После обновления wb 6.9. на 2307 перестал включаться
произвел обновление wb 6.9. путем загрузки через web страницу fit файла
лог со страницы ниже
<Received good update FIT /mnt/data/.wb-update/202311130829_wb-2310_bullseye_wb67.fit, starting update
Mon Nov 13 19:11:47 UTC 2023: started update from /mnt/data/.wb-update/202311130829_wb-2310_bullseye_wb67.fit
Description:         WirenBoard firmware update
Compatible device:   contactless,imx6ul-wirenboard670
Firmware version:    202311130829
Firmware compatible: +single-rootfs +force-repartition
Release name:        wb-2310
Release suite:       stable
Release target:      wb6/bullseye
Release repo prefix:
Time of creation:    Mon Nov 13 08:32:15 UTC 2023
>>> Checking SHA1 hash of install
>>> SHA1 hash of install ok
32+0 records in
32+0 records out
16384 bytes (16 kB, 16 KiB) copied, 0.00778586 s, 2.1 MB/s
tar: stdout: write error
>>> Firmware seems to be compatible with this controller
>>> Extracting install script
>>> Running install script
>>> Using flags from /mnt/data/.wb-update/install_update.web.flags: --force-repartition
>>> Console logging enabled; tempfile /tmp/tmp.NJl0Jf0ph2, final file /mnt/data/.wb-update/wb-console.log will be written on exit
>>> Checking SHA1 hash of rootfs
>>> SHA1 hash of rootfs ok
>>> rootfs is valid, installing firmware update
>>> Storing this update as factory FIT to use as bootlet
>>> Old factory FIT will be kept as factoryreset.original.fit and will still be used to restore firmware
>>> Flashed U-boot version is too old, updating it before reboot
Das U-Boot installer for Wiren Board
You are about to install U-boot image '/usr/lib/u-boot/mx6ul_wirenboard6/u-boot-with-spl.imx' on '/dev/mmcblk0' (platform wb6)
Force installation requested
Writing U-boot image '/usr/lib/u-boot/mx6ul_wirenboard6/u-boot-with-spl.imx' on '/dev/mmcblk0' (options 'bs=512 seek=2')
831+1 records in
831+1 records out
425816 bytes (426 kB, 416 KiB) copied, 0.571896 s, 745 kB/s
Syncing device
>>> Watch logs in the debug console, or in /mnt/data/.wb-update/state/update.log
>>> Rebooting system to install update
>>> Waiting for Wiren Board to boot again...
>>> Reboot system>
После перезагрузки начал попеременно индикатором показывать сначала зеленый потом оранжевый висит секунды 3 и переходит в красный и по кругу.
что теперь делать пока не понятно
Подключитесь через отладочный порт контроллера покажите лог загрузки контроллера.
Решил вопрос координально сбросом до заводскиз настроек
