Добрый день. Внезапно отвалился WBIO-DO-R10A-8. Из UI устройств не реагирует на выключатель, после обновления страницы выключатель возвращается на “выкл”. При удалении и последующем добавлении модуля в UI в логах WB идут ошибки (см ниже)
Сбросил WB до заводских настроек, не помогает.
Jul 30 11:07:07 wirenboard-A2H24T55 user.info wb-hwconf-manager: Adding wb6-extio1:wbio-do-r3a-8Jul 30 11:07:06 wirenboard-A2H24T55 user.info wb-hwconf-manager: Initializing wb6-extio1:wbio-do-r3a-8.
Jul 30 11:07:08 wirenboard-A2H24T55 user.info wb-hwconf-manager: Warning (reg_format): “reg” property in /fragment/overlay/extio1_wbio_do_r3a_8@20 has invalid length (4 bytes) (#address-cells == 2, #size-cells == 1)
Jul 30 11:07:08 wirenboard-A2H24T55 user.info wb-hwconf-manager: Warning (avoid_default_addr_size): Relying on default #address-cells value for /fragment/overlay/extio1_wbio_do_r3a_8@20
Jul 30 11:07:08 wirenboard-A2H24T55 user.info wb-hwconf-manager: Warning (avoid_default_addr_size): Relying on default #size-cells value for /fragment/overlay/extio1_wbio_do_r3a_8@20
Jul 30 11:07:08 wirenboard-A2H24T55 user.warn kernel: [ 770.958211] mcp230xx: probe of 1-0020 failed with error -11
Jul 30 11:07:09 wirenboard-A2H24T55 user.info wb-hwconf-manager: Running hook service_restart_delete_retained wb-homa-gpio /devices/wb-gpio/#
Jul 30 11:07:15 wirenboard-A2H24T55 daemon.info wb-rules[2136]: WARNING: [driver] Failed to accept ‘/meta/order’ on control ‘wb-gpio/A4_IN’: strconv.Atoi: parsing “”: invalid syntax, ignored
Jul 30 11:07:15 wirenboard-A2H24T55 daemon.info wb-rules[2136]: WARNING: [driver] Failed to accept ‘/meta/order’ on control ‘wb-gpio/A1_IN’: strconv.Atoi: parsing “”: invalid syntax, ignored
Jul 30 11:07:15 wirenboard-A2H24T55 daemon.info wb-rules[2136]: WARNING: [driver] Failed to accept ‘/meta/order’ on control ‘wb-gpio/V_OUT’: strconv.Atoi: parsing “”: invalid syntax, ignored
Jul 30 11:07:15 wirenboard-A2H24T55 daemon.info wb-rules[2136]: WARNING: [driver] Failed to accept ‘/meta/order’ on control ‘wb-gpio/V_OUT_OK’: strconv.Atoi: parsing “”: invalid syntax, ignored
Jul 30 11:07:15 wirenboard-A2H24T55 daemon.info wb-rules[2136]: WARNING: [driver] Failed to accept ‘/meta/order’ on control ‘wb-gpio/A4_OUT’: strconv.Atoi: parsing “”: invalid syntax, ignored
Jul 30 11:07:15 wirenboard-A2H24T55 daemon.info wb-rules[2136]: WARNING: [driver] Failed to accept ‘/meta/order’ on control ‘wb-gpio/EXT1_R3A3’: strconv.Atoi: parsing “”: invalid syntax, ignored
Jul 30 11:07:15 wirenboard-A2H24T55 daemon.info wb-rules[2136]: WARNING: [driver] Failed to accept ‘/meta/order’ on control ‘wb-gpio/EXT1_R3A8’: strconv.Atoi: parsing “”: invalid syntax, ignored
Jul 30 11:07:15 wirenboard-A2H24T55 user.info wb-hwconf-manager: … 0% [ ] 0 of 55^M 1% [# ] 1 of 55^M 3% [## ] 2 of 55^M 5% [### ] 3 of 55^M 7% [#### ] 4 of 55^M 9% [##### ] 5 of 55^M 10% [###### ] 6 of 55^M 12% [######## ] 7 of 55^M 14% [######### ] 8 of 55^M 16% [########## ] 9 of 55^M 18% [########### ] 10 of 55^M 20% [############ ] 11 of 55^M 21% [#############
Jul 30 11:07:15 wirenboard-A2H24T55 daemon.info wb-rules[2136]: WARNING: [driver] Failed to accept ‘/meta/order’ on control ‘wb-gpio/A3_IN’: strconv.Atoi: parsing “”: invalid syntax, ignored
Jul 30 11:07:15 wirenboard-A2H24T55 daemon.info wb-rules[2136]: WARNING: [driver] Failed to accept ‘/meta/order’ on control ‘wb-gpio/EXT1_R3A6’: strconv.Atoi: parsing “”: invalid syntax, ignored
Jul 30 11:07:15 wirenboard-A2H24T55 daemon.info wb-rules[2136]: WARNING: [driver] Failed to accept ‘/meta/order’ on control ‘wb-gpio/A1_OUT’: strconv.Atoi: parsing “”: invalid syntax, ignored
Jul 30 11:07:15 wirenboard-A2H24T55 user.info wb-hwconf-manager: ] 12 of 55^M 23% [############## ] 13 of 55^M 25% [################ ] 14 of 55^M 27% [################# ] 15 of 55^M 29% [################## ] 16 of 55^M 30% [################### ] 17 of 55^M 32% [#################### ] 18 of 55^M 34% [##################### ] 19 of 55^M 36% [###################### ] 20 of 55^M 38% [######################## ] 21 of 55^M 40% [######################### ] 22 of 55^M 41% [########################## ] 23 of 55^M 43% [###########################
