Обновился на wb-67-stable-2021-03-01_18:45:32.fit.
Контролер перешел в циклический ребут.
Debian GNU/Linux 9 wirenboard-ASIX3PDG ttymxc0
wirenboard-ASIX3PDG login: [ 37.945190] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 38.485131] fec 2188000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 42.781225] RTL871X: RTW_ADAPTIVITY_EN_[ 42.785103] AUTO, chplan:0x20, Regulation:3,3
[ 42.789478] RTL871X: RTW_ADAPTIVITY_MODE_[ 42.793337] NORMAL
[ 46.055091] RTL871X: nolinked power save leave
[ 46.339657] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 46.848660] RTL871X: assoc success
[ 46.852232] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 92.548970] systemd-journald[149]: Received SIGTERM from PID 4449 (watchdog).
[ 93.541417] systemd[1]: wb-mqtt-adc.service: Main process exited, code=killed, status=6/ABRT
[ 93.592574] systemd[1]: wb-mqtt-adc.service: Unit entered failed state.
[ 93.608423] systemd[1]: wb-mqtt-adc.service: Failed with result ‘signal’.
[ 93.618120] systemd[1]: wb-mqtt-gpio.service: Main process exited, code=killed, status=6/ABRT
[ 93.629243] systemd[1]: wb-mqtt-gpio.service: Unit entered failed state.
[ 93.636571] systemd[1]: wb-mqtt-gpio.service: Failed with result ‘signal’.
[ 93.690941] systemd[1]: Reexecuting.
[ 93.776125] systemd: 28 output lines suppressed due to ratelimiting
[ 94.053352] systemd-sysv-generator[4581]: [/etc/init.d/wb-mqtt-knx:6] Could not build name for facility $remote_fs,: Invalid argument
[ 94.648167] RTL871X: nolinked power save enter
[ 97.669791] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 98.507460] RTL871X: RTW_ADAPTIVITY_EN_[ 98.511148] AUTO, chplan:0x20, Regulation:3,3
[ 98.515556] RTL871X: RTW_ADAPTIVITY_MODE_[ 98.519396] NORMAL
[ 99.253402] RTL871X: nolinked power save leave
[ 100.514536] gpio-wdt watchdog: Timer expired. System will reboot soon!
[ 103.600668] RTL871X: nolinked power save enter
[ 119.891176] systemd-sysv-generator[4593]: [/etc/init.d/wb-mqtt-knx:6] Could not build name for facility $remote_fs,: Invalid argument
U-Boot 2017.03-1.1.0-gaa233c0fa3 (Jun 09 2020 - 19:28:23 +0000)
