После удаления старых сетевых соединений контроллер подключился с помощю новых, а затем исчез. Подключиться к нему обычным способом не удалось, только через Debug.
Судя по логу, контроллер постоянно перезагружается.
Что с этим можно сделать?
[ 9.516731] Driver for 1-wire Dallas network protocol.
[ 9.618559] gpio-11 (onewire_w1): enforced open drain please flag it properle
[ 9.691100] gpio-108 (onewire_w2): enforced open drain please flag it propere
[ OK ] Found device /dev/ttymxc0.
[ 10.494274] fec 20b4000.ethernet eth1: renamed from ethFEC0
[ 11.206219] fec 2188000.ethernet eth0: renamed from ethFEC1
[ 11.216838] imx_usb 2184000.usb: No over current polarity defined
[ 11.322722] ci_hdrc ci_hdrc.0: EHCI Host Controller
[ 11.360160] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
[ 11.490089] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[ 11.547080] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, b0
[ 11.555450] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber1
[ 11.562712] usb usb1: Product: EHCI Host Controller
[ 11.567597] usb usb1: Manufacturer: Linux 5.10.35-wb142 ehci_hcd
[ 11.573629] usb usb1: SerialNumber: ci_hdrc.0
[ 11.836306] hub 1-0:1.0: USB hub found
[ 11.878958] hub 1-0:1.0: 1 port detected
[ 11.980692] ci_hdrc ci_hdrc.1: EHCI Host Controller
[ 12.004555] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 2
[ 12.130108] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[ 12.160256] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, b0
[ 12.168547] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber1
[ 12.175849] usb usb2: Product: EHCI Host Controller
[ 12.180758] usb usb2: Manufacturer: Linux 5.10.35-wb142 ehci_hcd
[ 12.186787] usb usb2: SerialNumber: ci_hdrc.1
[ 12.320159] usb usb1-port1: over-current condition
[ 12.530938] hub 2-0:1.0: USB hub found
[ 12.576040] hub 2-0:1.0: 1 port detected
[ 13.000104] usb 2-1: new high-speed USB device number 2 using ci_hdrc
[ 13.240795] usb 2-1: New USB device found, idVendor=0424, idProduct=2514, bc3
[ 13.249041] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 13.408424] hub 2-1:1.0: USB hub found
[ 13.456670] hub 2-1:1.0: 4 ports detected
[ 13.830079] usb 2-1.1: new high-speed USB device number 3 using ci_hdrc
[ 13.991282] usb 2-1.1: New USB device found, idVendor=0bda, idProduct=b720, 0
[ 13.999680] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumbe3
[ 14.007063] usb 2-1.1: Product: 802.11n WLAN Adapter
[ 14.012075] usb 2-1.1: Manufacturer: Realtek
[ 14.016351] usb 2-1.1: SerialNumber: 00e04c000001
[ OK ] Found device /dev/mmcblk0p5.
[ OK ] Found device /dev/mmcblk0p6.
[ 14.425951] cfg80211: Loading compiled-in X.509 certificates for regulatory e
[ 14.444870] Bluetooth: Core ver 2.22
[ 14.448603] NET: Registered protocol family 31
[ 14.453138] Bluetooth: HCI device and connection manager initialized
[ 14.488914] Bluetooth: HCI socket layer initialized
[ 14.510119] Bluetooth: L2CAP socket layer initialized
[ 14.515264] Bluetooth: SCO socket layer initialized
[ 14.553622] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 14.613281] usbcore: registered new interface driver btusb
[ 14.633936] Bluetooth: hci0: RTL: examining hci_ver=06 hci_rev=000b lmp_ver=3
[ 14.644281] Bluetooth: hci0: RTL: rom_version status=0 version=1
[ 14.650395] Bluetooth: hci0: RTL: loading rtl_bt/rtl8723b_fw.bin
[ 14.661228] Bluetooth: hci0: RTL: loading rtl_bt/rtl8723b_config.bin
[ 14.667764] bluetooth hci0: Direct firmware load for rtl_bt/rtl8723b_config.2
[ 14.677104] Bluetooth: hci0: RTL: cfg_sz -2, total sz 22496
[ 14.726523] cfg80211: loaded regulatory.db is malformed or signature is missd
[ OK ] Listening on Load/Save RF ¬タᆭitch Status /dev/rfkill Watch.