Jul 30 11:07:16 wirenboard-A2H24T55 user.info wb-hwconf-manager: ] 24 of 55^M 45% [############################ ] 25 of 55^M 47% [############################# ] 26 of 55^M 49% [############################## ] 27 of 55^M 50% [################################ ] 28 of 55^M 52% [################################# ] 29 of 55^M 54% [################################## ] 30 of 55^M 56% [################################### ] 31 of 55^M 58% [#################################### ] 32 of 55^M 60% [##################################### ] 33 of 55^M 61% [###################################### ] 34 of 55^M 63% [######################################## ] 35 of 55^M 65% [######################################### ]
Jul 30 11:07:16 wirenboard-A2H24T55 user.info wb-hwconf-manager: 6 of 55^M 67% [########################################## ] 37 of 55^M 69% [########################################### ] 38 of 55^M 70% [############################################ ] 39 of 55^M 72% [############################################# ] 40 of 55^M 74% [############################################## ] 41 of 55^M 76% [################################################ ] 42 of 55^M 78% [################################################# ] 43 of 55^M 80% [################################################## ] 44 of 55^M 81% [################################################### ] 45 of 55^M 83% [#################################################### ] 46 of 55^M 85% [##################################################### ] 47 of 55^M 87% [###################################################### ] 48 of 55^M 89% [##########
Jul 30 11:07:16 wirenboard-A2H24T55 user.info wb-hwconf-manager: ############################################# ] 49 of 55^M 90% [######################################################### ] 50 of 55^M 92% [########################################################## ] 51 of 55^M 94% [########################################################### ] 52 of 55^M 96% [############################################################ ] 53 of 55^M 98% [############################################################# ] 54 of 55^M100% [###############################################################] 55 of 55^M100% [###############################################################] 55 of 55^M
Jul 30 11:07:25 wirenboard-A2H24T55 user.warn kernel: [ 787.656517] unexport_store: invalid GPIO 160
Jul 30 11:07:25 wirenboard-A2H24T55 user.warn kernel: [ 787.683659] export_store: invalid GPIO 160
Jul 30 11:07:25 wirenboard-A2H24T55 user.warn kernel: [ 787.707707] unexport_store: invalid GPIO 161
Jul 30 11:07:25 wirenboard-A2H24T55 user.warn kernel: [ 787.726253] export_store: invalid GPIO 161
Jul 30 11:07:25 wirenboard-A2H24T55 user.warn kernel: [ 787.749556] unexport_store: invalid GPIO 162
Jul 30 11:07:25 wirenboard-A2H24T55 user.warn kernel: [ 787.756715] export_store: invalid GPIO 162
Jul 30 11:07:25 wirenboard-A2H24T55 user.warn kernel: [ 787.768894] unexport_store: invalid GPIO 163
Jul 30 11:07:25 wirenboard-A2H24T55 user.warn kernel: [ 787.773359] export_store: invalid GPIO 163
Jul 30 11:07:25 wirenboard-A2H24T55 user.warn kernel: [ 787.792098] unexport_store: invalid GPIO 164
Jul 30 11:07:25 wirenboard-A2H24T55 user.warn kernel: [ 787.808725] export_store: invalid GPIO 164
Jul 30 11:07:25 wirenboard-A2H24T55 user.warn kernel: [ 787.813220] unexport_store: invalid GPIO 165
Jul 30 11:07:25 wirenboard-A2H24T55 user.warn kernel: [ 787.837438] export_store: invalid GPIO 165
Jul 30 11:07:25 wirenboard-A2H24T55 user.warn kernel: [ 787.842561] unexport_store: invalid GPIO 166
Jul 30 11:07:25 wirenboard-A2H24T55 user.warn kernel: [ 787.852798] export_store: invalid GPIO 166
Jul 30 11:07:25 wirenboard-A2H24T55 user.warn kernel: [ 787.857286] unexport_store: invalid GPIO 167
Jul 30 11:07:25 wirenboard-A2H24T55 user.warn kernel: [ 787.874672] export_store: invalid GPIO 167
