Лампочка: 0.5 сек. зеленая, 4 сек. желтая, потом мигает красным до бесконечности.
Лог с момента включения:
0
MMC0: Command 8 timeout (status 0xf03c4020)
MMC0: Command 55 timeout (status 0xf02c4020)
switch to partitions #0, OK
mmc0(part 0) is current device
SD/MMC found on device 0
322 bytes read in 125 ms (2 KiB/s)
Importing environment from mmc (uEnv.txt)...
Checking if uenvcmd is set ...
Running default loadzimage ...
3833432 bytes read in 1341 ms (2.7 MiB/s)
40668 bytes read in 910 ms (43 KiB/s)
Booting from mmc ...
Kernel image @ 0x42000000 [ 0x000000 - 0x3a7e58 ]
## Flattened Device Tree blob at 41000000
Booting using the fdt blob at 0x41000000
Loading Device Tree to 47b51000, end 47b5dedb ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.22-wb2 (root@wbdevenv) (gcc version 6.3.0 20170516 (Debian 6.3.0-18) ) #2 Sat Jan 26 11:30:10 UTC 2019
[ 0.000000] CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=0005317f
[ 0.000000] CPU: VIVT data cache, VIVT instruction cache
[ 0.000000] OF: fdt:Machine model: Wiren Board rev. 5.8 (i.MX28)
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
[ 0.000000] Kernel command line: console=ttyAMA0,115200 ro rootwait fixrtc root=/dev/mmcblk0p3 rootfstype=ext4 video=
[ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Memory: 122700K/131072K available (4569K kernel code, 204K rwdata, 1664K rodata, 160K init, 286K bss, 8372K reserved, 0K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xc8800000 - 0xff800000 ( 880 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xc8000000 ( 128 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .text : 0xc0008000 - 0xc047e9b0 (4571 kB)
[ 0.000000] .init : 0xc0642000 - 0xc066a000 ( 160 kB)
[ 0.000000] .data : 0xc066a000 - 0xc069d2c0 ( 205 kB)
[ 0.000000] .bss : 0xc069d2c0 - 0xc06e4e70 ( 287 kB)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] clocksource: mxs_timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000020] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000688] Console: colour dummy device 80x30
[ 0.000754] Calibrating delay loop... 226.09 BogoMIPS (lpj=1130496)
[ 0.080301] pid_max: default: 32768 minimum: 301
[ 0.080573] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.080618] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.082198] CPU: Testing write buffer coherency: ok
[ 0.083008] Setting up static identity map for 0x40008400 - 0x40008458
[ 0.086695] devtmpfs: initialized
[ 0.117574] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.117640] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.117995] pinctrl core: initialized pinctrl subsystem
[ 0.120767] NET: Registered protocol family 16
[ 0.122106] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.192997] Serial: AMBA PL011 UART driver
[ 0.193824] 80074000.serial: ttyAMA0 at MMIO 0x80074000 (irq = 234, base_baud = 0) is a PL011 rev2
[ 0.456783] console [ttyAMA0] enabled
[ 0.484265] mxs-dma 80004000.dma-apbh: initialized
[ 0.494361] mxs-dma 80024000.dma-apbx: initialized
[ 0.504081] usbcore: registered new interface driver usbfs
[ 0.509915] usbcore: registered new interface driver hub
[ 0.515499] usbcore: registered new device driver usb
[ 0.522204] i2c-gpio i2c_rtc_wb59@0: using pins 85 (SDA) and 90 (SCL)
[ 0.530439] Linux video capture interface: v2.00
[ 0.535403] pps_core: LinuxPPS API ver. 1 registered
[ 0.540394] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.549689] PTP clock support registered
[ 0.554549] Advanced Linux Sound Architecture Driver Initialized.
[ 0.563025] clocksource: Switched to clocksource mxs_timer
[ 0.605246] NET: Registered protocol family 2
[ 0.611187] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.618337] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.624814] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.631369] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.637345] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.644053] NET: Registered protocol family 1
[ 0.649351] RPC: Registered named UNIX socket transport module.
