Ошибка после обновления прошивки
После прошивки, веб юай не подключается, в консоли браузера:
Request URL: ws://wb:18883/mqtt
на экране попап с текстом -
* Failure to connect to wb:18883 as contactless-Hnj0kDuJ6S. error code 7, error message “AMQJS0007E Socket error:undefined.”
Айпи на контроллере выделяется (wifi dhcp), он не пингуется, ssh не работает
последнее из дебаг консоли:
[ 24.995590] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ OK ] Started MQTT Driver for serial devices.
[ 25.045963] RTL871X: send eapol packet
Starting OpenBSD Secure Shell server…
[ 25.138370] RTL871X: send eapol packet
Starting A high performance web server and a reverse proxy server…
[ 25.295709] RTL871X: set pairwise key camid:4, addr:90:72:82:07:61:4c, kid:0, type:AES
[ 25.450384] RTL871X: set group key camid:5, addr:90:72:82:07:61:4c, kid:1, type:AES
[FAILED] Failed to start KNX Daemon.
See ‘systemctl status knxd.service’ for details.
[ OK ] Started Permit User Sessions.
[ OK ] Started Serial Getty on ttymxc0.
[ OK ] Started Getty on tty1.
[ OK ] Reached target Login Prompts.
[ OK ] Reached target Network is Online.
Starting LSB: Start NTP daemon…
Starting LSB: Brings up/down network automatically…
Starting LSB: Advanced IEEE 802.11 management daemon…
Starting LSB: : Wiren Board MQTT KNX bridge…
[ OK ] Started OpenBSD Secure Shell server.
[ 31.695343] SMSC LAN8710/LAN8720 2188000.ethernet:00: attached PHY driver [SMSC LAN8710/LAN8720] (mii_bus:phy_addr=2188000.ethernet:00, irq=-1)
[ 31.927561] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 32.599358] RTL871X: assoc success
Debian GNU/Linux 9 wirenboard-ACSIRGKJ ttymxc0
wirenboard-ACSIRGKJ login: [ 32.705586] Micrel KSZ8081 or KSZ8091 2188000.ethernet:03: attached PHY driver [Micrel KSZ8081 or KSZ8091] (mii_bus:phy_addr=2188000.ethernet:03, irq=-1)
[ 33.035755] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 51.798032] RTL871X: assoc success
[ 79.985440] random: crng init done
Это ifconfig:
root@wirenboard-ACSIRGKJ:~# ifconfig
eth0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 80:1f:12:63:36:fe txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
eth1: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 80:1f:12:63:21:a6 txqueuelen 1000 (Ethernet)
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10
loop txqueuelen 1 (Local Loopback)
RX packets 28133 bytes 2102816 (2.0 MiB)
TX packets 28133 bytes 2102816 (2.0 MiB)
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.14 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 fe80::7e25:daff:fe1f:5ae0 prefixlen 64 scopeid 0x20
ether 7c:25:da:1f:5a:e0 txqueuelen 1000 (Ethernet)
RX packets 527 bytes 10016 (9.7 KiB)
RX errors 0 dropped 47 overruns 0 frame 0
TX packets 215 bytes 41391 (40.4 KiB)
TX errors 0 dropped 14 overruns 0 carrier 0 collisions 0
Что делать дальше, куда смотреть?
У вас замечательный продукт, хорошая поддержка, отличные ребята, но каждый раз замена прошивки это сюрпризы, потеря времени на выяснение и переписку…
М.б. стоит больше уделить внимания этому вопросу? нанять тестеров, покрыть тестами и вообще обратить внимание на эту серьезную проблему? Да, вопрос не простой, нудный, дерево вариантов огромное, но может все-таки рано или поздно начать…Я понимаю, что пальцем можно показывать на дебиан или какую-нибудь железку, но может все таки начать?
Здравствуйте! Скажите, каким способом обновляли контроллер? Возможно поломались настройки сетевых интерфейсов (при обновлении затерлись файлы /etc/network/interfaces, /etc/hostapd.conf, /etc/default/hostapd. Проверьте их содержимое и правильность настроек. Эту проблему программисты обещали исправить.
Обновлял через web UI.
Добрый день. А зачем именно “прошивкой”?
Очень тщательно тестируется именно штатное обновление, а вот так, простая замена содержимого ФС - ну, как-то не очень полезно.
Не запущен ли hostapd?
Вы знаете… если бы вы где-то упомянули о том, что “прошивка” это оказывается никакая не прошивка, а бандл с ФС, то я бы конечно не пошел бы ее грузить… По моим представлениям прошивка это микрокод который именно нужно прошивать в ППЗУ, и apt update не умеет это делать, поэтому я и выбрал этот путь…
Возможно я невнимательно читал документацию.
hostapd - да, оказался активным, в то время как до обновления он был выключен.
После отключения hostapd сеть поднялась? И да, перепишу в вики про обновление.
Да, все дело было в поднятом по умолчанию hostapd. Убрал и все заработало, спасибо.
