Aug 7 09:36:53 wirenboard-AFNMUY2G syslog.info syslogd started: BusyBox v1.22.1
Aug 7 09:36:56 wirenboard-AFNMUY2G user.notice kernel: klogd started: BusyBox v1.22.1 (Debian 1:1.22.0-19+b3)
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.000000] Booting Linux on physical CPU 0x0
Aug 7 09:36:56 wirenboard-AFNMUY2G user.notice kernel: [ 0.000000] Linux version 4.9.22-wb6 (root@wbdevenv) (gcc version 6.3.0 20170516 (Debian 6.3.0-18) ) #2 SMP Wed Jun 10 11:07:45 UTC 2020
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.000000] CPU: div instructions available: patching division code
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.000000] OF: fdt:Machine model: Wiren Board rev. 6.5 (i.MX6UL/ULL)
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.000000] cma: Reserved 16 MiB at 0x9f000000
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.000000] Memory policy: Data cache writealloc
Aug 7 09:36:56 wirenboard-AFNMUY2G user.debug kernel: [ 0.000000] On node 0 totalpages: 131072
Aug 7 09:36:56 wirenboard-AFNMUY2G user.debug kernel: [ 0.000000] free_area_init_node: node 0, pgdat c0b4d840, node_mem_map deab3000
Aug 7 09:36:56 wirenboard-AFNMUY2G user.debug kernel: [ 0.000000] Normal zone: 1152 pages used for memmap
Aug 7 09:36:56 wirenboard-AFNMUY2G user.debug kernel: [ 0.000000] Normal zone: 0 pages reserved
Aug 7 09:36:56 wirenboard-AFNMUY2G user.debug kernel: [ 0.000000] Normal zone: 131072 pages, LIFO batch:31
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.000000] percpu: Embedded 14 pages/cpu @defc7000 s25996 r8192 d23156 u57344
Aug 7 09:36:56 wirenboard-AFNMUY2G user.debug kernel: [ 0.000000] pcpu-alloc: s25996 r8192 d23156 u57344 alloc=14*4096
Aug 7 09:36:56 wirenboard-AFNMUY2G user.debug kernel: [ 0.000000] pcpu-alloc: [0] 0
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 129920
Aug 7 09:36:56 wirenboard-AFNMUY2G user.notice kernel: [ 0.000000] Kernel command line: console=ttymxc0,115200 root=/dev/mmcblk0p3 rootwait ro
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.000000] Memory: 491716K/524288K available (6144K kernel code, 312K rwdata, 2276K rodata, 1024K init, 342K bss, 16188K reserved, 16384K cma-reserved)
Aug 7 09:36:56 wirenboard-AFNMUY2G user.notice kernel: [ 0.000000] Virtual kernel memory layout:
Aug 7 09:36:56 wirenboard-AFNMUY2G user.notice kernel: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
Aug 7 09:36:56 wirenboard-AFNMUY2G user.notice kernel: [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
Aug 7 09:36:56 wirenboard-AFNMUY2G user.notice kernel: [ 0.000000] vmalloc : 0xe0800000 - 0xff800000 ( 496 MB)
Aug 7 09:36:56 wirenboard-AFNMUY2G user.notice kernel: [ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
Aug 7 09:36:56 wirenboard-AFNMUY2G user.notice kernel: [ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
Aug 7 09:36:56 wirenboard-AFNMUY2G user.notice kernel: [ 0.000000] .text : 0xc0008000 - 0xc0700000 (7136 kB)
Aug 7 09:36:56 wirenboard-AFNMUY2G user.notice kernel: [ 0.000000] .init : 0xc0a00000 - 0xc0b00000 (1024 kB)
Aug 7 09:36:56 wirenboard-AFNMUY2G user.notice kernel: [ 0.000000] .data : 0xc0b00000 - 0xc0b4e100 ( 313 kB)
Aug 7 09:36:56 wirenboard-AFNMUY2G user.notice kernel: [ 0.000000] .bss : 0xc0b50000 - 0xc0ba5aec ( 343 kB)
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.000000] Hierarchical RCU implementation.
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.000000] Build-time adjustment of leaf fanout to 32.
