Коллеги добрый день, есть такая проблема, при попытке обновить прошивку нового WB7 2410 до 2501 (впрочем ка и до любой версии, разными файлами) идет в отказ. Нехочет обновлятся не через веб-морду и консоль. Выдает следующее:
root@wirenboard-AWIHN44X:~# wb-run-update /mnt/data/root/tmp/202504170732_wb-2501_bullseye_wb7x.fit
Thu May 22 21:18:16 UTC 2025: started update from /mnt/data/root/tmp/202504170732_wb-2501_bullseye_wb7x.fit
Description: WirenBoard firmware update
Compatible device: wirenboard,wirenboard-720
Firmware version: 202504170732
Firmware compatible: +single-rootfs +fit-factory-reset +force-repartition +repartition-ramsize-fix +fit-immutable-support +wb8-debug-network-update-fix +wrong-ab-layout-fix +update-from-cloud
Release name: wb-2501
Release suite: stable
Release target: wb7/bullseye
Release repo prefix:
Time of creation: Thu Apr 17 07:35:23 UTC 2025
Checking SHA1 hash of install
SHA1 hash of install ok
32+0 records in
32+0 records out
16384 bytes (16 kB, 16 KiB) copied, 0.000828292 s, 19.8 MB/s
Firmware seems to be compatible with this controller
Extracting install script
Running install script
Console logging enabled; tempfile /tmp/tmp.KrpLByyRUt, final file /mnt/data/root/tmp/wb-console.log will be written on exit
32+0 records in
32+0 records out
16384 bytes (16 kB, 16 KiB) copied, 0.00100567 s, 16.3 MB/s
Checking SHA1 hash of rootfs
SHA1 hash of rootfs ok
rootfs is valid, installing firmware update
Watch logs in the debug console, or in /mnt/data/.wb-update/state/update.log
Rebooting system to install update
Waiting for Wiren Board to boot again…
mv: cannot move ‘/mnt/data/root/tmp/202504170732_wb-2501_bullseye_wb7x.fit’ to ‘/mnt/data/.wb-update/webupd.fit’: Operation not permitted
Нужна помощь!!!