Activating swap /dev/mmcblk0p5...
Starting File System Check on /dev/mmcblk0p6...
Starting Load/Save RF Kill Switch Status...
[ 15.269777] RTL871X: module init start
[ 15.273611] RTL871X: rtl8723bu BT-Coex version = BTCOEX20140507-4E40
[ 15.481326] RTL871X: rtw_ndev_init(wlan0)
[ 15.493124] RTL871X: rtw_ndev_init(wlan1)
[ 15.505089] usbcore: registered new interface driver rtl8723bu
[ 15.511129] RTL871X: module init ret=0
[ 15.516259] Bluetooth: hci0: RTL: fw version 0x0e2f9f73
[ 15.583798] Adding 262140k swap on /dev/mmcblk0p5. Priority:-2 extents:1 acc
[ 15.738596] usbcore: registered new interface driver rtl8xxxu
[ OK ] Activated swap /dev/mmcblk0p5.
[ OK ] Finished File System Check on /dev/mmcblk0p6.
[ OK ] Started Load/Save RF Kill Switch Status.
[ OK ] Reached target Swap.
Mounting /mnt/data...
[ 16.537150] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. d
[ OK ] Mounted /mnt/data.
Mounting /var/log...
[ OK ] Mounted /var/log.
[ OK ] Reached target Local File Systems.
Starting Flush Journal to Persistent Storage...
Starting prepare mounts and symlinks to config files...
[ 16.837216] systemd-journald[121]: Received client request to flush runtime .
[ OK ] Finished Flush Journal to Persistent Storage.
[ OK ] Finished prepare mounts and symlinks to config files.
Starting Create Volatile Files and Directories...
[ OK ] Finished Create Volatile Files and Directories.
Starting Update UTMP about System Boot/Shutdown...
[ OK ] Finished Update UTMP about System Boot/Shutdown.
[ OK ] Reached target System Initialization.
[ OK ] Started Monitor directorie¬タᆭ templates for wb-mqtt-serial.
[ OK ] Started Daily apt download activities.
[ OK ] Started Daily apt upgrade and clean activities.
[ OK ] Started Periodic ext4 Onli¬タᆭata Check for All Filesystems.
[ OK ] Started Discard unused blocks once a week.
[ OK ] Started Daily rotation of log files.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Paths.
[ OK ] Reached target Timers.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Listening on fcgiwrap Socket.
[ OK ] Listening on KNX Daemon (socket).
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
Starting Bluetooth service...
[ OK ] Started Regular background program processing daemon.
[ OK ] Started D-Bus System Message Bus.
Starting Network Manager...
Starting Remove Stale Onli¬タᆭt4 Metadata Check Snapshots...
Starting LSB: iRidium Server auto start script...
Starting Authorization Manager...
Starting User Login Management...
[ OK ] Started watch config files.
Starting Initialize Wiren Board Device Tree overlays...
[ OK ] Started Generates wb-mqtt-¬タᆭ UI schema for wb-mqtt-confed.
[ 19.641715] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 19.647054] Bluetooth: BNEP filters: protocol multicast
Starting Avahi mDNS/DNS-SD Stack...
[ 19.790089] Bluetooth: BNEP socket layer initialized
Starting WPA supplicant...
[ OK ] Started Authorization Manager.
[ OK ] Started Bluetooth service.
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ OK ] Reached target Bluetooth.
Starting Modem Manager...
Starting Hostname Service...
[ OK ] Started WPA supplicant.
[ OK ] Started User Login Management.
[ OK ] Started Hostname Service.
[ OK ] Started Modem Manager.
[ OK ] Started LSB: iRidium Server auto start script.