[ 0.655416] RPC: Registered udp transport module.
[ 0.660145] RPC: Registered tcp transport module.
[ 0.664936] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.671901] NetWinder Floating Point Emulator V0.97 (double precision)
[ 0.681465] workingset: timestamp_bits=30 max_order=15 bucket_order=0
[ 0.734534] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.741969] io scheduler noop registered (default)
[ 0.750957] 8006a000.serial: ttyAPP0 at MMIO 0x8006a000 (irq = 229, base_baud = 1500000) is a 8006a000.serial
[ 0.761937] mxs-auart 8006a000.serial: Found APPUART 3.1.0
[ 0.768275] 8006c000.serial: ttyAPP1 at MMIO 0x8006c000 (irq = 230, base_baud = 1500000) is a 8006c000.serial
[ 0.779299] mxs-auart 8006c000.serial: Found APPUART 3.1.0
[ 0.785705] 8006e000.serial: ttyAPP2 at MMIO 0x8006e000 (irq = 231, base_baud = 1500000) is a 8006e000.serial
[ 0.796766] mxs-auart 8006e000.serial: Found APPUART 3.1.0
[ 0.802979] 80070000.serial: ttyAPP3 at MMIO 0x80070000 (irq = 232, base_baud = 1500000) is a 80070000.serial
[ 0.814052] mxs-auart 80070000.serial: Found APPUART 3.1.0
[ 0.820271] 80072000.serial: ttyAPP4 at MMIO 0x80072000 (irq = 233, base_baud = 1500000) is a 80072000.serial
[ 0.831282] mxs-auart 80072000.serial: Found APPUART 3.1.0
[ 0.857508] loop: module loaded
[ 0.863452] libphy: Fixed MDIO Bus: probed
[ 0.983202] 800f0000.ethernet supply phy not found, using dummy regulator
[ 1.104434] libphy: fec_enet_mii_bus: probed
[ 1.114285] 800f4000.ethernet supply phy not found, using dummy regulator
[ 1.124387] PPP generic driver version 2.4.2
[ 1.129335] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.136409] usbcore: registered new interface driver usbserial
[ 1.142411] usbcore: registered new interface driver usbserial_generic
[ 1.149209] usbserial: USB Serial support registered for generic
[ 1.155994] mousedev: PS/2 mouse device common for all mice
[ 2.033080] rtc-pcf8563 1-0051: pcf8563_write_block_data: err=-6 addr=0e, data=03
[ 2.040601] rtc-pcf8563 1-0051: pcf8563_probe: write error
[ 2.046263] rtc-pcf8563: probe of 1-0051 failed with error -5
[ 2.056221] stmp3xxx-rtc 80056000.rtc: rtc core: registered 80056000.rtc as rtc0
[ 2.064379] i2c /dev entries driver
[ 2.070276] stmp3xxx_rtc_wdt stmp3xxx_rtc_wdt: initialized watchdog with heartbeat 19s
[ 2.080672] 80010000.ssp supply vmmc not found, using dummy regulator
[ 2.143144] mxs-mmc 80010000.ssp: initialized
[ 2.149495] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.161558] usbcore: registered new interface driver usbhid
[ 2.167285] usbhid: USB HID core driver
[ 2.188390] NET: Registered protocol family 10
[ 2.196028] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 2.204851] NET: Registered protocol family 17
[ 2.209533] Key type dns_resolver registered
[ 2.216603] registered taskstats version 1
[ 2.228332] stmp3xxx-rtc 80056000.rtc: setting system clock to 1970-01-01 00:00:06 UTC (6)
[ 2.236713] of_cfs_init
[ 2.239357] of_cfs_init: OK
[ 2.243322] usb0_vbus: disabling
[ 2.246589] usb1_vbus: disabling
[ 2.249830] ALSA device list:
[ 2.252806] No soundcards found.
[ 2.256683] uart-pl011 80074000.serial: no DMA platform data
[ 2.262537] Waiting for root device /dev/mmcblk0p3...
