Не могу установить WB Cloud. В web интерфейсе нет ссылки на подключение к облаку, команда wb-cloud-agent через SSH выдает ошибку
Exception in thread Thread-1: Traceback (most recent call last): Traceback (most recent call last): File "/usr/lib/python3.9/threading.py", line 954, in _bootstrap_inner File "/usr/bin/wb-cloud-agent", line 9, in <module> sys.exit(main.main()) self.run() File "/usr/lib/python3.9/dist-packages/wb/cloud_agent/main.py", line 352, in main File "/usr/lib/python3.9/threading.py", line 892, in run make_start_up_request(settings, mqtt) File "/usr/lib/python3.9/dist-packages/wb/cloud_agent/main.py", line 231, in make_start_up_request self._target(*self._args, **self._kwargs) status_data, http_status = do_curl(settings=settings, method="get", endpoint="agent-start-up/") File "/usr/lib/python3/dist-packages/paho/mqtt/client.py", line 3452, in _thread_main File "/usr/lib/python3.9/dist-packages/wb/cloud_agent/main.py", line 86, in do_curl result = subprocess.run(command, timeout=360, check=True, capture_output=True) File "/usr/lib/python3.9/subprocess.py", line 528, in run raise CalledProcessError(retcode, process.args, subprocess.CalledProcessError: Command '['curl', '--connect-timeout', '45', '--retry', '8', '--retry-delay', '1', '--retry-all-errors', '--cert', '/var/lib/wb-cloud-agent/device_bundle.crt.pem', '--key', 'ATECCx08:00:02:C0:00', '--engine', 'ateccx08', '--key-type', 'ENG', '-w', '|||{"code":"%{response_code}"}', 'https://agent.wirenboard.cloud/api-agent/v1/agent-start-up/']' returned non-zero exit status 6.
версия прошивки 2410, контроллер wirenboard 7
Добрый день
