Что-то сломалось в репозитории для WB6
# apt upgrade
Reading package lists... Done
Building dependency tree... Done
Calculating upgrade... Done
wb-homeui-backend wb-mqtt-alice wb-mqtt-homeui wb-release-info
4 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 3,400 kB of archives.
After this operation, 28.7 kB disk space will be freed.
Do you want to continue? [Y/n]
Err:1 http://deb.wirenboard.com/wb6/bullseye testing/main armhf wb-release-info all 1.0-testing~wb6+bullseye~20260507040747
404 Not Found [IP: 151.236.110.189 80]
Err:2 http://deb.wirenboard.com/wb6/bullseye testing/main armhf wb-homeui-backend all 2.206.5
Err:3 http://deb.wirenboard.com/wb6/bullseye testing/main armhf wb-mqtt-homeui all 2.206.5
Err:4 http://deb.wirenboard.com/wb6/bullseye testing/main armhf wb-mqtt-alice all 0.9.4
E: Failed to fetch http://deb.wirenboard.com/wb6/bullseye/pool/main/w/wb-release-info/wb-release-info_1.0-testing%7ewb6%2bbullseye%7e20260507040747_all.deb 404 Not Found [IP: 151.236.110.189 80]
E: Failed to fetch http://deb.wirenboard.com/wb6/bullseye/pool/main/w/wb-mqtt-homeui/wb-homeui-backend_2.206.5_all.deb 404 Not Found [IP: 151.236.110.189 80]
E: Failed to fetch http://deb.wirenboard.com/wb6/bullseye/pool/main/w/wb-mqtt-homeui/wb-mqtt-homeui_2.206.5_all.deb 404 Not Found [IP: 151.236.110.189 80]
E: Failed to fetch http://deb.wirenboard.com/wb6/bullseye/pool/main/w/wb-mqtt-alice/wb-mqtt-alice_0.9.4_all.deb 404 Not Found [IP: 151.236.110.189 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
WB7 таких проблем нет, нормально обновился