[ 2.746020] mmc0: new high speed MMC card at address 0001
[ 2.753004] mmcblk0: mmc0:0001 SEM04G 3.69 GiB
[ 2.758366] mmcblk0boot0: mmc0:0001 SEM04G partition 1 1.00 MiB
[ 2.765143] mmcblk0boot1: mmc0:0001 SEM04G partition 2 1.00 MiB
[ 2.771765] mmcblk0rpmb: mmc0:0001 SEM04G partition 3 128 KiB
[ 2.783372] mmcblk0: p1 p2 p3 p4 < p5 p6 >
[ 2.863054] random: fast init done
[ 2.869571] EXT4-fs (mmcblk0p3): INFO: recovery required on readonly filesystem
[ 2.877020] EXT4-fs (mmcblk0p3): write access will be enabled during recovery
[ 2.941289] EXT4-fs (mmcblk0p3): recovery complete
[ 2.950131] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
[ 2.958444] VFS: Mounted root (ext4 filesystem) readonly on device 179:3.
[ 2.966459] devtmpfs: mounted
[ 2.970254] Freeing unused kernel memory: 160K (c0642000 - c066a000)
[ 2.976743] This architecture does not have kernel memory protection.
[ 3.497108] systemd[1]: System time before build time, advancing clock.
[ 3.543339] systemd[1]: Failed to insert module 'autofs4': No such file or directory
[ 3.568117] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 3.626529] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[ 3.646532] systemd[1]: Detected architecture arm.
Welcome to Debian GNU/Linux 9 (stretch)!
[ 3.693443] systemd[1]: Set hostname to <wirenboard-ACP6FPZO>.
[ 5.337784] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 5.374803] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ 5.441040] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ 5.484696] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ 5.525404] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 5.564883] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 5.594567] systemd[1]: Listening on fsck to fsckd communication Socket.
[ OK ] Listening on fsck to fsckd communication Socket.
[ OK ] Created slice System Slice.
Starting File System Check on Root Device...
Mounting /sys/kernel/config...
Mounting POSIX Message Queue File System...
[ OK ] Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-getty.slice.
Mounting Debug File System...
Starting Load Kernel Modules...
[ OK ] Reached target Remote File Systems.
[ OK ] Reached target Paths.
[ OK ] Listening on Journal Socket (/dev/log).
Starting Journal Service...
[ OK ] Listening on udev Control Socket.
[ OK ] Reached target Slices.
[ OK ] Created slice system-systemd\x2dfsck.slice.
[ OK ] Reached target Encrypted Volumes.
Starting Create list of required st…ce nodes for the current kernel...
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Mounted Debug File System.
[ OK ] Mounted /sys/kernel/config.
[ OK ] Started Create list of required sta…vice nodes for the current kernel.
[ OK ] Started Load Kernel Modules.
[ OK ] Started File System Check Daemon to report status.
Starting Apply Kernel Variables...
Starting Create Static Device Nodes in /dev...
[ OK ] Started Apply Kernel Variables.plete)
[ OK ] Started Create Static Device Nodes in /dev.
Starting udev Kernel Device Manager...
[ OK ] Started Journal Service.
[ OK ] Started udev Kernel Device Manager.lete)
[FAILED] Failed to start File System Check on Root Device.
See 'systemctl status systemd-fsck-root.service' for details.
Starting Remount Root and Kernel File Systems...
[ OK ] Reached target Timers.
[ OK ] Reached target Login Prompts.
[ 8.182127] EXT4-fs (mmcblk0p3): warning: mounting fs with errors, running e2fsck is recommended
[ OK ] Reached target[ 8.203826] EXT4-fs (mmcblk0p3): re-mounted. Opts: errors=remount-ro
Host and Network Name Lookups.
[ OK ] Reached target Sockets.
[ OK ] Started Emergency Shell.
[ OK ] Reached target Emergency Mode.
[ OK ] Started Remount Root and Kernel File Systems.
[ OK ] Reached target Local File Systems (Pre).
Starting Flush Journal to Persistent Storage...
Starting udev Coldplug all Devices...