[ 43.494619] 21f4000.serial: ttymxc4 at MMIO 0x21f4000 (irq = 224, base_baud X
[ *** ] (1 of 3) A start job is running for Network Manager (43s / 1min 44s)
[ OK ] Finished Initialize Wiren Board Device Tree overlays.
Starting Raise network interfaces...
Starting Power on GSM modem...
Starting KNXD Configurator for Wiren Board...
[ OK ] Finished Raise network interfaces.
[ INFO ] Skipped Power on GSM modem.
[ OK ] Started Network Manager.
[ OK ] Reached target Network.
Starting Network Manager Wait Online...
Starting dnsmasq - A light¬タᆭDHCP and caching DNS server...
Starting Access point and ¬タᆭrver for Wi-Fi and Ethernet...
Starting KNX Daemon...
Starting Mosquitto MQTT Broker...
Starting Network Time Service...
Starting OpenBSD Secure Shell server...
Starting Permit User Sessions...
[ OK ] Started Network connection¬タᆭrvice for Wiren Board devices.
Starting MQTT Driver for ADC...
Starting MQTT Driver for GPIO-controlled switches...
[ OK ] Started MQTT Driver for serial devices.
[ OK ] Started Kernel 1-Wire MQTT driver for WB-HomA.
[ INFO ] Skipped dnsmasq - A lightw¬タᆭt DHCP and caching DNS server.
[ INFO ] Skipped Access point and a¬タᆭserver for Wi-Fi and Ethernet.
[FAILED] Failed to start KNX Daemon.
See 'systemctl status knxd.service' for details.
[ OK ] Started Network Time Service.
[ OK ] Finished Permit User Sessions.
[FAILED] Failed to start KNXD Configurator for Wiren Board.
See 'systemctl status wb-knxd-config.service' for details.
[ OK ] Reached target Host and Network Name Lookups.
[ OK ] Started Getty on tty1.
Starting A high performanc¬タᆭ and a reverse proxy server...
[ OK ] Started Serial Getty on ttymxc0.
[ OK ] Reached target Login Prompts.
[ OK ] Started Wiren Board MQTT KNX bridge.
[ OK ] Started OpenBSD Secure Shell server.
[ OK ] Started Mosquitto MQTT Broker.
[ OK ] Started Wiren Board modbus devices manager.
[ OK ] Started one-click diagnost¬タᆭ generating archive with data.
[ OK ] Started Wiren Board configuration editor backend.
[ OK ] Started Wiren Board database logger.
[ OK ] Started Wiren Board journald to MQTT gateway.
Starting Wiren Board MQTT to Modbus TCP gateway...
[ OK ] Started metrics sender..
[ OK ] Started Virtual MQTT devic¬タᆭr Network Manager connections.
Starting Wiren Board MQTT to OPC UA gateway...
[ OK ] Started MQTT Rule engine for Wiren Board.
[ OK ] Started Wiren Board firmware update service.
Debian GNU/Linux 11 wirenboard-AAQ5JZBR ttymxc0
wirenboard-AAQ5JZBR login: [ 91.210217] SMSC LAN8710/LAN8720 2188000.ethernet)
[ OK ] Removed slice system-modprobe.slice.
[ OK ] Stopped target Bluetooth.
[ OK ] Stopped target Timers.
[ OK ] Stopped Daily apt upgrade and clean activities.
[ OK ] Stopped Daily apt download activities.
[ OK ] Stopped Periodic ext4 Onli¬タᆭata Check for All Filesystems.
[ OK ] Stopped Discard unused blocks once a week.
[ OK ] Stopped Daily rotation of log files.
[ 92.662956] Micrel KSZ8081 or KSZ8091 2188000.ethernet-2:03: attached PHY dr)
[ OK ] Stopped Daily Cleanup of Temporary Directories.
[ OK ] Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
Stopping Bluetooth service...
Stopping Hostname Service...
Stopping Load/Save Random Seed...
[ 93.610906] fec 2188000.ethernet eth0: Link is Up - 100Mbps/Full - flow contf
[ OK ] Stopped target Login Prompts.
