При накате 2410 вижу
>>> Creating a new parition table
>>> New disk dump will be saved in /tmp/tmp.hbp00k
Partition #2 contains a ext4 signature.
Partition #5 contains a swap signature.
Partition #6 contains a ext4 signature.
Re-reading the partition table failed.: Device or resource busy
>>> Unmounting /mnt/data and saving its mountpoint
[  136.050726]  mmcblk0: p1 p2 p3 p4 < p5 p6 >
>>> Restoring mount of /dev/mmcblk0p6 to /mnt/data
[  136.072171] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
>>> Expanding filesystem on this partition
resize2fs 1.46.2 (28-Feb-2021)
Please run 'e2fsck -f /dev/mmcblk0p2' first.
/tmp/tmp.99fWF0: while force-closing undo file
Overwriting existing filesystem; this can be undone using the command:
    e2undo /tmp/tmp.99fWF0 /dev/mmcblk0p2
>>> Filesystem expantion failed, restoring everything
/tmp/tmp.99fWF0: Corrupt undo file header.
самопроизвольных перезагрузок нет, но по кнопке не выключается…
              прогнал
root@wirenboard-APGGBV4J:~# e2fsck -f /dev/mmcblk0p2
e2fsck 1.46.2 (28-Feb-2021)
Pass 1: Checking inodes, blocks, and sizes
Inode 9 has illegal block(s).  Clear<y>? yes
Illegal block #0 (295238) in inode 9.  CLEARED.
Illegal block #1 (353257) in inode 9.  CLEARED.
Illegal block #2 (411276) in inode 9.  CLEARED.
Illegal block #3 (469295) in inode 9.  CLEARED.
Illegal block #6 (298264) in inode 9.  CLEARED.
Illegal block #7 (356283) in inode 9.  CLEARED.
Illegal block #8 (414302) in inode 9.  CLEARED.
Illegal block #9 (472321) in inode 9.  CLEARED.
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
/lost+found not found.  Create<y>? yes
Pass 4: Checking reference counts
Pass 5: Checking group summary information
Block bitmap differences:  -(24868--24875)
Fix<y>? yes
Free blocks count wrong for group #0 (10, counted=18).
Fix<y>? yes
Free blocks count wrong (75807, counted=75815).
Fix<y>? yes
rootfs1: ***** FILE SYSTEM WAS MODIFIED *****
rootfs1: 27444/65536 files (0.1% non-contiguous), 186329/262144 blocks
              Отлично! Рад что быстро разобрались, давайте теперь решим последнюю проблему, что касается ФС…
              Перенес тему согласно правилам портала.
Попробуйте еще раз установить прошивку. Ошибка повторится?
              Добрый день
На текущий момент работает 2410, обсуждаемой проблемы пока не наблюдаю.
Но это не значит что ее нет. Каким образом я получил постоянный reboot - не понятно. Как была повреждена фс (повторю вашу мантру про журналируемую) - не понятно. Напомню, что контроллер живёт аж за двумя батарейками, проблемы с питанием я исключаю. Сторонний софт принципиально не ставлю на контроллер, для этого рядом трудятся два rpi. Пока я подозреваю сам накопитель.
PS при выделении этой темы в отдельную вы упустили начальную проблему, скопировали только логи моего расследования. Вот тут вся соль, но как обычно поторопились закрыть как решенное, особо не вникая… Странное поведение контроллера 7.4 после обновления
Прошу прислать новый диагностический файл.
Я также переговорю с разработчиками, возможно, они смогут предложить что-то.
              Да, конечно, но я уже обновил контроллер до 2410, сейчас заново все настраиваю… Точно ли нужна новая диагностика? На сколько я понимаю, все уже сильно изменилось и вряд ли он поможет в расследовании проблем с фс?
 (346,6 КБ)
Для получения полной картины необходимо владеть всеми состояниями системы.
Выявлялись ли повторно проблемы с системой? Или после обновления всё работает штатно?
              Добрый день
ТТТ, пока все штатно. Архив из начального треда не помог? Он как раз был снят на “сбойном состоянии”.
К сожалению, явных причин проблемы выявлено не было.
Для анализа ситуации с файловой системой (ФС) потребуется:
- Повторное выявление проблемы.
- Примерное описание действий, выполненных с момента начала работы до обнаружения ошибки.
Однако, скорее всего, данная проблема не побеспокоит вас повторно.
              Очень надеюсь на то что повторно не побеспокоит =) Но как она появилась-то… Обратите внимание на логику… я снял полную диагностику в момент возникновения проблемы - но вы криминала в ней не увидели. Сейчас предлагаете дождаться повторения и… снова снять диагностику? Так там вряд ли будет что-то новое… возможно тут уровень логирования другой нужен?
Важно не выполнять следующую команду до сбора всей необходимой информации:
              Да, хорошо, договорились. Единственная просьба чуть быстрее реагировать на проблемы, а то у меня это единственный контролер и он мне нужен рабочим =) Ждать по два дня пока проснется ТП для меня неприемлемо =(
Помечу данную тему как решённую. Если ситуация повторится, пожалуйста, создайте новую тему и вставьте ссылку на эту для удобства. Спасибо за обращение!
              Думаю да, можно закрывать, я заказал 8.5, а этот экземпляр верну вам.
