Добрый день, котел Vaillant, был приобретен модуль ebus, была проблема с отсутствием данных, модуль поехал в СПБ там обновился и вернулся обратно, но к сожалению модуль постоянно отваливается, сначала помогало перезагружать контроллер, потом только изменение физически слота модуля, сначала во второй потом в 3 потом снова в первый, скажите можно ли сделать что то с этой ситуацией?
| 21-07-2023 01:19:09.960 [wb-rules] | INFO: wbe2-i-ebus_12/FW Version: failed to convert value ‘’, passing raw |
| 21-07-2023 01:19:09.955 [wb-rules] | INFO: wbe2-i-ebus_12/FW Version: failed to convert value ‘’, passing raw |
| 21-07-2023 01:19:09.944 [wb-rules] | INFO: wbe2-i-ebus_12/FW Version: failed to convert value ‘’, passing raw |
| 21-07-2023 01:19:09.935 [wb-rules] | INFO: wbe2-i-ebus_12/Heating Setpoint: failed to convert value ‘’, passing raw |
| 21-07-2023 01:19:09.927 [wb-rules] | INFO: wbe2-i-ebus_12/Heating Setpoint: failed to convert value ‘’, passing raw |
| 21-07-2023 01:19:09.919 [wb-rules] | INFO: wbe2-i-ebus_12/Heating Setpoint: failed to convert value ‘’, passing raw |
| 21-07-2023 01:19:09.914 [wb-rules] | INFO: wbe2-i-ebus_12/Heating Setpoint: failed to convert value ‘’, passing raw |
| 21-07-2023 01:19:09.910 [wb-rules] | INFO: wbe2-i-ebus_12/Hot Water Setpoint: failed to convert value ‘’, passing raw |
| 21-07-2023 01:19:09.899 [wb-rules] | INFO: wbe2-i-ebus_12/Hot Water Setpoint: failed to convert value ‘’, passing raw |
| 21-07-2023 01:19:09.884 [wb-rules] | INFO: wbe2-i-ebus_12/Hot Water Setpoint: failed to convert value ‘’, passing raw |
| 21-07-2023 01:19:09.881 [wb-rules] | INFO: wbe2-i-ebus_12/Hot Water Setpoint: failed to convert value ‘’, passing raw |
| 21-07-2023 01:19:09.879 [wb-rules] | INFO: wbe2-i-ebus_12/Boiler Status: failed to convert value ‘’, passing raw |
| 21-07-2023 01:19:09.868 [wb-rules] | INFO: wbe2-i-ebus_12/Boiler Status: failed to convert value ‘’, passing raw |
| 21-07-2023 01:19:09.860 [wb-rules] | INFO: wbe2-i-ebus_12/Boiler Status: failed to convert value ‘’, passing raw |
| 21-07-2023 01:19:09.853 [wb-rules] | INFO: wbe2-i-ebus_12/Invalid Connection: failed to convert value ‘’, passing raw |
| 21-07-2023 01:19:09.845 [wb-rules] | INFO: wbe2-i-ebus_12/Invalid Connection: failed to convert value ‘’, passing raw |
| 21-07-2023 01:19:09.836 [wb-rules] | INFO: wbe2-i-ebus_12/Invalid Connection: failed to convert value ‘’, passing raw |
| 21-07-2023 01:19:09.832 [wb-rules] | INFO: wbe2-i-ebus_12/Burner Modulation Level (%): failed to convert value ‘’, passing raw |
| 21-07-2023 01:19:09.828 [wb-rules] | INFO: wbe2-i-ebus_12/Burner Modulation Level (%): failed to convert value ‘’, passing raw |
| 21-07-2023 01:19:09.814 [wb-rules] | INFO: wbe2-i-ebus_12/Burner Modulation Level (%): failed to convert value ‘’, passing raw |
| 21-07-2023 01:19:09.809 [wb-rules] | INFO: wbe2-i-ebus_12/Water Pressure: failed to convert value ‘’, passing raw |
| 21-07-2023 01:19:09.805 [wb-rules] | INFO: wbe2-i-ebus_12/Water Pressure: failed to convert value ‘’, passing raw |
| 21-07-2023 01:19:09.798 [wb-rules] | INFO: wbe2-i-ebus_12/Water Pressure: failed to convert value ‘’, passing raw |
| 21-07-2023 01:19:09.791 [wb-rules] | INFO: wbe2-i-ebus_12/Hot Water Setpoint Max: failed to convert value ‘’, passing raw |