Stopping Modem Manager...
[ 93.787828] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Stopping Avahi mDNS/DNS-SD Stack...
Stopping Regular background program processing daemon...
Stopping Getty on tty1...
Stopping LSB: iRidium Server auto start script...
Stopping Serial Getty on ttymxc0...
Stopping User Login Management...
Stopping Network connectio¬タᆭice for Wiren Board devices...
Stopping Wiren Board modbus devices manager...
Stopping one-click diagnos¬タᆭenerating archive with data...
Stopping Network Time Service...
Stopping OpenBSD Secure Shell server...
Stopping Wiren Board configuration editor backend...
Stopping Wiren Board database logger...
Stopping Wiren Board MQTT KNX bridge...
Stopping Wiren Board journald to MQTT gateway...
Stopping metrics sender....
Stopping Virtual MQTT devi¬タᆭNetwork Manager connections...
Stopping Wiren Board MQTT to OPC UA gateway...
Stopping Generates wb-mqtt¬タᆭI schema for wb-mqtt-confed...
[ OK ] Stopped Kernel 1-Wire MQTT driver for WB-HomA.
Stopping MQTT Rule engine for Wiren Board...
Stopping Wiren Board firmware update service...
[ OK ] Stopped Bluetooth service.
[ OK ] Stopped Regular background program processing daemon.
[ OK ] Stopped User Login Management.
[ OK ] Stopped Avahi mDNS/DNS-SD Stack.
[ OK ] Stopped Modem Manager.
[ OK ] Stopped Network Manager Wait Online.
[ OK ] Stopped Network connection¬タᆭrvice for Wiren Board devices.
[ OK ] Stopped MQTT Driver for ADC.
[ OK ] Stopped MQTT Driver for GPIO-controlled switches.
[ OK ] Stopped Network Time Service.
[ OK ] Stopped OpenBSD Secure Shell server.
[ OK ] Stopped Getty on tty1.
[ OK ] Stopped Serial Getty on ttymxc0.
[ OK ] Stopped Hostname Service.
[ OK ] Stopped Wiren Board modbus devices manager.
[ OK ] Stopped one-click diagnost¬タᆭ generating archive with data.
[ OK ] Stopped Wiren Board configuration editor backend.
[ OK ] Stopped Wiren Board journald to MQTT gateway.
[ OK ] Stopped Wiren Board MQTT to Modbus TCP gateway.
[ OK ] Stopped metrics sender..
[ OK ] Stopped Virtual MQTT devic¬タᆭr Network Manager connections.
[ OK ] Stopped Wiren Board firmware update service.
[ OK ] Stopped A high performance¬タᆭer and a reverse proxy server.
[ OK ] Stopped Load/Save Random Seed.
[ OK ] Stopped LSB: iRidium Server auto start script.
[ OK ] Removed slice system-getty.slice.
[ OK ] Removed slice system-serial\x2dgetty.slice.
[ OK ] Stopped target Host and Network Name Lookups.
Stopping Authorization Manager...
Stopping Permit User Sessions...
Stopping MQTT Driver for serial devices...
[ OK ] Stopped Authorization Manager.
[ OK ] Stopped Permit User Sessions.
[ OK ] Stopped target Remote File Systems.
[ OK ] Stopped MQTT Rule engine for Wiren Board.
[ OK ] Stopped Wiren Board MQTT to OPC UA gateway.
[ OK ] Stopped Wiren Board MQTT KNX bridge.
[ OK ] Stopped KNX Daemon.
[ OK ] Stopped Remove Stale Onlin¬タᆭext4 Metadata Check Snapshots.
[** ] (1 of 3) A stop job is running for ¬タᆭd database logger (22s / 1min 4)[ 107.474586] RTL871X: assoc success
[* ] (2 [ 107.501161] RTL871X: set group key camid:1, addr:00:00:00:00:00:P
[ OK ] Stopped MQTT Driver for serial devices.
[ OK ] Stopped Generates wb-mqtt-¬タᆭ UI schema for wb-mqtt-confed.