Starting Load/Save Random Seed...
[ OK ] Reached target Local File Systems.
Starting Raise network interfaces...
[ OK ] Started Load/Save Random Seed.
[ OK ] Started Raise network interfaces.
[ 9.198775] systemd-journald[91]: Received request to flush runtime journal from PID 1
[ OK ] Reached target Network.
[ OK ] Reached target Network is Online.
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Started udev Coldplug all Devices.
You are in emergency mode. After logging in, type "journalctl -xb" to view
system logs, "systemctl reboot" to reboot, "systemctl default" or ^D to
try again to boot into default mode.
Give root password for maintenance
(or press Control-D to continue): [ 14.633900] mxs-dcp 80028000.dcp: Failed to register sha1 hash!
[ 14.649985] CAN device driver interface
[ 14.697030] mxs-dcp: probe of 80028000.dcp failed with error -22
[ 14.776288] 80034000.can supply xceiver not found, using dummy regulator
[ 14.908027] flexcan 80034000.can: device registered (reg_base=c8a40000, irq=209)
[ 15.226954] mxs-spdif-dai 80054000.spdif: MXS SPDIF Audio Transmitter
[ 16.170030] ci_hdrc ci_hdrc.0: EHCI Host Controller
[ 16.179866] lirc_dev: IR Remote Control driver registered, major 245
[ 16.230543] Driver for 1-wire Dallas network protocol.
[ 16.242268] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
[ 16.310175] lirc_pwm: module is from the staging directory, the quality is unknown, you have been warned.
[ 16.333247] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[ 16.385911] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 16.392751] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 16.400146] usb usb1: Product: EHCI Host Controller
[ 16.405136] usb usb1: Manufacturer: Linux 4.9.22-wb2 ehci_hcd
[ 16.410912] usb usb1: SerialNumber: ci_hdrc.0
[ 16.443162] mxs-spdif sound-spdif: snd-soc-dummy-dai <-> 80054000.spdif mapping ok
[ 16.566635] lirc_pwm lirc-rfm69: GPIO receiver on pin 37
[ 16.593541] lirc_pwm lirc-rfm69: lirc_dev: driver lirc-rfm69 registered at minor = 0
[ 16.601333] lirc_pwm lirc-rfm69: probed
[ 16.785358] hub 1-0:1.0: USB hub found
[ 16.797684] hub 1-0:1.0: 1 port detected
[ 16.893240] ci_hdrc ci_hdrc.1: EHCI Host Controller
[ 16.898287] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 2
[ 17.023250] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[ 17.083722] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 17.090561] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 17.097955] usb usb2: Product: EHCI Host Controller
[ 17.102870] usb usb2: Manufacturer: Linux 4.9.22-wb2 ehci_hcd
[ 17.108730] usb usb2: SerialNumber: ci_hdrc.1
[ 17.213318] usb 1-1: new full-speed USB device number 2 using ci_hdrc
[ 17.403826] hub 2-0:1.0: USB hub found
[ 17.423218] hub 2-0:1.0: 1 port detected
[ 17.483233] usb 1-1: device descriptor read/64, error -71
[ 17.833209] usb 1-1: device descriptor read/64, error -71
[ 18.093227] usb 1-1: new full-speed USB device number 3 using ci_hdrc
[ 18.333216] usb 1-1: device descriptor read/64, error -71
[ 18.926786] Adding 262140k swap on /dev/mmcblk0p5. Priority:-1 extents:1 across:262140k SS
[ 18.953229] usb 1-1: new full-speed USB device number 4 using ci_hdrc
[ 19.202226] usb 1-1: New USB device found, idVendor=0658, idProduct=0200
[ 19.209137] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[ 19.216392] usb 1-1: SerialNumber: 12345678-9012-3456-7890-123456789012
[ 20.425326] cdc_acm 1-1:1.0: ttyACM0: USB ACM device
[ 20.473194] usbcore: registered new interface driver cdc_acm
[ 20.478892] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 20.861453] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
[ 147.173157] random: crng init done