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=1
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.000000] NR_IRQS:16 nr_irqs:16 16
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.000000] Switching to timer-based delay loop, resolution 41ns
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.000016] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.000054] clocksource: mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.002556] Console: colour dummy device 80x30
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.002594] Calibrating delay loop (skipped), value calculated using timer frequency… 48.00 BogoMIPS (lpj=240000)
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.002626] pid_max: default: 32768 minimum: 301
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.002891] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.002916] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.004396] CPU: Testing write buffer coherency: ok
Aug 7 09:36:56 wirenboard-AFNMUY2G user.err kernel: [ 0.004965] /cpus/cpu@0 missing clock-frequency property
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.005007] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.005064] Setting up static identity map for 0x80100000 - 0x80100070
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.007658] Brought up 1 CPUs
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.007690] SMP: Total of 1 processors activated (48.00 BogoMIPS).
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.007705] CPU: All CPU(s) started in SVC mode.
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.009150] devtmpfs: initialized
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.036112] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.036901] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.036949] futex hash table entries: 256 (order: 2, 16384 bytes)
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.038334] pinctrl core: initialized pinctrl subsystem
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.040904] NET: Registered protocol family 16
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.042815] DMA: preallocated 256 KiB pool for atomic coherent allocations
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.045622] cpuidle: using governor menu
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.080455] No ATAGs?
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.080510] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.080533] hw-breakpoint: maximum watchpoint size is 8 bytes.
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.082912] imx6ul-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.128975] mxs-dma 1804000.dma-apbh: initialized
Aug 7 09:36:56 wirenboard-AFNMUY2G user.notice kernel: [ 0.133811] SCSI subsystem initialized
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.134417] usbcore: registered new interface driver usbfs
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.134573] usbcore: registered new interface driver hub
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.134834] usbcore: registered new device driver usb
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.136559] i2c-gpio i2c_rtc: using pins 48 (SDA) and 49 (SCL)
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.137485] i2c-gpio i2c_eeprom1: using pins 76 (SDA) and 67 (SCL)
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.138369] i2c-gpio i2c_eeprom2: using pins 70 (SDA) and 71 (SCL)
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.139750] i2c i2c-1: IMX I2C adapter registered
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.139790] i2c i2c-1: can’t use DMA, using PIO instead.
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.140149] Linux video capture interface: v2.00
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.140308] pps_core: LinuxPPS API ver. 1 registered
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.140327] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.140382] PTP clock support registered
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.141102] Advanced Linux Sound Architecture Driver Initialized.
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.143770] clocksource: Switched to clocksource mxc_timer1
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.169590] NET: Registered protocol family 2
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.170854] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.170977] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.171133] TCP: Hash tables configured (established 4096 bind 4096)
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.171249] UDP hash table entries: 256 (order: 1, 8192 bytes)
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.171304] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.171625] NET: Registered protocol family 1
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.172541] RPC: Registered named UNIX socket transport module.
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.172571] RPC: Registered udp transport module.
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.172588] RPC: Registered tcp transport module.
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.172602] RPC: Registered tcp NFSv4.1 backchannel transport module.
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.177549] workingset: timestamp_bits=14 max_order=17 bucket_order=3
Aug 7 09:36:56 wirenboard-AFNMUY2G user.notice kernel: [ 0.197208] NFS: Registering the id_resolver key type
Aug 7 09:36:56 wirenboard-AFNMUY2G user.notice kernel: [ 0.197274] Key type id_resolver registered
Aug 7 09:36:56 wirenboard-AFNMUY2G user.notice kernel: [ 0.197291] Key type id_legacy registered
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.208124] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.208158] io scheduler noop registered (default)
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.208178] io scheduler deadline registered
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.208260] io scheduler cfq registered
Aug 7 09:36:56 wirenboard-AFNMUY2G user.warn kernel: [ 0.215011] imx-sdma 20ec000.sdma: Direct firmware load for imx/sdma/sdma-imx6q.bin failed with error -2
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.215055] imx-sdma 20ec000.sdma: external firmware not found, using ROM firmware
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.224579] 2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 18, base_baud = 5000000) is a IMX
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.803370] console [ttymxc0] enabled
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.809001] 21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 55, base_baud = 5000000) is a IMX
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.819344] 21fc000.serial: ttymxc5 at MMIO 0x21fc000 (irq = 56, base_baud = 5000000) is a IMX
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.862690] imx_rngc 2284000.rngb: Freescale RNGC registered.