[ OK ] Stopped Wiren Board database logger.
Stopping Mosquitto MQTT Broker...
[ OK ] Stopped Mosquitto MQTT Broker.
[ OK ] Stopped target Network.
Stopping Network Manager...
Stopping Raise network interfaces...
Stopping WPA supplicant...
[ OK ] Stopped WPA supplicant.
[ OK ] Stopped Raise network interfaces.
[ OK ] Stopped Initialize Wiren Board Device Tree overlays.
Stopping watch config files...
[ OK ] Stopped watch config files.
[ OK ] Stopped Network Manager.
Stopping D-Bus System Message Bus...
[ OK ] Stopped D-Bus System Message Bus.
[ OK ] Stopped target Basic System.
[ OK ] Stopped target Paths.
[ OK ] Stopped Monitor directorie¬タᆭ templates for wb-mqtt-serial.
[ OK ] Stopped target Slices.
[ OK ] Removed slice User and Session Slice.
[ OK ] Stopped target Sockets.
[ OK ] Closed Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Closed D-Bus System Message Bus Socket.
[ OK ] Closed fcgiwrap Socket.
[ OK ] Closed KNX Daemon (socket).
[ OK ] Stopped target System Initialization.
[ OK ] Stopped target Local Encrypted Volumes.
[ OK ] Stopped Dispatch Password ¬タᆭts to Console Directory Watch.
[ OK ] Stopped Forward Password R¬タᆭuests to Wall Directory Watch.
[ OK ] Stopped target Swap.
Deactivating swap /dev/dis¬タᆭmmc-W62704_0x36f27e35-part5...
[ OK ] Stopped Apply Kernel Variables.
[ OK ] Stopped Load Kernel Modules.
Stopping Update UTMP about System Boot/Shutdown...
[ OK ] Deactivated swap /dev/disk/by-partuuid/042737dc-05.
[ OK ] Deactivated swap /dev/disk¬タᆭth/platform-2194000.mmc-part5.
[ OK ] Deactivated swap /dev/disk¬タᆭ6-ed35-449f-b1a0-75f3fb91744c.
[ OK ] Deactivated swap /dev/disk¬タᆭd/mmc-W62704_0x36f27e35-part5.
[ OK ] Deactivated swap /dev/mmcblk0p5.
[ OK ] Stopped Update UTMP about System Boot/Shutdown.
[ OK ] Stopped Create Volatile Files and Directories.
Stopping Flush Journal to Persistent Storage...
Stopping prepare mounts and symlinks to config files...
[ OK ] Stopped prepare mounts and symlinks to config files.
[ 187.918483] systemd-journald[121]: Received client request to relinquish /va.
[ OK ] Stopped target Local File Systems.
[ OK ] Unset automount mnt-sdcard.automount.
[ OK ] Stopped Flush Journal to Persistent Storage.
Unmounting /var/log...
[ OK ] Unmounted /var/log.
Unmounting /mnt/data...
[ OK ] Unmounted /mnt/data.
[ OK ] Reached target Unmount All Filesystems.
[ OK ] Stopped File System Check on /dev/mmcblk0p6.
[ OK ] Removed slice system-systemd\x2dfsck.slice.
[ OK ] Stopped target Local File Systems (Pre).
[ OK ] Stopped Create Static Device Nodes in /dev.
[ OK ] Stopped Create System Users.
[ OK ] Stopped Remount Root and Kernel File Systems.
[ OK ] Stopped File System Check on Root Device.
[ OK ] Reached target Shutdown.
[ OK ] Reached target Final Step.
[ OK ] Finished Reboot.
[ OK ] Reached target Reboot.
[ 188.884079] watchdog: watchdog0: watchdog did not stop!
[ 188.961875] systemd-shutdown[1]: Syncing filesystems and block devices.
[ 188.972391] systemd-shutdown[1]: Sending SIGTERM to remaining processes...
[ 188.991234] systemd-journald[121]: Received SIGTERM from PID 1 (systemd-shut.
