Wirenboard 8.4 теряет WiFi соединение и не присоединяется больше
Здравствуйте. У меня контроллер присоединен через мобильный роутер. Сейчас мобильный интернет отключают периодически и WB теряет связь и больше не пытается присоединиться. NetworkManager restart помогает. 13-го я его рестартовал, сеть поднялась.
Есть идеи почему интерфейс может уходить в Inactive? Есть там какой-то таймаут?
Что видно в логе:
13-08-2025 14:05:01.894 [1755083101.8936] device (wlan0): driver supports Access Point (AP) mode
13-08-2025 14:05:00.708 [1755083100.7079] device (p2p-dev-wlan0): state change: disconnected → unmanaged (reason ‘removed’, sys-iface-state: ‘removed’)
13-08-2025 14:05:00.698 [1755083100.6974] device (wlan0): state change: disconnected → unmanaged (reason ‘unmanaged’, sys-iface-state: ‘managed’)
01-08-2025 22:25:06.450 [1754076306.4469] device (p2p-dev-wlan0): supplicant management interface state: disconnected → inactive
01-08-2025 22:25:06.446 [1754076306.4466] device (wlan0): supplicant interface state: disconnected → inactive
01-08-2025 22:24:56.824 [1754076296.8223] device (wlan0): state change: failed → disconnected (reason ‘none’, sys-iface-state: ‘managed’)
01-08-2025 22:24:56.819 [1754076296.8189] device (wlan0): Activation: failed for connection ‘zanzibar4’
01-08-2025 22:24:56.811 [1754076296.8100] device (wlan0): state change: config → failed (reason ‘no-secrets’, sys-iface-state: ‘managed’)
01-08-2025 22:24:56.810 [1754076296.8098] device (wlan0): Activation: (wifi) association took too long
01-08-2025 22:24:56.446 [1754076296.4428] device (p2p-dev-wlan0): supplicant management interface state: associating → disconnected
01-08-2025 22:24:56.442 [1754076296.4425] device (wlan0): supplicant interface state: associating → disconnected
01-08-2025 22:24:49.534 [1754076289.5304] device (p2p-dev-wlan0): supplicant management interface state: scanning → associating
01-08-2025 22:24:49.530 [1754076289.5301] device (wlan0): supplicant interface state: scanning → associating
01-08-2025 22:24:44.854 [1754076284.8491] device (p2p-dev-wlan0): supplicant management interface state: disconnected → scanning
01-08-2025 22:24:44.849 [1754076284.8488] device (wlan0): supplicant interface state: disconnected → scanning
01-08-2025 22:24:34.846 [1754076274.8438] device (p2p-dev-wlan0): supplicant management interface state: associating → disconnected
01-08-2025 22:24:34.843 [1754076274.8432] device (wlan0): supplicant interface state: associating → disconnected
01-08-2025 22:24:32.537 [1754076272.5349] device (p2p-dev-wlan0): supplicant management interface state: scanning → associating
01-08-2025 22:24:32.534 [1754076272.5347] device (wlan0): supplicant interface state: scanning → associating
01-08-2025 22:24:31.828 [1754076271.8274] device (p2p-dev-wlan0): supplicant management interface state: disconnected → scanning
01-08-2025 22:24:31.827 [1754076271.8271] device (wlan0): supplicant interface state: disconnected → scanning
01-08-2025 22:24:31.817 [1754076271.8166] device (wlan0): Activation: (wifi) connection ‘zanzibar4’ has security, and secrets exist. No new secrets needed.
01-08-2025 22:24:31.817 [1754076271.8156] device (wlan0): state change: prepare → config (reason ‘none’, sys-iface-state: ‘managed’)
01-08-2025 22:24:31.814 [1754076271.8142] device (wlan0): state change: need-auth → prepare (reason ‘none’, sys-iface-state: ‘managed’)
01-08-2025 22:24:31.810 [1754076271.8105] device (wlan0): Activation: (wifi) asking for new secrets
01-08-2025 22:24:31.810 [1754076271.8099] sup-iface[90b5dfed6fba4d72,0,wlan0]: wps: type pbc start…
(387,7 КБ)
Я вижу разрыв связи и отказ в соединении.
В диагностическом архиве данных за 08.01 - нет.
А загрузите пожалуйста логи NetworkManager за время с запасом?
NetworkManager.log.gz (1,2 МБ)
Так, я вижу что 1 августа после многократных попыток по таймауту прекртились, дествительно, попытки.
Для того чтобы они не прекращались в секцию [connection] добавьте
auth-retries=-1 # бесконечные повторные попытки аутентификации
autoconnect-retries=0 # неограниченное количество автоматических переподключений
И да, попрошу добавить по умолчанию.
Добрался попробовать. Не знает NetworkManager этих опций.
Aug 31 05:19:57 wirenboard-ALOWDROC NetworkManager[292584]: [1756617597.1922] config: unknown key ‘auth-retries’ in section [connection] of file ‘/etc/NetworkManager/conf.d/custom-retries.conf’
Aug 31 05:19:57 wirenboard-ALOWDROC NetworkManager[292584]: [1756617597.1923] config: unknown key ‘autoconnect-retries’ in section [connection] of file ‘/etc/NetworkManager/conf.d/custom-retries.conf’
A
Добрый день! Извините за задержку с ответом!
Покажите, пожалуйста, содержимое /etc/NetworkManager/conf.d/custom-retries.conf’ полностью.
Попробуйте также задать эти параметры не в conf.d, а для конкретного подключения.
Добрый день! Получается ли решить проблему?
