Продолжая обсуждение из темы Cannot load WebUI config.: MQTT RPC request timed out MqttTimeoutError:
Создал новую тему. Исходное сообщение:
Wiren Board 6.6.0, release wb-2108
точно так же обновлялся со старой версии, выпущенно еще в начале этого года с помощью
apt update && apt dist-upgradeпосле обновления перестали грузиться те же страницы в chrome и ff последних версий. В консоли бразуреа ошибок нет. Вывод
systemctl list-units --type=serviceavahi-daemon.service loaded active running Avahi mDNS/DNS-SD Stack bluetooth.service loaded active running Bluetooth service cgmanager.service loaded active running Cgroup management daemon cron.service loaded active running Regular background program processing daemon dbus.service loaded active running D-Bus System Message Bus dnsmasq.service loaded active running dnsmasq - A lightweight DHCP and caching DNS server getty@tty1.service loaded active running Getty on tty1 hostapd.service loaded active running LSB: Advanced IEEE 802.11 management daemon ifup@wlan0.service loaded active exited ifup for wlan0 kmod-static-nodes.service loaded active exited Create list of required static device nodes for the current kernel knxd.service loaded active running KNX Daemon mosquitto.service loaded active running Mosquitto MQTT v3.1/v3.1.1 Broker netplug.service loaded active running LSB: Brings up/down network automatically networking.service loaded active exited Raise network interfaces nginx.service loaded active running A high performance web server and a reverse proxy server nodered.service loaded active running Node-RED graphical event wiring tool ntp.service loaded active running LSB: Start NTP daemon rsyslog.service loaded active running System Logging Service serial-getty@ttymxc0.service loaded active running Serial Getty on ttymxc0 spruthub.service loaded active running SprutHub ssh.service loaded active running OpenBSD Secure Shell server systemd-fsck-root.service loaded active exited File System Check on Root Device systemd-fsck@dev-mmcblk0p6.service loaded active exited File System Check on /dev/mmcblk0p6 systemd-journald.service loaded active running Journal Service systemd-logind.service loaded active running Login Service systemd-modules-load.service loaded active exited Load Kernel Modules systemd-random-seed.service loaded active exited Load/Save Random Seed systemd-remount-fs.service loaded active exited Remount Root and Kernel File Systems systemd-sysctl.service loaded active exited Apply Kernel Variables systemd-tmpfiles-setup-dev.service loaded active exited Create Static Device Nodes in /dev systemd-tmpfiles-setup.service loaded active exited Create Volatile Files and Directories systemd-udev-trigger.service loaded active exited udev Coldplug all Devices systemd-udevd.service loaded active running udev Kernel Device Manager systemd-update-utmp.service loaded active exited Update UTMP about System Boot/Shutdown systemd-user-sessions.service loaded active exited Permit User Sessions user@0.service loaded active running User Manager for UID 0 watchdog.service loaded active running watchdog daemon wb-configs-early.service loaded active exited prepare mounts and symlinks to config files wb-configs.service loaded active running watch config files wb-gsm-rtc.service loaded active exited LSB: initscript to use GSM modem integrated RTC wb-homa-ism-radio.service loaded active exited LSB: MQTT driver for WB HomA for RFM69 ISM radio wb-hwconf-manager.service loaded active exited LSB: Hardware configuration with Device Tree overlays wb-init.service loaded active exited LSB: board-specific initscript wb-mqtt-adc.service loaded active running MQTT Driver for ADC wb-mqtt-confed.service loaded active exited LSB: Configuration Editor Backend wb-mqtt-db.service loaded active running Wiren Board database logger wb-mqtt-gpio.service loaded active running MQTT Driver for GPIO-controlled switches wb-mqtt-knx.service loaded active running LSB: : Wiren Board MQTT KNX bridge wb-mqtt-mbgate.service loaded active running Wiren Board MQTT to Modbus TCP gateway wb-mqtt-opcua.service loaded active running Wiren Board MQTT to OPC UA gateway wb-mqtt-serial.service loaded active running MQTT Driver for serial devices wb-mqtt-w1.service loaded active running Kernel 1-Wire MQTT driver for WB-HomA wb-prepare.service loaded active exited initialize filesystems at first boot wb-watch-update.service loaded active running LSB: Firmware update monitorстраницу пролистал до конца. Вывод
systemctl status wb-mqtt-confedwb-mqtt-confed.service - LSB: Configuration Editor Backend Loaded: loaded (/etc/init.d/wb-mqtt-confed; generated; vendor preset: enabled) Active: active (exited) since Thu 2021-11-04 08:27:14 UTC; 30min ago Docs: man:systemd-sysv-generator(8) ноя 04 08:27:14 wirenboard-ASWHWRGG systemd[1]: Starting LSB: Configuration Editor Backend... ноя 04 08:27:14 wirenboard-ASWHWRGG systemd[1]: Started LSB: Configuration Editor Backend.очень не хочется перезагружать контроллер😅
