Нет интернета на контроллере ,docker
здравствуйте, при установке docker столкнулся с проблемой
Err:1 http:debian-mirror.wirenboard.com/debian bullseye InRelease
403 Forbidden [IP: 172.67.192.89 80]
Err:2 http:debian-mirror.wirenboard.com/debian bullseye-updates InReleas
Err:3 http:deb.wirenboard.com/wb6/bullseye stable InRelease
Err:4 http:debian-mirror.wirenboard.com/debian bullseye-backports InRele
Err:5 http:debian-mirror.wirenboard.com/debian-security bullseye-securitlease
Reading package lists… Done
N: See apt-secure(8) manpage for repository creation and user configuratioils.
N: Updating from such a repository can’t be done securely, and is thereforbled by default.
E: The repository ‘http:debian-mirror.wirenboard.com/debian bullseye InR’ is not signed.
E: Failed to fetch http:debian-mirror.wirenboard.com/debian/dists/bullseelease 403 Forbidden [IP: 172.67.192.89 80]
E: The repository ‘http:debian-mirror.wirenboard.com/debian bullseye-updnRelease’ is not signed.
E: Failed to fetch http:debian-mirror.wirenboard.com/debian/dists/bullseates/InRelease 403 Forbidden [IP: 172.67.192.89 80]
E: The repository 'http:deb.wirenboard.com/wb6/bullseye stable InReleaseot signed.
E: Failed to fetch http:deb.wirenboard.com/wb6/bullseye/dists/stable/InR 403 Forbidden [IP: 172.67.192.89 80]
E: Failed to fetch http:debian-mirror.wirenboard.com/debian/dists/bullsekports/InRelease 403 Forbidden [IP: 172.67.192.89 80]
E: The repository ‘http:debian-mirror.wirenboard.com/debian bullseye-bac InRelease’ is not signed.
E: Failed to fetch http:debian-mirror.wirenboard.com/debian-security/dislseye-security/InRelease 403 Forbidden [IP: 172.67.192.89 80]
E: The repository ‘http:debian-mirror.wirenboard.com/debian-security bulsecurity InRelease’ is not signed.
root@wirenboard-AW5MPASN:~#
в веб иртерфейсе
P.S. везде после https:: удалил ‘//’, иначе не давало опубликовать
прилагаю диагностический файл
(вложения)
(204 KB)
  1. А пинг до других сервисов работает? Попробуйте выполнить:
ping google.com
ping 8.8.8.8
ping debian-mirror.wirenboard.com
  1. Также выполните следующую команду для проверки:
curl -I http://debian-mirror.wirenboard.com/debian
  1. Установку Docker вы выполняете по данной инструкции?
Кроме того, прошу проверить выполнение этих команд с другого устройства, так как ошибка 403 обычно указывает на блокировку сервиса.
фотка с putty, не пингуется, при этом с ноутбука, который подключен к той же сети пингуется нормально
3, да, докер ставлю по этой инструкции
(вложения)
(вложения)
Прошу прощения за долгий ответ.
Проверьте настройки сети на контроллере. Судя по поведению, у вас могут быть проблемы с сетевым подключением.
какие именно настройки стоит посмотреть? я смотрел, ему нормально выдало IP, веб интерфейс работает, но нет доступа в интернет
Судя по ошибкам, проблема может быть связана с маршрутизацией трафика, особенно если даже адрес 8.8.8.8 не пингуется.
какие возможные команды я могу применить?
Рекомендую ознакомиться с данной статьёй. Она должна помочь в решении вашей проблемы.
попробовал создать точку доступа WiFi, все подключилось, IP address контроллеру был выдан, на веб интерфейс заходит, но выхода в интернет все равно нет. также попробовал выдать статический IP. маску подсети и днс, аналогично, доступа в интернет нет
11:54, 2 декабря 2024 г., “Aleksandr Khlebnikov через Wiren Board Support” <info@wirenboard.com>:
[вложения доступны только сотрудникам техподдержки]
Пожалуйста опишите ожидаемый маршрут пакетов в интернет с контроллера. Вот именно по порядку: соединение-интерфейс-шлюз.Также покажите результаты ping к шлюзу.
Если я верно рассмотрел фото - то проблема св том что узел ics.enecelectronintorg.ru блокирует трафик. Исключите его из маршрута.
благодарю, все заработало