[ 189.027560] systemd-shutdown[1]: Sending SIGKILL to remaining processes...
[ 189.061964] systemd-shutdown[1]: Using hardware watchdog 'imx2+ watchdog', vg
[ 189.086738] systemd-shutdown[1]: Unmounting file systems.
[ 189.104437] [4585]: Remounting '/' read-only in with options 'discard,errors.
[ 189.138979] EXT4-fs (mmcblk0p3): re-mounted. Opts: discard,errors=remount-ro
[ 189.155746] systemd-shutdown[1]: All filesystems unmounted.
[ 189.161608] systemd-shutdown[1]: Deactivating swaps.
[ 189.166906] systemd-shutdown[1]: All swaps deactivated.
[ 189.172320] systemd-shutdown[1]: Detaching loop devices.
[ 189.187017] systemd-shutdown[1]: All loop devices detached.
[ 189.192831] systemd-shutdown[1]: Stopping MD devices.
[ 189.198585] systemd-shutdown[1]: All MD devices stopped.
[ 189.204124] systemd-shutdown[1]: Detaching DM devices.
[ 189.209918] systemd-shutdown[1]: All DM devices detached.
[ 189.215496] systemd-shutdown[1]: All filesystems, swaps, loop devices, MD de.
[ 189.243412] systemd-shutdown[1]: Syncing filesystems and block devices.
[ 189.254381] systemd-shutdown[1]: Rebooting.
[ 189.260443] ci_hdrc ci_hdrc.0: remove, state 4
[ 189.264917] usb usb1: USB disconnect, device number 1
[ 189.271038] ci_hdrc ci_hdrc.0: USB bus 1 deregistered
[ 189.308344] ci_hdrc ci_hdrc.1: remove, state 1
[ 189.312941] usb usb2: USB disconnect, device number 1
[ 189.318005] usb 2-1: USB disconnect, device number 2
[ 189.323001] usb 2-1.1: USB disconnect, device number 3
[ 189.333443] RTL871X: rtw_ndev_uninit(wlan0)
[ 189.339129] RTL871X: rtw_ndev_uninit(wlan1)
[ 189.344556] RTL871X: rtw_cmd_thread: DriverStopped(1) SurpriseRemoved(1) bre1
[ 189.352948] RTL871X: rtw_dev_unload: driver not in IPS
[ 189.364266] ci_hdrc ci_hdrc.1: USB bus 2 deregistered
[ 189.369554] imx2-wdt 20bc000.watchdog: Device shutdown: Expect reboot!
[ 189.376235] reboot: Restarting system
U-Boot 2017.03-1.0.1-gf543a623ed (Mar 14 2019 - 14:32:12 +0000)
CPU: Freescale i.MX6ULL rev1.1 792 MHz (running at 396 MHz)
CPU: Industrial temperature grade (-40C to 105C) at 63C
Reset cause: WDOG
Model: Wiren Board rev. 6.1 (i.MX6UL)
Board: Wiren Board MX6UL
DRAM: 512 MiB
MMC: FSL_SDHC: 0
Using default environment
In: serial
Out: serial
Err: serial
EEPROM #0 MAC: 80:1f:12:48:d7:f2
EEPROM #1 MAC: 80:1f:12:48:cc:d7
Net: eth0: ethernet@02188000
Hit any key to stop autoboot: 0
Checking if there is a USB storage with update file wb6_update.fit
dev: usb1_vbus @ regulator@0
starting USB...
USB0: USB EHCI 1.00
USB1: USB EHCI 1.00
scanning bus 0 for devices... 1 USB Device(s) found
scanning bus 1 for devices... EHCI timed out on TD - token=0x80008c80
unable to get device descriptor (error=-1)
scanning usb for storage devices... 0 Storage Device(s) found
No storage devices, perhaps not 'usb start'ed..?
No USB update detected, continuing boot
switch to partitions #0, OK
mmc0(part 0) is current device
SD/MMC found on device 0
322 bytes read in 63 ms (4.9 KiB/s)
Importing environment from 0x82000000...