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.868835] [drm] Initialized
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.908540] brd: module loaded
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.928327] loop: module loaded
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.936598] at24 5-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.948052] at24 6-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.958913] libphy: Fixed MDIO Bus: probed
Aug 7 09:36:56 wirenboard-AFNMUY2G user.warn kernel: [ 0.965626] 20b4000.ethernet supply phy not found, using dummy regulator
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 0.973636] pps pps0: new PPS source ptp0
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 1.007601] libphy: fec_enet_mii_bus: probed
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 1.013322] fec 20b4000.ethernet eth0: registered PHC device 0
Aug 7 09:36:56 wirenboard-AFNMUY2G user.warn kernel: [ 1.133873] 2188000.ethernet supply phy not found, using dummy regulator
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 1.254900] pps pps1: new PPS source ptp1
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 1.260179] libphy: fec_enet_mii_bus: probed
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 1.268310] fec 2188000.ethernet eth1: registered PHC device 1
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 1.274886] PPP generic driver version 2.4.2
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 1.279718] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 1.286407] ehci-mxc: Freescale On-Chip EHCI Host driver
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 1.292250] usbcore: registered new interface driver usb-storage
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 1.298893] usbcore: registered new interface driver usbserial
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 1.305055] usbcore: registered new interface driver usbserial_generic
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 1.311715] usbserial: USB Serial support registered for generic
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 1.318438] mousedev: PS/2 mouse device common for all mice
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 1.382589] rtc-pcf8563 4-0051: rtc core: registered rtc-pcf8563 as rtc0
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 1.398795] snvs_rtc 20cc000.snvs:snvs-rtc-lp: rtc core: registered 20cc000.snvs:snvs-r as rtc1
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 1.407919] i2c /dev entries driver
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 1.421458] lm75 4-0048: hwmon0: sensor ‘lm75b’
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 1.542595] imx2-wdt 20bc000.wdog: timeout 60 sec (nowayout=0)
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 1.550879] sdhci: Secure Digital Host Controller Interface driver
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 1.557217] sdhci: Copyright© Pierre Ossman
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 1.561604] sdhci-pltfm: SDHCI platform and OF driver helper
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 1.633851] mmc0: SDHCI controller on 2194000.usdhc [2194000.usdhc] using ADMA
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 1.653402] ledtrig-cpu: registered to indicate activity on CPUs
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 1.678162] usbcore: registered new interface driver usbhid
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 1.685930] usbhid: USB HID core driver
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 1.711930] NET: Registered protocol family 10
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 1.719256] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 1.727150] NET: Registered protocol family 17
Aug 7 09:36:56 wirenboard-AFNMUY2G user.notice kernel: [ 1.731821] Key type dns_resolver registered
Aug 7 09:36:56 wirenboard-AFNMUY2G user.notice kernel: [ 1.741214] Registering SWP/SWPB emulation handler
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 1.748228] registered taskstats version 1
Aug 7 09:36:56 wirenboard-AFNMUY2G user.notice kernel: [ 1.770353] random: fast init done
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 1.778763] mmc0: new DDR MMC card at address 0001
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 1.785869] imx_thermal 2000000.aips-bus:tempmon: Industrial CPU temperature grade - max:105C critical:100C passive:95C
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 1.796861] mmcblk0: mmc0:0001 Q2J54A 3.59 GiB
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 1.801844] mmcblk0boot0: mmc0:0001 Q2J54A partition 1 16.0 MiB
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 1.820724] rtc-pcf8563 4-0051: setting system clock to 2020-08-07 09:36:42 UTC (1596793002)
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 1.829219] of_cfs_init
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 1.832030] mmcblk0boot1: mmc0:0001 Q2J54A partition 2 16.0 MiB
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 1.838543] mmcblk0rpmb: mmc0:0001 Q2J54A partition 3 512 KiB
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 1.847574] of_cfs_init: OK
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 1.856128] mmcblk0: p1 p2 p3 p4 < p5 p6 >
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 1.861288] vdd3p0: disabling
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 1.867836] vref-3v3: disabling
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 1.871010] usb1_vbus: disabling
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 1.874399] usb2_vbus: disabling
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 1.877647] ALSA device list:
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 1.880620] No soundcards found.
Aug 7 09:36:56 wirenboard-AFNMUY2G user.err kernel: [ 1.885177] EXT4-fs (mmcblk0p3): couldn’t mount as ext3 due to feature incompatibilities
Aug 7 09:36:56 wirenboard-AFNMUY2G user.err kernel: [ 1.893994] EXT4-fs (mmcblk0p3): couldn’t mount as ext2 due to feature incompatibilities
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 1.909314] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 1.917732] VFS: Mounted root (ext4 filesystem) readonly on device 179:3.
