купил контроллер давно, сейчас настраиваю, сперва он завелся, но после сброса к заводу и апдейту прошивки, столкнулся с тем что модуль не работает, ниже логи (модуль физически воткнут в 3-й слот, открыл посмотрел)
Wiren Board 8.4.4 , release wb-2407 (as stable)
# systemctl status zigbee2mqtt
● zigbee2mqtt.service - zigbee2mqtt
Loaded: loaded (/lib/systemd/system/zigbee2mqtt.service; enabled; vendor preset: enabled)
Active: activating (auto-restart) (Result: exit-code) since Fri 2026-09-18 14:13:43 UTC; 337ms ago
Process: 25851 ExecStart=/usr/bin/npm start (code=exited, status=1/FAILURE)
Main PID: 25851 (code=exited, status=1/FAILURE)
CPU: 7.998s
# journalctl -u zigbee2mqtt.service -n 20 --no-pager
-- Journal begins at Fri 2026-09-18 09:39:04 UTC, ends at Fri 2026-09-18 14:13:43 UTC. --
Sep 18 14:12:19 wirenboard-AJ4FN6QV systemd[1]: zigbee2mqtt.service: Failed with result 'exit-code'.
Sep 18 14:12:19 wirenboard-AJ4FN6QV systemd[1]: zigbee2mqtt.service: Consumed 8.583s CPU time.
Sep 18 14:12:58 wirenboard-AJ4FN6QV systemd[1]: Stopped zigbee2mqtt.
Sep 18 14:12:58 wirenboard-AJ4FN6QV systemd[1]: zigbee2mqtt.service: Consumed 8.583s CPU time.
Sep 18 14:13:37 wirenboard-AJ4FN6QV systemd[1]: Started zigbee2mqtt.
Sep 18 14:13:38 wirenboard-AJ4FN6QV zigbee2mqtt[25851]: > zigbee2mqtt@2.10.0 start
Sep 18 14:13:38 wirenboard-AJ4FN6QV zigbee2mqtt[25851]: > node index.js
Sep 18 14:13:38 wirenboard-AJ4FN6QV zigbee2mqtt[25863]: Starting Zigbee2MQTT without watchdog.
Sep 18 14:13:42 wirenboard-AJ4FN6QV zigbee2mqtt[25863]: [2026-09-18 14:13:42] info: z2m: Logging to console, file (filename: log.log)
Sep 18 14:13:42 wirenboard-AJ4FN6QV zigbee2mqtt[25863]: [2026-09-18 14:13:42] info: z2m: Starting Zigbee2MQTT version 2.10.0 (commit #unknown)
Sep 18 14:13:42 wirenboard-AJ4FN6QV zigbee2mqtt[25863]: [2026-09-18 14:13:42] info: z2m: Starting zigbee-herdsman (10.0.7)
Sep 18 14:13:43 wirenboard-AJ4FN6QV zigbee2mqtt[25863]: [2026-09-18 14:13:43] info: zh:zstack:znp: Opening SerialPort with {"path":"/dev/ttyMOD3","baudRate":115200,"rtscts":false,"autoOpen":false}
Sep 18 14:13:43 wirenboard-AJ4FN6QV zigbee2mqtt[25863]: [2026-09-18 14:13:43] error: z2m: Error while starting zigbee-herdsman
Sep 18 14:13:43 wirenboard-AJ4FN6QV zigbee2mqtt[25863]: [2026-09-18 14:13:43] error: z2m: Failed to start zigbee-herdsman
Sep 18 14:13:43 wirenboard-AJ4FN6QV zigbee2mqtt[25863]: [2026-09-18 14:13:43] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
Sep 18 14:13:43 wirenboard-AJ4FN6QV zigbee2mqtt[25863]: [2026-09-18 14:13:43] error: z2m: Exiting...
Sep 18 14:13:43 wirenboard-AJ4FN6QV zigbee2mqtt[25863]: [2026-09-18 14:13:43] error: z2m: Error: Error: Input/output error setting custom baud rate of 115200
Sep 18 14:13:43 wirenboard-AJ4FN6QV systemd[1]: zigbee2mqtt.service: Main process exited, code=exited, status=1/FAILURE
Sep 18 14:13:43 wirenboard-AJ4FN6QV systemd[1]: zigbee2mqtt.service: Failed with result 'exit-code'.
Sep 18 14:13:43 wirenboard-AJ4FN6QV systemd[1]: zigbee2mqtt.service: Consumed 7.998s CPU time.
wb-cc2652p-flasher 3 -latest
Fetching latest release information...
Downloading firmware: CC1352P2_CC2652P_launchpad_coordinator_20250321.zip
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
100 208k 100 208k 0 0 299k 0 --:--:-- --:--:-- --:--:-- 299k
Firmware extracted to: /tmp/tmp.TBG0cyvRyJ/CC1352P2_CC2652P_launchpad_coordinator_20250321.hex
Using RTS_GPIO 106
Opening port /dev/ttyMOD3, baud 500000
Reading data from /tmp/tmp.TBG0cyvRyJ/CC1352P2_CC2652P_launchpad_coordinator_20250321.hex
Firmware file: Intel Hex
Connecting to target...
ERROR: Timeout waiting for ACK/NACK after 'Synch (0x55 0x55)'
# python3 ./check_cc2652p.py /dev/ttyMOD3
No response received. The module might not be working.
