Добрый день пытаюсь перепрошить со сбросом до заводских настроек контроллер, получаю это
Factory reset is confirmed!
Mon Jan 19 09:43:35 UTC 2026: started update from /disk/wb6_update_FACTORYRESET.fit
Description: WirenBoard firmware update
Compatible device: contactless,imx6ul-wirenboard61
Firmware version: 202601161811
Firmware compatible: +single-rootfs +fit-factory-reset +force-repartition +repartition-ramsize-fix +fit-immutable-support +wb8-debug-network-update-fix +wrong-ab-layout-fix +update-from-cloud
Release name: wb-2507
Release suite: stable
Release target: wb6/bullseye
Release repo prefix:
Time of creation: Fri Jan 16 18:12:11 UTC 2026
Checking SHA1 hash of install
PROGRESS: 0%
SHA1 hash of install ok
Requested factory reset will be performed by firmware itself
32+0 records in
32+0 records out
16384 bytes (16 kB, 16 KiB) copied, 0.0133141 s, 1.2 MB/s
Firmware seems to be compatible with this controller
Extracting install script
Running install script
Console logging enabled; tempfile /tmp/tmp.LIUfw7, final file /disk/wb-console.log will be writ ten on exit
Reading uboot env offset/size from device tree…
Could not read uboot-env-offset from device tree. Keeping old fw_env.config from rootfs
Extend tmpfs size to whole RAM
Remount tmpfs in /tmp with size=498M
Maybe update factoryreset.fit to fix tmpfs size issue at 512M RAM (with emmc update)
[ 27.620285] EXT4-fs (mmcblk0p6): recovery complete
[ 27.626842] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
fit_info: Can’t open /tmp/tmp.LBvW44/.wb-restore/factoryreset.fit: No such file or directory
Replace factoryreset.fit with current fit to fix rootfs extending issue at 512M RAM
Copying /disk/wb6_update_FACTORYRESET.fit to factory default location as requested
fit_info: Can’t open /tmp/tmp.GiQHpd/.wb-restore/factoryreset.fit: No such file or directory
cp: can’t create ‘/tmp/tmp.GiQHpd/.wb-restore/factoryreset.fit’: No such file or directory
BusyBox v1.30.1 (Debian 1:1.30.1-6+deb11u1) built-in shell (ash)
Enter ‘help’ for a list of built-in commands.
sh: can’t access tty; job control turned off
~ # [ 33.767799] vref-3v3: disabling