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 1.929649] devtmpfs: mounted
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 1.934130] Freeing unused kernel memory: 1024K (c0a00000 - c0b00000)
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 2.185741] ip_tables: © 2000-2006 Netfilter Core Team
Aug 7 09:36:56 wirenboard-AFNMUY2G daemon.info kernel: [ 2.222498] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
Aug 7 09:36:56 wirenboard-AFNMUY2G daemon.info kernel: [ 2.241687] systemd[1]: Detected architecture arm.
Aug 7 09:36:56 wirenboard-AFNMUY2G daemon.info kernel: [ 2.284836] systemd[1]: Set hostname to .
Aug 7 09:36:56 wirenboard-AFNMUY2G daemon.info kernel: [ 2.917936] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
Aug 7 09:36:56 wirenboard-AFNMUY2G daemon.info kernel: [ 2.954596] systemd[1]: Listening on fsck to fsckd communication Socket.
Aug 7 09:36:56 wirenboard-AFNMUY2G daemon.info kernel: [ 2.994707] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
Aug 7 09:36:56 wirenboard-AFNMUY2G daemon.info kernel: [ 3.034216] systemd[1]: Reached target Paths.
Aug 7 09:36:56 wirenboard-AFNMUY2G daemon.info kernel: [ 3.065907] systemd[1]: Created slice User and Session Slice.
Aug 7 09:36:56 wirenboard-AFNMUY2G daemon.info kernel: [ 3.104669] systemd[1]: Listening on udev Kernel Socket.
Aug 7 09:36:56 wirenboard-AFNMUY2G daemon.info kernel: [ 3.152176] systemd[1]: Reached target Encrypted Volumes.
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 4.152395] EXT4-fs (mmcblk0p3): re-mounted. Opts: errors=remount-ro
Aug 7 09:36:56 wirenboard-AFNMUY2G syslog.info kernel: [ 4.704888] systemd-journald[144]: Received request to flush runtime journal from PID 1
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 6.075162] lirc_dev: IR Remote Control driver registered, major 245
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 6.099591] Driver for 1-wire Dallas network protocol.
Aug 7 09:36:56 wirenboard-AFNMUY2G user.warn kernel: [ 6.155417] lirc_pwm: module is from the staging directory, the quality is unknown, you have been warned.
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 6.240235] lirc_pwm lirc-rfm69: GPIO receiver on pin 77
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 6.297713] lirc_pwm lirc-rfm69: lirc_dev: driver lirc-rfm69 registered at minor = 0
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 6.349635] lirc_pwm lirc-rfm69: probed
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 6.549488] fec 20b4000.ethernet rename2: renamed from eth0
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 6.880489] fec 2188000.ethernet eth0: renamed from eth1
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 6.924079] ci_hdrc ci_hdrc.0: EHCI Host Controller
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 6.929036] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 6.978613] fec 20b4000.ethernet eth1: renamed from rename2
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 7.083950] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 7.118986] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 7.125980] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 7.133214] usb usb1: Product: EHCI Host Controller
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 7.138158] usb usb1: Manufacturer: Linux 4.9.22-wb6 ehci_hcd
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 7.143941] usb usb1: SerialNumber: ci_hdrc.0
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 7.388703] hub 1-0:1.0: USB hub found
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 7.417125] hub 1-0:1.0: 1 port detected
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 7.503920] ci_hdrc ci_hdrc.1: EHCI Host Controller
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 7.557565] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 2
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 7.674071] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 7.714165] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 7.720981] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 7.728335] usb usb2: Product: EHCI Host Controller
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 7.733225] usb usb2: Manufacturer: Linux 4.9.22-wb6 ehci_hcd
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 7.739018] usb usb2: SerialNumber: ci_hdrc.1
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 7.979611] hub 2-0:1.0: USB hub found
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 8.007993] hub 2-0:1.0: 1 port detected
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 8.423933] usb 2-1: new high-speed USB device number 2 using ci_hdrc
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 8.641798] Adding 262140k swap on /dev/mmcblk0p5. Priority:-1 extents:1 across:262140k SS
Aug 7 09:36:56 wirenboard-AFNMUY2G user.info kernel: [ 8.656378] usb 2-1: New USB device found, idVendor=0424, idProduct=2514