Checking if uenvcmd is set ...
Running default loadzimage ...
6304344 bytes read in 423 ms (14.2 MiB/s)
MMC read: dev # 0, block # 2016, count 32 ... 32 blocks read: OK
Reading overlays list from eMMC
Reading factory fdt name from eMMC
Loading factory fdt imx6ul-wirenboard65
46062 bytes read in 164 ms (273.4 KiB/s)
670 bytes read in 69 ms (8.8 KiB/s)
Applying DT overlay wb6-gsm-sim800
597 bytes read in 73 ms (7.8 KiB/s)
Applying DT overlay wb6-wifi-rtl8723bu
509 bytes read in 151 ms (2.9 KiB/s)
Applying DT overlay wb6-noradio
334 bytes read in 105 ms (2.9 KiB/s)
Applying DT overlay wb6-eth1
254 bytes read in 176 ms (1000 Bytes/s)
Applying DT overlay temp-industrial
Applying extra overlay
Booting from mmc ...
Kernel image @ 0x82000000 [ 0x000000 - 0x603258 ]
## Flattened Device Tree blob at 83000000
Booting using the fdt blob at 0x83000000
Loading Device Tree to 9ef33000, end 9ef55fff ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.10.35-wb142 (jenkins@wbdevenv) (arm-linux-gnueab3
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instructie
[ 0.000000] OF: fdt: Machine model: Wiren Board rev. 6.5 (i.MX6UL/ULL)
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] cma: Reserved 16 MiB at 0x9f000000
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x0000000080000000-0x000000009fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000009fffffff]
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 129920
[ 0.000000] Kernel command line: console=ttymxc0,115200 root=/dev/mmcblk0p3 o
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, )
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, l)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 489364K/524288K available (8192K kernel code, 728K rwdat)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] random: get_random_bytes called from start_kernel+0x234/0x3dc wi0
[ 0.000000] Switching to timer-based delay loop, resolution 41ns
[ 0.000018] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 8947s
[ 0.000059] clocksource: mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffffs
[ 0.002738] Console: colour dummy device 80x30
[ 0.002802] Calibrating delay loop (skipped), value calculated using timer f)
[ 0.002840] pid_max: default: 32768 minimum: 301
[ 0.003238] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, line)
[ 0.003273] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes,)
[ 0.004969] CPU: Testing write buffer coherency: ok
[ 0.006193] Setting up static identity map for 0x80100000 - 0x80100078
[ 0.007073] devtmpfs: initialized
[ 0.024455] VFP support v0.3: implementor 41 architecture 2 part 30 variant 5
[ 0.024953] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ms
[ 0.024996] futex hash table entries: 256 (order: -1, 3072 bytes, linear)
[ 0.026361] pinctrl core: initialized pinctrl subsystem
[ 0.028309] NET: Registered protocol family 16
[ 0.030539] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.032497] thermal_sys: Registered thermal governor 'step_wise'
[ 0.032767] cpuidle: using governor menu
[ 0.195283] vdd1p1: supplied by regulator-dummy
[ 0.206299] vdd3p0: supplied by regulator-dummy
[ 0.217327] cpu: supplied by regulator-dummy
[ 0.228396] vddsoc: supplied by regulator-dummy
[ 0.558310] No ATAGs?
[ 0.558369] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint.
[ 0.558389] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.558957] debugfs: Directory 'dummy-iomuxc-gpr@20e4000' with parent 'regma!
[ 0.559566] imx6ul-pinctrl 20e0000.pinctrl: initialized IMX pinctrl driver
[ 0.561091] imx6ul-pinctrl 2290000.iomuxc-snvs: no groups defined in /soc/bu0
[ 0.561131] imx6ul-pinctrl 2290000.iomuxc-snvs: initialized IMX pinctrl drivr
[ 0.603390] mxs-dma 1804000.dma-apbh: initialized
[ 0.608611] SCSI subsystem initialized
[ 0.609091] usbcore: registered new interface driver usbfs
[ 0.609208] usbcore: registered new interface driver hub
