Вижу в логах WARNING: [wbgo_mqtt] MQTT connection lost: pingresp not received
Добрый день. Вижу в лога такие сообщения:
tail -f /var/log/messages
wb-rules[6951]: WARNING: [wbgo_mqtt] MQTT connection lost: pingresp not received, disconnecting
May 29 14:53:03 wirenboard-A3KSWYOC wb-rules[6951]: WARNING: [wbgo_mqtt] Cleaning up token queue
May 29 14:53:03 wirenboard-A3KSWYOC wb-rules[6951]: INFO: [wbgo_mqtt] wb-rules-engine-wirenboard-A3KSWYOC-6951: MQTT connection established
wb-rules[6951]: ERROR: [wbgo_mqtt] MQTT error: publish was broken by timeout
[wb-mqtt-db.service] WARNING: [dblogger] Group data limit is reached: group all, row count 102099, limit 100000
May 29 15:19:52 wirenboard-A3KSWYOC wb-rules[6951]: ERROR: [wbgo_mqtt] MQTT token wait timeout: *mqtt.SubscribeToken (&{{{{0 0} 0 0 0 0} 0x221c700 } [zigbee2mqtt/hall_primary_sw] map[] 1858})
root@wirenboard-A3KSWYOC:~# tail -f /var/log/mosquitto/mosquitto.log
1653797745: New connection from 127.0.0.1 on port 1883.
1653797746: New client connected from 127.0.0.1 as wb-rules-engine-wirenboard-A3KSWYOC-6951 (c1, k30).
1653797791: Socket error on client wb-rules-engine-wirenboard-A3KSWYOC-6951, disconnecting.
1653797796: New connection from 127.0.0.1 on port 1883.
1653797796: New client connected from 127.0.0.1 as wb-rules-engine-wirenboard-A3KSWYOC-6951 (c1, k30).
1653797841: Socket error on client wb-rules-engine-wirenboard-A3KSWYOC-6951, disconnecting.
1653797846: New connection from 127.0.0.1 on port 1883.
1653797846: New client connected from 127.0.0.1 as wb-rules-engine-wirenboard-A3KSWYOC-6951 (c1, k30).
1653797896: Socket error on client wb-rules-engine-wirenboard-A3KSWYOC-6951, disconnecting.
версия софта 2204
Как устранить? С чем связанно? девайсов не много…
Попробуйте: Ошибка при подключении к web ui - #2 от пользователя BrainRoot
Добрый день. Давно уже сделано… не помогает.
Нужно больше информации тогда. Нагрузка на систему (вывод top), диагностический архив, стоит ли на контроллере что-то стороннее и ресурсоемкое.
@Max_Zabolotsky Здравствуйте! Получилось ли решить проблему?
