Добрый день
При возврате к заводским настройкам пишет- превышено время…иконка горит красным
Вероятно при попытке настроек через SSH смог что то снести
-При попытке установки модуля Алисы переход на тестинг не переходит, SSH ошибки в коде
System load: 0.14 0.20 0.26 Up time: 17:15
Memory usage: 12% of 1.94G Usage of /: 40% of 2.0G /mnt/data: 3% of 13G
eth0 ip: 192.168.1.108
Last login: Fri Oct 3 11:55:00 2025 from 10.200.200.2
root@wirenboard-ABT4KBQW:~# wb-cloud-agent
| Provider | Controller Url / Activation Url |
| wirenboard.cloud | No connect to: https://wirenboard.cloud |
| root@wirenboard-ABT4KBQW:~# apt update && apt full-upgrade | |
| Err:1 Index of /debian bullseye InRelease | |
| Could not resolve ‘debian-mirror.wirenboard.com’ | |
| Err:2 http://deb.wirenboard.com/wb8/bullseye stable InRelease | |
| Could not resolve ‘deb.wirenboard.com’ | |
| Err:3 Index of /debian bullseye-updates InRelease | |
| Err:4 Index of /debian-security bullseye-security InRelease | |
| Reading package lists… Done | |
| Building dependency tree… Done | |
| Reading state information… Done | |
| All packages are up to date. | |
| W: Failed to fetch http://debian-mirror.wirenboard.com/debian/dists/bullseye/InRelease Could not resolve ‘debian-mirror.wirenboard.com’ | |
| W: Failed to fetch http://debian-mirror.wirenboard.com/debian/dists/bullseye-updates/InRelease Could not resolve ‘debian-mirror.wirenboard.com’ | |
| W: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/dists/bullseye-security/InRelease Could not resolve ‘debian-mirror.wirenboard.com’ | |
| W: Failed to fetch http://deb.wirenboard.com/wb8/bullseye/dists/stable/InRelease Could not resolve ‘deb.wirenboard.com’ | |
| W: Some index files failed to download. They have been ignored, or old ones used instead. | |
| Calculating upgrade… Done | |
| 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. | |
| root@wirenboard-ABT4KBQW:~# inux wirenboard-ABT4KBQW 6.8.0-wb140 #1 SMP Fri Jul 18 08:08:05 UTC 2025 aarch64 GNU/Linux |
Опишите пожалуйста как сейчас настроен dns-сервер. Ну и проверьте - доступен ли он?
Я из описания к сожалению не понял что именно делаете.
Покажите пожалуйста команды, напишите какой ответ (реакцию) ожидаете и чем получаемая отличается.
выше дал настройки
Для возможности подключения к Алисе
На запрос командой на смену
wb-release -t testing
выдает
Accessing http://deb.wirenboard.com/wb8/bullseye/dists/testing/Release.
“Между релизами можно переключаться вручную. Сделайте резервную копию настроек, подключитесь к контроллеру через SSH и выполните одну из команд:”
Почему нет автоматической смены релиза?
похоже разобрался
дали наводку - не верно установил настройки сетевого соединения
wb-cloud-agent
нет, не пускает
Проверил :
traceroute wirenboard.cloud
-bash: traceroute: command not found
