Решил обновить прошивку в контроллере WB6. Скачал файл, в процессе установки высветилась ошибка.
Received good update FIT /var/www/uploads/0000000003, starting update
Wed Jan 24 00:14:54 MSK 2024: started update from /mnt/data/uploads/0000000003
Description: WirenBoard firmware update
Compatible device: contactless,imx6ul-wirenboard670
Firmware version: 202401221310
Firmware compatible: +single-rootfs +fit-factory-reset +force-repartition +repartition-ramsize-fix
Release name: wb-2401
Release suite: stable
Release target: wb6/bullseye
Release repo prefix:
Time of creation: Mon Jan 22 16:13:10 MSK 2024
>>> Checking SHA1 hash of install
>>> SHA1 hash of install ok
>>> Extracting install script
>>> Running install script
>>> Console logging enabled; tempfile /tmp/tmp.DL5DGyxjlL, final file /mnt/data/uploads/wb-console.log will be written on exit
/dev/shm/tmp.Q8yuDtbrhX: line 975: fw_has_proper_dtb: command not found
>>> This firmware is too old for this device, please use newer one from https://fw-releases.wirenboard.com/
!!! Firmware is not compatible with this device, no proper DTB found
>>> Removing FIT /mnt/data/uploads/0000000003
Как я понял из описания, прошивка старая для контроллера.
Что я делаю неправильно?
