Версия контроллера 6.9B/4 и также 6.9A.
Несколько раз отформатировал 2 флешки и записал файл образа раз 5.
переименовал файл в wb6_update_FACTORYRESET.fit
Включаю контроллер, нажимаю FW но в дебаге будто бы прошивка пытается стартовать потом сбрасывается и снова предлагает нажать FW и так по кругу.
U-Boot SPL 2017.03-wb1.3.0-g520058c326 (Jan 18 2022 - 10:56:38)
DRAM init ok, rows:16, ncs:1, size: 1024MB
.p0_mpdgctrl0 = 0x01160116
.p0_mpdgctrl1 = 0x0e3f0e3f
.p0_mprddlctl = 0x3f3f3c3f
.p0_mpwrdlctl = 0x3f3f3632
.p0_mpwldectrl0 = 0x00100012
.p0_mpwldectrl1 = 0x00130013
Trying to boot from MMC1
Warning - USDHC2 controller not supporting
U-Boot 2017.03-wb1.3.0-g520058c326 (Jan 18 2022 - 10:56:38 +0000)
CPU: Freescale i.MX6ULL rev1.1 792 MHz (running at 396 MHz)
CPU: Industrial temperature grade (-40C to 105C) at 43C
Reset cause: POR
Model: Wiren Board rev. 6.1 (i.MX6UL)
Board: Wiren Board MX6UL
DRAM: 1 GiB
MMC: FSL_SDHC: 0
Using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 0
Checking if there is a USB storage with update file wb6_update.fit
dev: usb1_vbus @ regulator@0
starting USB...
USB0: USB EHCI 1.00
USB1: USB EHCI 1.00
scanning bus 0 for devices... 2 USB Device(s) found
scanning bus 1 for devices... EHCI timed out on TD - token=0x80008c80
unable to get device descriptor (error=-1)
1 USB Device(s) found
scanning usb for storage devices... 1 Storage Device(s) found
Device 0: Vendor: Flash Rev: 6.90 Prod: USB Disk
Type: Removable Hard Disk
Capacity: 15000.0 MB = 14.6 GB (30720000 x 512)
reading wb6_update.fit
** Unable to read file wb6_update.fit **
reading wb6_update_FACTORYRESET.fit
1 bytes read in 20 ms (0 Bytes/s)
# Detected USB flash drive with update file
# Filename: wb6_update_FACTORYRESET.fit
# Press a FW key if you want to update firmware from this file
# or wait 3 seconds to boot normally.
USB update procedure start
Checking if ubootenv part is present
## Loading FIT header to 0x82000000 ...
## Loading FIT strings to 0x82000028 ...
CPU: Industrial temperature grade (-40C to 105C) at 46C
Reset cause: POR
DRAM: 1 GiB
MMC: FSL_SDHC: 0
In: serial
Out: serial
Err: serial
.p0_mpdgctrl0 = 0x01170117
.p0_mprddlctl = 0x3f3f393f
.p0_mpwrdlctl = 0x3f3f3834
Reset cause: POR
DRAM: 1 GiB
MMC: FSL_SDHC: 0
In: serial
Out: serial
Err: serial
Hit any key to stop autoboot: 1
.p0_mprddlctl = 0x3f3f3b3f
Reset cause: POR
DRAM: 1 GiB
MMC: FSL_SDHC: 0
In: serial
Out: serial
Err: serial
starting USB...
USB0: USB EHCI 1.00
USB1: USB EHCI 1.00
.p0_mprddlctl = 0x3f3f3a3f
CPU: Industrial temperature grade (-40C to 105C) at 47C
Reset cause: POR
DRAM: 1 GiB
MMC: FSL_SDHC: 0
In: serial
Out: serial
Err: serial
starting USB...
USB0: USB EHCI 1.00
USB1: USB EHCI 1.00
## Loading FIT struct to 0x82000100 ...
FAT: Misaligned buffer address (820020c8)
Skip 11333216 bytes of data
FAT: Misaligned buffer address (8200125c)
Skip 47891 bytes of data
FAT: Misaligned buffer address (8200173c)
Skip 34749 bytes of data
FAT: Misaligned buffer address (82000f70)
Skip 217229000 bytes of data
FAT: Misaligned buffer address (8200089c)
** wb6_update_FACTORYRESET.fit shorter than offset + len **
Can't find subimage 'ubootenv'
Extracting kernel
11349856 bytes read in 6604 ms (1.6 MiB/s)
Description: Update kernel
Type: Kernel Image
Compression: uncompressed
Data Start: 0x82000300
Data Size: 11333216 Bytes = 10.8 MiB
Architecture: ARM
OS: Linux
Load Address: unavailable
Entry Point: unavailable
Hash algo: sha1
Hash value: 855731103e35fa26fcdde99340a5980680759c13
## Verifying ... sha1+
Loading part 0 ... OK
Extracting DTB
## Loading FIT header to 0x83000000 ...
## Loading FIT strings to 0x83000028 ...
## Loading FIT struct to 0x83000100 ...
FAT: Misaligned buffer address (830020c8)
FAT: Misaligned buffer address (8300125c)
64975 bytes read in 508 ms (124 KiB/s)
Description: Update DTB
Type: Flat Device Tree
Data Start: 0x83000480
Data Size: 47891 Bytes = 46.8 KiB
Architecture: ARM
Hash algo: sha1
Hash value: 50379d0c7fb9a54564de1311fee0fb398cef285a
## Flattened Device Tree blob at 83000000
Booting using the fdt blob at 0x83000000
Loading Device Tree to bef60000, end bef6eb12 ... OK
Starting kernel ...
CPU: Industrial temperature grade (-40C to 105C) at 48C
Reset cause: POR
DRAM: 1 GiB
MMC: FSL_SDHC: 0
In: serial
Out: serial
Err: serial
starting USB...
USB0: USB EHCI 1.00
USB1: USB EHCI 1.00
1 bytes read in 19 ms (0 Bytes/s)
No USB update detected, continuing boot
switch to partitions #0, OK
mmc0(part 0) is current device
SD/MMC found on device 0
324 bytes read in 74 ms (3.9 KiB/s)
Importing environment from 0x82000000...
Checking if uenvcmd is set ...
Running default loadzimage ...
5899184 bytes read in 410 ms (13.7 MiB/s)
MMC read: dev # 0, block # 2016, count 32 ... 32 blocks read: OK
Reading overlays list from eMMC
Reading factory fdt name from eMMC
Loading factory fdt imx6ul-wirenboard690
47104 bytes read in 216 ms (212.9 KiB/s)
485 bytes read in 203 ms (2 KiB/s)
Applying DT overlay wb6-nogsm
597 bytes read in 227 ms (2 KiB/s)
Applying DT overlay wb6-wifi-rtl8723bu
509 bytes read in 207 ms (2 KiB/s)
Applying DT overlay wb6-noradio
334 bytes read in 166 ms (2 KiB/s)
Applying DT overlay wb6-eth1
254 bytes read in 104 ms (2 KiB/s)
Applying DT overlay temp-industrial
Applying extra overlay
Booting from mmc ...
Loading Device Tree to bef4c000, end bef6efff ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.10.35-wb116 (jenkins@wbdevenv) (arm-linux-gnueabihf-gcc (Debian 6.3.0-18) 6.3.0 20170516, GNU ld (GNU Binutils for Debian) 2.28) #1 Wed Jul 6 16:10:09 UTC 2022
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Wiren Board rev. 6.9.0 (i.MX6UL/ULL)
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] cma: Reserved 16 MiB at 0xbf000000
[ 0.000000] Zone ranges:
Лог дебага до моменрта обычного старта
