bullseye-updates InRelease [44.1 kB]
Get:3 http://deb.wirenboard.com/wb7/bullseye testing InRelease [3942 B]
Hit:4 Index of linux/debian/ bullseye InRelease
Get:5 Index of /debian bullseye-backports InRelease [49.0 kB]
Get:6 https://deb.nodesource.com/node_16.x bullseye InRelease [4586 B]
Hit:7 Index of /debian-security bullseye-security InRelease
Get:8 http://deb.wirenboard.com/wb7/bullseye testing/main armhf Packages [43.7 kB]
E: Repository ‘Index of /debian bullseye-backports InRelease’ changed its ‘Origin’ value from ‘Debian’ to ‘Debian Backports’
E: Repository ‘Index of /debian bullseye-backports InRelease’ changed its ‘Label’ value from ‘Debian-Security’ to ‘Debian Backports’
N: Repository ‘Index of /debian bullseye-backports InRelease’ changed its ‘Version’ value from ‘11’ to ‘’
N: Repository ‘Index of /debian bullseye-backports InRelease’ changed its ‘Suite’ value from ‘oldstable-security’ to ‘bullseye-backports’
E: Repository ‘Index of /debian bullseye-backports InRelease’ changed its ‘Codename’ value from ‘bullseye-security’ to ‘bullseye-backports’
E: Repository ‘Index of /debian bullseye-backports InRelease’ changed its default priority for apt_preferences(5) from 500 to 100.
N: This must be accepted explicitly before updates for this repository can be applied. See apt-secure(8) manpage for details.
Do you want to accept these changes and continue updating from this repository? [y/N]
А что работает не так как должно?
Сейчас совершенно другой вывод.
Всё работает штатно, нет сообщений по типу Connection failed.
Видимо изначально были какие-то проблемы с сетью.
Произведите обновление и сообщите, всё ли корректно прошло?
все ок