| 21-07-2023 01:19:09.777 [wb-rules] | INFO: wbe2-i-ebus_12/Hot Water Setpoint Max: failed to convert value ‘’, passing raw |
| 21-07-2023 01:19:09.768 [wb-rules] | INFO: wbe2-i-ebus_12/Hot Water Setpoint Max: failed to convert value ‘’, passing raw |
| 21-07-2023 01:19:09.757 [wb-rules] | INFO: wbe2-i-ebus_12/Heating Return Water Temperature: failed to convert value ‘’, passing raw |
| 21-07-2023 01:19:09.754 [wb-rules] | INFO: wbe2-i-ebus_12/Heating Return Water Temperature: failed to convert value ‘’, passing raw |
| 21-07-2023 01:19:09.745 [wb-rules] | INFO: wbe2-i-ebus_12/Heating Return Water Temperature: failed to convert value ‘’, passing raw |
| 21-07-2023 01:19:09.741 [wb-rules] | INFO: wbe2-i-ebus_12/Heating Temperature: failed to convert value ‘’, passing raw |
| 21-07-2023 01:19:09.738 [wb-rules] | INFO: wbe2-i-ebus_12/Heating Temperature: failed to convert value ‘’, passing raw |
| 21-07-2023 01:19:09.729 [wb-rules] | INFO: wbe2-i-ebus_12/Heating Temperature: failed to convert value ‘’, passing raw |
| 21-07-2023 01:19:09.719 [wb-rules] | INFO: wbe2-i-ebus_12/Hot Water Temperature: failed to convert value ‘’, passing raw |
| 21-07-2023 01:19:09.714 [wb-rules] | INFO: wbe2-i-ebus_12/Hot Water Temperature: failed to convert value ‘’, passing raw |
| 21-07-2023 01:19:09.708 [wb-rules] | INFO: wbe2-i-ebus_12/Hot Water Temperature: failed to convert value ‘’, passing raw |
| 21-07-2023 01:19:09.705 [wb-rules] | INFO: wbe2-i-ebus_12/Error Code: failed to convert value ‘’, passing raw |
| 21-07-2023 01:19:09.698 [wb-rules] | INFO: wbe2-i-ebus_12/Error Code: failed to convert value ‘’, passing raw |
| 21-07-2023 01:19:09.671 [wb-rules] | INFO: wbe2-i-ebus_12/Error Code: failed to convert value ‘’, passing raw |
Подскажите, пожалуйста, а в виджете показания красные или черные? Можете фото скинуть.
Интересно состояние параметров данного виджета при возникновении описываемой вами проблемы. Т.е. Необходимо понять, где теряется связь: между контроллером и модулем или между модулем и котлом.
Когда возникает данная проблема, доступен ли сам модуль? Т.е. не все параметры будут красными.
Причём, что когда котёл подключён некоторые данные не опрашиваются периодически:
параметры частично отваливаются, но потом модуль пишет про отсутствие связи и на этом все заканчивается
Нужен диагностический архив, когда “все заканчивается”
Нужно ещё какие нибудь данные? Если есть необходимость я могу и контроллер с модулем привезти на тест, котел только не получится))
по индикации
По индикации я так вижу котёл отключён? А Modbus светодиод работает так, будто WB его неправильно опрашивает. Бит чётности, паритет правильно настроен?
Котёл подключен физически, всё настроено так же как до отвала
Все-таки мне не совсем ясно. Когда “отваливается” модуль, пропадают все собираемые параметры или нет? В момент возникновения проблемы, попробуйте связаться по modbus_client с модулем и проверить считываются ли какие-либо параметры. До сих пор не ясно отваливается связь WB с модулем или модуля с котлом.
Котёл отваливается если не видит модуль, параметры не считываются но не отваливаются, не краснеют
Подскажите, какая версия прошивки сейчас в модуле?
Увидел, на скрине, что версия 1.4
Просьба проверить связь WB с модулем в момент возникновения проблемы через modbus_client - удачные ли ответы от модуля.
