Проблема с установкой пакетов
Добрый день не получается установить пакеты на контроллер выдает следущее
root@wirenboard-AG2YRMHT:~# apt update && apt install -y nodejs git make g++ gcc build-essential Err:1 Index of /debian bullseye InRelease
Could not resolve ‘debian-mirror.wirenboard.com
Err:2 http://deb.wirenboard.com/wb6/bullseye stable InRelease
Could not resolve ‘deb.wirenboard.com
Err:3 https://deb.nodesource.com/node_16.x bullseye InRelease
Could not resolve ‘deb.nodesource.com
Err:4 Index of /debian bullseye-updates InRelease
Err:5 Index of /debian bullseye-backports InRelease
Err:6 http://debian-mirror.wirenboard.com/debian-security bullseye-security InRelease
Reading package lists… Done
All packages are up to date.
W: Failed to fetch http://debian-mirror.wirenboard.com/debian/dists/bullseye/InRelease Could not resolve ‘debian-mirror.wirenboard.com
W: Failed to fetch http://debian-mirror.wirenboard.com/debian/dists/bullseye-updates/InRelease Could not resolve ‘debian-mirror.wirenboard.com
W: Failed to fetch http://debian-mirror.wirenboard.com/debian/dists/bullseye-backports/InRelease Could not resolve ‘debian-mirror.wirenboard.com
W: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/dists/bullseye-security/InRelease Could not resolve ‘debian-mirror.wirenboard.com
W: Failed to fetch https://deb.nodesource.com/node_16.x/dists/bullseye/InRelease Could not resolve ‘deb.nodesource.com
W: Failed to fetch http://deb.wirenboard.com/wb6/bullseye/dists/stable/InRelease Could not resolve ‘deb.wirenboard.com
W: Some index files failed to download. They have been ignored, or old ones used instead.
Package make is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Unable to locate package git
E: Package ‘make’ has no installation candidate
E: Unable to locate package g+
E: Unable to locate package gcc
E: Unable to locate package build-essential
root@wirenboard-AG2YRMHT:~# npm install -g --unsafe-perm node-red
-bash: npm: command not found
HW Revision 6.7.2
Release name2310
Проверьте, есть ли у вас доступ в интернет. Проблем с установкой данных пакетов не должно быть.
Нет доступ есть я в этой сети сейчас, вам пишу выдает по прежнему это
Укажите ревизию контроллера и версию ПО. Как реализован выход контроллера в интернет? Если через роутер, то нет ли ограничений для контроллера?
Покажите пинг с роутером и каким-либо внешним адресом.
Это выше писал, дублирую
HW Revision 6.7.2
Release name2310
Диагностический архив не получается скачать, нажимаю скачать в веб интерфейсе сообщение “Время ожидания вышло.Обновите страницу для повторной попытки”
Пожалуйста не выкладывайте сообщения консоли в виде скриншотов. В виде текста - более чем достаточно.
Напишите: чем разрешаются имена в вашей конфигурации сети. Доступен ли настроенный на контроллере DNS сервер с контроллера?
Подскажите пожалуйста как это сделать
Сделать - что?
Напишите что у вас в сети настроено быть DNS сервером.
Затем - покажите что настроено в контроллере в качестве DNS.
Здравствуйте на контроллере конфиг resolv.conf пустой
конфиг interfaces
#auto generating settings
#auto lo
#iface lo inet loopback
iface eth0 inet static
address 192.168.64.32
netmask 255.255.254.0
gateway 192.168.64.1
hwaddress ether 94:C6:91:91:4D:5A
#dns-nameservers 8.8.8.8 8.8.4.4
iface eth1 inet static
address 192.168.0.2
netmask 255.255.255.0
gateway 192.168.0.1
DNS это я сам только что закомментировал, до этого был незакоментирован и DNS маршрутизатора посмотреть не могу стоит Cisco ASA к ней доступа нет
Здесь имеется ввиду проверка доступа с контроллера данных узлов, а не с компьютера.
Можете команды подсказать? не очень пока силен в линукс
Команды абсолютно такие же, какие вы ввели с компа:
ping 192.168.64.1
и
ping ya.ru
root@wirenboard-AG2YRMHT:~# ping 192.168.64.1
PING 192.168.64.1 (192.168.64.1) 56(84) bytes of data.
64 bytes from 192.168.64.1: icmp_seq=1 ttl=255 time=0.784 ms
64 bytes from 192.168.64.1: icmp_seq=2 ttl=255 time=1.32 ms
64 bytes from 192.168.64.1: icmp_seq=3 ttl=255 time=1.18 ms
64 bytes from 192.168.64.1: icmp_seq=4 ttl=255 time=1.22 ms
64 bytes from 192.168.64.1: icmp_seq=5 ttl=255 time=1.35 ms
64 bytes from 192.168.64.1: icmp_seq=6 ttl=255 time=1.30 ms
64 bytes from 192.168.64.1: icmp_seq=7 ttl=255 time=1.32 ms
64 bytes from 192.168.64.1: icmp_seq=8 ttl=255 time=1.23 ms
64 bytes from 192.168.64.1: icmp_seq=9 ttl=255 time=1.23 ms
64 bytes from 192.168.64.1: icmp_seq=10 ttl=255 time=1.16 ms
64 bytes from 192.168.64.1: icmp_seq=11 ttl=255 time=1.19 ms
64 bytes from 192.168.64.1: icmp_seq=12 ttl=255 time=1.32 ms
64 bytes from 192.168.64.1: icmp_seq=13 ttl=255 time=1.32 ms
64 bytes from 192.168.64.1: icmp_seq=14 ttl=255 time=1.41 ms
^C
— 192.168.64.1 ping statistics —
14 packets transmitted, 14 received, 0% packet loss, time 13018ms
rtt min/avg/max/mdev = 0.784/1.237/1.406/0.143 ms
root@wirenboard-AG2YRMHT:~# ping ya.ru
ping: ya.ru: Name or service not known
да внешний адрес не пингуется((
конфиг resolv сделал
nameserver 192.168.64.1
nameserver 77.88.8.1
nameserver 8.8.8.8
nameserver 8.8.4.4
nameserver 1.1.1.1
конфиг interfeces
#auto lo
hostname Wirenboard
#hwaddress ether 94:C6:91:91:4D:5A
address 192.168.0.2
gateway 192.168.0.1
Скажите это проблема с настройкой сети или все-таки что-то в конфигурации контроллера? Просто сеть не ограничивали и выход в интернет других устройств есть.
В релизе wb-2310 данный файл настройки должен быть пустым. Сетевые настройки уже есть возможность править через веб-интерфейс в “Настройки → Конфигурационные файлы → Сетевые соединения”.
