Все же проблема не только с конденсатором. На одном объекте стоит MAP3E на вводе и смотрите какая там картина:
info: 21:29:41 rss: 40.32MB; status->modbus-rtu->78_1 {“voltage_0x1410”:231.815,“power_load_0x1302”:7.78}
info: 21:29:42 rss: 40.32MB; status->modbus-rtu->78_1 {“voltage_0x1410”:14.487,“power_load_0x1302”:7.95}
info: 21:29:44 rss: 40.32MB; status->modbus-rtu->78_1 {“voltage_0x1410”:231.619,“power_usage_0x1204”:97.14937,“power_load_0x1302”:7.88}
info: 21:29:45 rss: 40.32MB; status->modbus-rtu->78_1 {“voltage_0x1410”:231.835,“power_load_0x1302”:7.68}
info: 21:29:47 rss: 40.32MB; status->modbus-rtu->78_1 {“voltage_0x1410”:231.858,“power_load_0x1302”:7.99}
info: 21:29:48 rss: 40.32MB; status->modbus-rtu->78_1 {“voltage_0x1410”:231.908,“power_usage_0x1204”:97.14938,“power_load_0x1302”:7.72}
info: 21:29:50 rss: 40.32MB; status->modbus-rtu->78_1 {“voltage_0x1410”:231.793,“power_load_0x1302”:7.74}
info: 21:29:51 rss: 40.32MB; status->modbus-rtu->78_1 {“voltage_0x1410”:231.873,“power_load_0x1302”:7.96}
info: 21:29:53 rss: 40.32MB; status->modbus-rtu->78_1 {“voltage_0x1410”:231.862,“power_usage_0x1204”:97.14939,“power_load_0x1302”:7.9}
info: 21:29:54 rss: 40.32MB; status->modbus-rtu->78_1 {“voltage_0x1410”:231.956,“power_load_0x1302”:7.84}
info: 21:29:56 rss: 40.32MB; status->modbus-rtu->78_1 {“voltage_0x1410”:231.957,“power_load_0x1302”:7.79}
info: 21:29:57 rss: 40.32MB; status->modbus-rtu->78_1 {“voltage_0x1410”:231.939,“power_usage_0x1204”:97.1494,“power_load_0x1302”:7.9}
info: 21:29:59 rss: 40.32MB; status->modbus-rtu->78_1 {“voltage_0x1410”:231.965,“amperage_0x1416”:0.1205,“power_load_0x1302”:7.73}
info: 21:30:00 rss: 40.32MB; status->modbus-rtu->78_1 {“voltage_0x1410”:231.898,“power_load_0x1302”:7.79}
info: 21:30:02 rss: 40.32MB; status->modbus-rtu->78_1 {“voltage_0x1410”:231.971,“amperage_0x1416”:0.1203,“power_usage_0x1204”:97.14941,“power_load_0x1302”:7.8}
info: 21:30:03 rss: 40.32MB; status->modbus-rtu->78_1 {“voltage_0x1410”:231.904,“amperage_0x1416”:0.1205,“power_load_0x1302”:8.01}
info: 21:30:05 rss: 40.32MB; status->modbus-rtu->78_1 {“voltage_0x1410”:231.911,“amperage_0x1416”:0.1203,“power_load_0x1302”:7.87}
info: 21:30:07 rss: 40.32MB; status->modbus-rtu->78_1 {“voltage_0x1410”:231.882,“power_usage_0x1204”:97.14942,“power_load_0x1302”:7.9}
info: 21:30:08 rss: 40.32MB; status->modbus-rtu->78_1 {“voltage_0x1410”:231.995,“power_load_0x1302”:7.7}
info: 21:30:10 rss: 40.32MB; status->modbus-rtu->78_1 {“voltage_0x1410”:0.906,“power_load_0x1302”:7.95}
info: 21:30:11 rss: 40.32MB; status->modbus-rtu->78_1 {“voltage_0x1410”:231.96,“power_usage_0x1204”:97.14943,“power_load_0x1302”:7.56}
info: 21:30:13 rss: 40.32MB; status->modbus-rtu->78_1 {“voltage_0x1410”:231.998,“amperage_0x1416”:0.1205,“power_load_0x1302”:8}
info: 21:30:14 rss: 40.32MB; status->modbus-rtu->78_1 {“voltage_0x1410”:231.936,“amperage_0x1416”:0.1203,“power_load_0x1302”:7.71}
info: 21:30:16 rss: 40.32MB; status->modbus-rtu->78_1 {“voltage_0x1410”:231.983,“power_usage_0x1204”:97.14944,“power_load_0x1302”:7.84}
info: 21:30:17 rss: 40.39MB; status->modbus-rtu->78_1 {“voltage_0x1410”:231.994,“amperage_0x1416”:0.1205,“power_load_0x1302”:7.71}
info: 21:30:19 rss: 40.39MB; status->modbus-rtu->78_1 {“voltage_0x1410”:232.134,“amperage_0x1416”:0.1203,“power_load_0x1302”:7.92}
info: 21:30:20 rss: 40.39MB; status->modbus-rtu->78_1 {“voltage_0x1410”:232.139,“power_usage_0x1204”:97.14945,“power_load_0x1302”:7.82}
info: 21:30:22 rss: 40.39MB; status->modbus-rtu->78_1 {“voltage_0x1410”:232.157,“power_load_0x1302”:7.89}
info: 21:30:23 rss: 40.39MB; status->modbus-rtu->78_1 {“voltage_0x1410”:232.053,“power_load_0x1302”:7.72}
info: 21:30:25 rss: 40.39MB; status->modbus-rtu->78_1 {“voltage_0x1410”:0.907,“power_usage_0x1204”:97.14946,“power_load_0x1302”:7.95}
info: 21:30:26 rss: 40.39MB; status->modbus-rtu->78_1 {“voltage_0x1410”:232.11,“amperage_0x1416”:0.1205,“power_load_0x1302”:8.05}
info: 21:30:28 rss: 40.39MB; status->modbus-rtu->78_1 {“voltage_0x1410”:232.129,“amperage_0x1416”:0.1203,“power_load_0x1302”:7.91}
info: 21:30:29 rss: 40.37MB; status->modbus-rtu->78_1 {“voltage_0x1410”:232.128,“amperage_0x1416”:0.1205,“power_usage_0x1204”:97.14947,“power_load_0x1302”:7.99}
info: 21:30:31 rss: 40.37MB; status->modbus-rtu->78_1 {“voltage_0x1410”:232.064,“amperage_0x1416”:0.1203,“power_load_0x1302”:7.9}
Смотреть на переменную voltage_0x1410. Никаких обрывов конечно же там нет.
Куплен относительно недавно из восстановленных.
После вводного есть еще MAP3E, и уже они показывают все корректно. Вот пример:
info: 21:33:48 rss: 55.55MB; status->modbus-rtu->141_1 {“voltage_0x1410”:230.842,“power_usage_0x1204”:232.72148,“power_load_0x1302”:113.99}
info: 21:33:49 rss: 40.14MB; status->modbus-rtu->78_1 {“voltage_0x1410”:14.49,“power_load_0x1302”:8.11}
Может это брак все-таки?
